Aircooled Pilot Samba Member
Joined: December 07, 2002 Posts: 153 Location: Tri-Cities, Washington
Posted: Tue May 13, 2025 10:55 pm Post subject: Vent Window Seal - PITA |
I ordered Wolfsburg Wests Wing vent window seals and they seem to be nothing more than over thick wet-suit material that I could not get to slide in even with clamps and Windex/Silicone spray. I am thinking to use this stuff I would have to build a wooden block jig that holds the whole frame with another piece that pushes on the back of the glass with screw clamps. The material is absolutely too think in fact trying to get it in there with the clamps I had we actually bent the frame, so I had to reshape it. What is the trick? I did my SC windows a few years back but never had this issue. I'm guessing I got a different seal from somewhere because this sucks. That being said I took the easier and cheaper route and used a thicker mountain bike tube doubled up and was able to get it all together. I learned this trick when I did a front safari on my bug and the aftermarket glass was too thick. I'm open for suggestions I ordered enough of the WW rubber to do 3 buses but already ruined one piece. Thanks for any tips _________________ Insignificant Human with a couple of aircooled toys having adventures. Follow along on youtube.com/glennwhitcomb |
Lind Samba Member
Joined: November 06, 2000 Posts: 10218 Location: idaho
Posted: Wed May 14, 2025 5:30 am Post subject: Re: Vent Window Seal - PITA |
I sell the BBT seals which are incredibly easy to use and fit right. The other supplier's seals are way too thick and unusable in my opinion.
https://www.bbt4vw.com/en/catalogue/1-exterior/rubbers-seals/windows/seal-glass-to-ventframe-tq-1/
You can use you left over WW seals to refresh the seal in you fresh air box directional flaps. Their material works quite well there. _________________ .
Wanted:
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1603 Location: Eerie PA
Posted: Wed May 14, 2025 7:41 am Post subject: Re: Vent Window Seal - PITA |
Use a seal from safari window. Goes in great works as it should and looks really close to being stock. It’s not my idea I stole it from someone here but if you scroll through my thread listed in my signature line I took so pictures of doing mine. Just toss that WW piece it’s almost impossible to use. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop
1973 standard bug
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk |
campingbox  Samba Member
Joined: November 14, 2000 Posts: 10249 Location: Petaluma, CA
Posted: Wed May 14, 2025 8:22 am Post subject: Re: Vent Window Seal - PITA |
The trick is to make the correct press. The WW rubber works perfect when you have one. |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2209 Location: Bulli Klinik, Colorado Springs
Posted: Wed May 14, 2025 9:00 am Post subject: Re: Vent Window Seal - PITA |
pondoras box wrote: |
Use a seal from safari window. Goes in great works as it should and looks really close to being stock. It’s not my idea I stole it from someone here but if you scroll through my thread listed in my signature line I took so pictures of doing mine. Just toss that WW piece it’s almost impossible to use. |
That was me. Used them in my 59 and they fit perfectly. I'd never torture myself with those silly slabs of rubber. It looks and fits like it's meant to be. _________________ PM me about quality metal-work on your vehicle.
Mike K
Bulli Klinik
Colorado Springs |
Posted: Wed May 14, 2025 9:56 am Post subject: Re: Vent Window Seal - PITA |
campingbox wrote: |
Would you mind showing what it looks like? I was thinking the same think. When did you get down to CA? I thought you were still in WA. Hope all is well. _________________ Insignificant Human with a couple of aircooled toys having adventures. Follow along on youtube.com/glennwhitcomb |
Posted: Wed May 14, 2025 9:58 am Post subject: Re: Vent Window Seal - PITA |
Thanks I'll take a look bummer is that I bought a few sets that was a waste of $70.00 _________________ Insignificant Human with a couple of aircooled toys having adventures. Follow along on youtube.com/glennwhitcomb |
Posted: Wed May 14, 2025 11:10 am Post subject: Re: Vent Window Seal - PITA |
The safari window seal trick, thanks for sharing that Bulli Klinic it was a God send!
Piece of doo doo WW seal.
Home made clamping device in operation. This is the passenger side, flip it over the other side is cut out for the driver’s side. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop
1973 standard bug
Posted: Mon May 26, 2025 10:04 pm Post subject: Re: Vent Window Seal - PITA |
Thanks Lind I'll get a hold of you _________________ Insignificant Human with a couple of aircooled toys having adventures. Follow along on youtube.com/glennwhitcomb |
karl h Samba Member
Joined: October 10, 2005 Posts: 643 Location: austria
Posted: Mon May 26, 2025 11:15 pm Post subject: Re: Vent Window Seal - PITA |
i use an old trick a long gone VW trained mechanic showed me:
the old cork gaskets for the valvcovers had leftover cork on the inside if you break away the valvecover seal
i clamp the ventwindow in a vise using these thin cork parts. you cant break the glass, no matter how hard you clamp it, i tried on spare
i then use a rubber mallet to install the frame over the glass catching the rubber
go careful and try not to widen the frame, some dishwashing liquid helps
the safari seal looks like a good way too.... _________________ 61 panel: http://www.thesamba.com/vw/forum/viewtopic.php?t=465022
68 ghia vert
arctic alice (63 ragtop on irs): http://cal-look.no/lounge/index.php/topic,27456.0.html
86 Caravelle
04 new beetle vert |
hitest Samba Member
Joined: September 30, 2008 Posts: 10324 Location: Prime Meridian, ID
Posted: Tue May 27, 2025 8:44 am Post subject: Re: Vent Window Seal - PITA |
Safari seals do not allow the rubber to "ride" up over the triangular latch assembly if that makes sense.
Another vote for Lind as there has been no development of the WW seal as long as I remember. _________________
EverettB wrote: |
FU#5 |
von_hansel  Samba Member
Joined: June 12, 2006 Posts: 812 Location: Inland Empire
Posted: Tue May 27, 2025 12:15 pm Post subject: Re: Vent Window Seal - PITA |
What I don't like about the Wolfsburg West seal is that there is a ton of leftover material after you install it. It is a PITA to cut near the swoosh. I use an X-Acto knife but it is still a pain.
I used Lind's style recently (bought from a different supplier). It wanted to roll/ pull more to one side in the corner by the swoosh on one of the vent wing windows but other than that, it was a lot easier to clean up after installing. I used X-Acto knife for around the latch as the seal has extra material in that spot. I highly recommend the newer style that Lind is selling. _________________
Mugatu wrote: |
von_hansel is still so hot right now |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1348 Location: So. Cal
