vik Samba Member
Joined: January 13, 2005 Posts: 240 Location: back in Czech
Posted: Fri Feb 03, 2023 12:59 pm Post subject: Re: 7 seater Caravelle Syncro to camper |
Thank you. I would prefer to be finished like year ago
Bullbar - Well I sold it already. Had multiple issues with registration, weight etc.
As always - knowing what I know now I will do some things differently _________________ T3 Syncro camper in progress |
vik Samba Member
Posted: Fri Feb 10, 2023 1:21 am Post subject: Re: 7 seater Caravelle Syncro to camper |
It is about the time to let the engine run again. Exhaust is back on. I thing I can call it V2 version as flexible pipe was added to prevent braking welds. Still it is not super nice job with nice bend pipes. But it does the job.
I realized that I might have a fridge sticking out a lot as the cabinet is much less deep due to much more comfortable Westy seat. Worst case - it will be changed to ARB style fridge behind passenger seat.
Front is welded in.
List to do before painter
- bleed brakes
- install new starter battery
- fill up coolant _________________ T3 Syncro camper in progress |
ALstew Samba Member
Posted: Mon Mar 13, 2023 10:53 am Post subject: Re: 7 seater Caravelle Syncro to camper |
Do you know if he will ship to the US? I have been messaging with him on instagram and he said he was going to check with DHL but never got back to me. And I don't want to keep bugging him. Thanks.
| vik wrote: |
Another interesting part might be airbox. In US there are several options available. I had cone cotton filter which I hated
- noisy
- it suck in hot air
In Germany there is company Zanzinger motorsport (I found them almost by an accident) and they have stainless steel bottom part of airbox and uses Subaru upper airbox type (there are 3 versions available). All located on common left side as most Subaru conversions. I do have intake to the righ side and want to utilize WBX cold air snorchel so they modified it to fit the airbox up side down. The elbow is 3D print I designed (V1) from ABS. I might add some ribs if needed. But it seems super sturdy.
vik Samba Member
Posted: Mon Mar 13, 2023 12:08 pm Post subject: Re: 7 seater Caravelle Syncro to camper |
Today after many months the engine run again.
Obviously there has to be something to spoil the moment.
As I´m still in the dash out situation the instrument cluster is connected only trough the flat connector. Before this rebuild I installed foil replacement and as far as I do remember all worked.
Now
- I do have tach(rev counter is working)
- alternator/battery light is working
- turn signal indication is working
- clock run
the bed:
- There is no oil light, temperature bulb is blinking like there is no connection and fuel is not showing anything.
QUESTION: where shall I start? All connectors seems to be plugged in.
T7a connector?
Testing instrument cluster?
Continuity on wiring between sensor and the flat connector?
vik Samba Member
Posted: Mon Mar 13, 2023 12:17 pm Post subject: Re: 7 seater Caravelle Syncro to camper |
[quote="ALstew"]Do you know if he will ship to the US? I have been messaging with him on instagram and he said he was going to check with DHL but never got back to me. And I don't want to keep bugging him. Thanks.
[quote="vik"]
Sorry I had to miss your post.
Well I don´t know. It is the customs thing.
I know this shop sells his filter case too https://www.be-vanlife.com/shop/t3/luftfilterkaste...r-a53fa02/ but I have not purchased from them anything.
Recently a fellow from Germany is putting an turbo subaru engine in. He just send me today a picture a intercooler water exchanger done by Zanzinger - looks super cool.
ALstew Samba Member
Posted: Wed Apr 12, 2023 6:58 am Post subject: Re: 7 seater Caravelle Syncro to camper |
| Thanks!!! And thanks for posting that picture. This is the best spot I have seen to mount an intercooler for this type of conversion. I bugged him again and he said he could ship some stuff and will get back to me after his month long road trip. |
vik Samba Member
Posted: Thu Apr 20, 2023 12:19 pm Post subject: Re: 7 seater Caravelle Syncro to camper |
| ALstew wrote: |
You welcome. It was coincidence that I got the picture from fellow T3 owner.
I have almost no time left to get my bus done. At least the intake is finally finished
I do hope to have the welding done next week. I hope.. _________________ T3 Syncro camper in progress |
vik Samba Member
Posted: Wed Sep 06, 2023 12:05 pm Post subject: Re: 7 seater Caravelle Syncro to camper |
Finally!!!
The rust issues has been taken care of.
