B+ alternator bolt hot to the touch...
volky1970
volky1970 is offline
PostPosted: Fri May 09, 2025 5:35 am    Post subject: B+ alternator bolt hot to the touch... Reply with quote
Hi,
So yesterday I was warming up my car as usual and I decided to just touch the B+ terminal on the alternator and instantly gave me a blister.
I don't recall ever having this issue. Just popped up!
What could it be? Loose connection somewhere? B+ is tight.
Thanks.
1970 Beetle Turbo 2109cc MS II EFI, W/M Injection, Intercooler, FORD Wasted Spark Coilpack, 48lb. Injectors.
busdaddy
busdaddy is offline
PostPosted: Fri May 09, 2025 7:13 am    Post subject: Re: B+ alternator bolt hot to the touch... Reply with quote
Just because it's tight doesn't mean it's making good contact, take the connection apart and shine up all the parts, apply a little grease when reassembling as well to prevent corrosion.
You'll probably want to disconnect the battery before this job, unless you like excitement. Wink
Слава Україні!
volky1970
PostPosted: Fri May 09, 2025 7:20 am    Post subject: Re: B+ alternator bolt hot to the touch... Reply with quote
Hi,
Thanks for the quick reply. The B+ terminal is nice and shiny. No rust at all on it or around the area.
I was thinking of putting in a new wire, just have to see the wire thickness and how it runs in the car.
Here's the car...
jeffrey8164
jeffrey8164 is offline
PostPosted: Fri May 09, 2025 8:30 am    Post subject: Re: B+ alternator bolt hot to the touch... Reply with quote
You’re making me want to touch mine.
Recently, I noticed mine had come loose. Not loose enough to come off but loose enough for an arc to happen that burned the post almost in half. In fact it broke in half when I tried to tighten it. Luckily I still had enough threads to save the situation. Now I check it every time before I start the car.
Volkswagen!
(Compression 8.7:1)
volky1970
PostPosted: Fri May 09, 2025 8:31 am    Post subject: Re: B+ alternator bolt hot to the touch... Reply with quote
I guess I'll give it a little wiggle when I get home.
busdaddy
busdaddy is offline
PostPosted: Fri May 09, 2025 9:57 am    Post subject: Re: B+ alternator bolt hot to the touch... Reply with quote
Hi,
It doesn't matter how good it looks, take it apart and see if it's just as pretty on the surfaces that make contact, bet ya there's some discoloration or corrosion.
Слава Україні!
Eric&Barb
Eric&Barb is offline
PostPosted: Fri May 09, 2025 10:25 am    Post subject: Re: B+ alternator bolt hot to the touch... Reply with quote
Even if the connection surfaces look clean it could be corroded just enough when pushing so many amps.
Had problem with starter turning over well. Cleaned the starter to transaxle surfaces and dielectric greased up, which improved the situation a notable amount. Pulled the starter solenoid off to do same between those parts and those surfaces looked nice and clean. Went ahead with the cleaning and greasing, and BOOM made huge difference.
In Stereo, Where Available!
volky1970
PostPosted: Fri May 09, 2025 10:47 am    Post subject: Re: B+ alternator bolt hot to the touch... Reply with quote
Super. I disassemble when I get home.
ashman40
ashman40 is offline
PostPosted: Fri May 09, 2025 5:16 pm    Post subject: Re: B+ alternator bolt hot to the touch... Reply with quote
Is the B+ wire the stock sized 6.0mm^2 wire (equivalent of 9AWG) or something else? A smaller diameter wire would increase the resistance and cause heat to build up.
AshMan40
bsairhead
bsairhead is offline
PostPosted: Fri May 09, 2025 6:58 pm    Post subject: Re: B+ alternator bolt hot to the touch... Reply with quote
ashman40 wrote:
Is the B+ wire the stock sized 6.0mm^2 wire (equivalent of 9AWG) or something else? A smaller gauge wire would increase the resistance and cause heat to build up.
Smaller the gauge larger the wire Laughing
calvinater
calvinater is offline
PostPosted: Sat May 10, 2025 3:32 am    Post subject: Re: B+ alternator bolt hot to the touch... Reply with quote
Quote worthy
"Albatross"!
ashman40
ashman40 is offline
PostPosted: Sat May 10, 2025 7:25 am    Post subject: Re: B+ alternator bolt hot to the touch... Reply with quote
Shocked Doh! Good catch. I've corrected my wording.
AshMan40
volky1970
PostPosted: Mon May 12, 2025 5:48 am    Post subject: Re: B+ alternator bolt hot to the touch... Reply with quote
Hi,
Saturday I disconnected the wire to find under the heat shrink a slightly loose connector and the strands being a bit separated. I cut off that part of the wire and used a new connector solving the problem. Now the terminal is nice and normal.
Thank you all for your time.
Eric&Barb
PostPosted: Mon May 12, 2025 8:03 am    Post subject: Re: B+ alternator bolt hot to the touch... Reply with quote
Good that it was a simple fix. Thanks for the update!