End of next week to the painters and than 100 small jobs to make it road ready again  _________________ T3 Syncro camper in progress |
vik Samba Member
Posted: Tue Oct 24, 2023 12:40 pm Post subject: Re: 7 seater Caravelle Syncro to camper |
Hi all,
Can anyone tell me if there any special trick to install grommet on the front doors for cables?
And second if the step rubbers shall be somehow glued to the step?
Other than that I´m almost ready to take it to the state technical inspection (which is due every 2 years here). There is still some work to be done, but the front interior apart from the drivers door is finished and I needed to order one of the headlamp adjusters as it was broken and some other small parts.
To wrap it up:
- all new window seals
- right middle and rear windows are now sliding type
- original locker switch valve was sourced and installed for front locker
There are more items on the custom office from US ready for me  _________________ T3 Syncro camper in progress |
vik Samba Member
Posted: Thu Nov 16, 2023 2:04 am Post subject: Re: 7 seater Caravelle Syncro to camper |
After so many setbags, delays, frustrations and sometimes unrest within the family my Bus is road worthy again. I was almost considered to name him Mrs. Colombo.
BUT, there is always a but. CEL and after when I go to full stop my engine stalls. I got these codes which one is clear and the temperature might be linked to the MAP/MAF sensor in the intake.
I still try to make some kms before the winter with salted roads will be here and with I will see if I measured right and will have 3cm clearance in the garage doors  _________________ T3 Syncro camper in progress |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17403 Location: Brookeville, MD
vik Samba Member
Posted: Wed Nov 22, 2023 3:52 am Post subject: Re: 7 seater Caravelle Syncro to camper |
I did not solved any technical problem today
Nor I visited some super nice pictures location worth sharing.
Or even no upgrade was done to my bus.
But I´m super happy
- first time in my garage
- it fits
To put some context - Originally we planned different doors (basically 4 panels where 2 are interconnected if it make sense). But locally nobody wanted to make them. So we went with the classic section type door which take up space on the ceiling. And this was not taken in consideration when the plans were drawn. Anyway 3cm is enough.
Cold weather is litle late this year, but I wanted to get it under the roof and off the road before the salty stuff is all over the place. _________________ T3 Syncro camper in progress |
vik Samba Member
Posted: Mon Feb 12, 2024 2:16 am Post subject: Re: 7 seater Caravelle Syncro to camper |
Garage starts to look like a workshop slowly.
First tasks for me at the moment is to get the interior redone. I throw out all the 3x12mm wooden screws which are useless. As example whole rear unit was held together with those and L brackets.
Original material is 15mm birch plywood. I find it too soft for pocket screws so I went with Festool Domino I do have access to.
It cuts mortise and use hard wood tenon. You can see that on picture above. All glued together with PU glue and on some places supported with L brackets and screws.
The main unit with kitchen is getting to shape too.
Rear unit has new rear doors with dividers for good access. Will post more pictures later. _________________ T3 Syncro camper in progress |
vik Samba Member
Posted: Fri Feb 23, 2024 11:57 am Post subject: Re: 7 seater Caravelle Syncro to camper |
Small update from my garage. There is lot of stuff going on with the cabinets, but that I will post later, no pictures
But when I looked under the back I have found a liquid. Once in the engine bay it was obvious - coolant leaking from new bottle. Maybe after 200km? I don´t remember where I purchased it. Do not want to deal with this again soon so this was slightly impulsive, but change it today. No spill. I was trying best I could to get air out of the hoses after refill. And it looks good I think.
4Gears4Tires Samba Member
Posted: Fri Feb 23, 2024 4:37 pm Post subject: Re: 7 seater Caravelle Syncro to camper |
All that expense to go to an aluminum tank and it retains the stock blue cap? That just seems odd. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
vik Samba Member
Posted: Sun May 26, 2024 1:00 pm Post subject: Re: 7 seater Caravelle Syncro to camper |
Hi
I took my syncro out for first trip to Mikulov - wine region here. About 300km one way to find out if all is good.
This is not my image. I was there for stone walls workshop.
First nigh I stayed here
and on a way I found a space where the 2 red armies met in May 1945
The good
nothing fall off
The westy bed is much more comfortable than the one we had before.
12V system works good.
The bed
There might be one bowden from the heater bend as I still get some hot air from the vents
The ugly
Propsahft will need to be rebalanced as I get a vibration around 90km/h (off city speed limit)
Error 24 is probably related to issue with VSS or cable between VSS and ECU. When I look for speed I get 0 or random low speed.
There is still some interior parts like overhead locker I need to do. But first these issues has to be sorted along with complete oil change for engine and drivetrain after the rebuild. As we changed so many times it takes some time to dial it in fully. _________________ T3 Syncro camper in progress |
vik Samba Member
Posted: Mon Jun 24, 2024 12:03 am Post subject: Re: 7 seater Caravelle Syncro to camper |
Sorting my stuff out...
Propshaft was dropped and I delivered it to the shop rebuilding these. I thought balancing would do, but they pointed me to the play in UJs as well the coupling (donut) was overdue replacement with many cracks forming. This is how I picked it up
Installed and have no vibration anymore. Done
Error 24 - After cleaning intake, replacing the idle valve still nothing. Friend pointed me out to VSS as when the Subaru ECU don´t see speed when braking with the engine it sees so many conflicting information that it throws up a code.
1. changed the VSS as the old one had tip slightly filed away. Again don´t ask me why it started to rub after several K km. No change
2. Tested the VSS manually turning the input shaft and checking speed on FreeSSM diagnostic. It was working. When driving - nothing. Than by accident I noticed that when the lights are on - VSS is off. Made short test ride without lights and it seems all is working. VSS was grounded on gray wire with blue stripe which is always present with bulbs. Not sure why as I was not installing this. Routed to the ground tree. Done Need to make proper test drive, but wish me luck. _________________ T3 Syncro camper in progress |
vik Samba Member
Posted: Mon Jul 08, 2024 5:41 am Post subject: Re: 7 seater Caravelle Syncro to camper |
Well, clock is ticking. On Friday we are planning do depart for 3weeks of Balkan fun. The idea on way there is following:
Other than this last minute final maintenance.
- engine oil and filter change ✔ (Motul/Bosch)
- gearbox and front diff oil change ✔
- poptop new gasket ✔
- greased shiftier and replaced nut for self locking ✔
And so many small things like insurance and so on.
Changing the gearbox oil was dirty.
And obviously the engine protection had to be removed. Magnet (this is from diff, but the gearbox was similar) did not had anything worrying after the rebuild.
Last thing to do before we will start packing was the poptop seal. The old one was falling and it was really dirty around
Major spares are in the Bus along with tools. Lets hope I won´t need them. _________________ T3 Syncro camper in progress |
vik Samba Member
Posted: Sat May 10, 2025 11:05 am Post subject: Re: 7 seater Caravelle Syncro to camper |
This is not a dead thread
We took advantage of local bank holidays and went to Italy to show our 8 year old Venice.
We took advantage of great camp site out of Venice lagoon directly on the beach where I met fellow Samba member David (Mud$hooter) with his tastefully done Syncro Hightop.
After some beach time (water was still quite cold honestly) we went to Venice. Unfortunately weather turned to cold and rainy so we left early and visited some interesting places along the way and had good luck for nice overnight spots. Last few nights were not great as temperatures dropped to 3C and rain. In the poptop without thermal insulation was really cold.
Thermal springs in Villach (AUT) was great to heat up again.
Saltzburg castle was really ineresting. Unfortunately the Hangar 7 from RedBull was closed. Last stop before home was Passau where Donau and Inn are merging.
First night above Mondsee (AUT)
Camping spot
Venice - Best stuff was outside the city center anyway
Camping by memorial for Alpini- Terrazza sul Tagliamento (italian mountain divisions) above river Tagliamento where in summer you can do some driving. Due to the rains it was not possible at all. Around this point north there were some heavy fighting during WW1 up to the mountain tops. There are some parts of the fortifications possible to visit.
Above same river
Goriuda waterfall
And Passau:
vik Samba Member
Posted: Sun May 18, 2025 12:13 pm Post subject: Re: 7 seater Caravelle Syncro to camper |
Preparing for summer:
Aftermath of the Italy is one broken rear CV booth. This has to be addressed before we will go in July. Not sure where. Either central France or Balkan countries again.
Anyway - Since 2011 I have AC kit in a box. Well I build a house and rebuild few things on my Syncro. So this is the plan
- Noise/thermal insulation of drivers area
- AC install
- I´m booked for exhaust repair as I do finally have the correct holders
- few bits and bobs around based on time
#1 the insulation.
Driver side had some factory insulation which was cracked and moisture got under it. Over this was a cork layer broken in multiple places. I did 2 layers. First was polymer/Al sandwich followed by closed foam
Heater core is connected. Now I need to tight down the unit and order the AC lines with fittings _________________ T3 Syncro camper in progress |
