MTT3107 Samba Member
Posted: Tue May 13, 2025 5:10 pm Post subject: AN fittings for fuel hoses |
So, I want to convert my fuel hoses to AN fittings.
I have dual EMPI HPMX 40’s on my bug.
I think I would need AN6 fittings, but want to make sure before ordering |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1760 Location: Niagara Region, CANADA
Posted: Tue May 13, 2025 5:14 pm Post subject: Re: AN fittings for fuel hoses |
AN6 will be good. -4 are a pain to assemble. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3842 Location: The Woodlands, TX
Posted: Tue May 13, 2025 5:52 pm Post subject: Re: AN fittings for fuel hoses |
Agree, ran -6 from tank to both carbs. |
Rob Combs Samba Member
Joined: December 30, 2020 Posts: 538 Location: South Bay LA, California
Posted: Tue May 13, 2025 10:11 pm Post subject: Re: AN fittings for fuel hoses |
I used AN4s. Gates vapor guard fuel hose. Get the end of the hose real warm. Push the fitting end on the hose quickly using a towel to protect yourself from the heat.
I used boiling water. Not difficult at all.
Never have fuel volume trouble either.
FWIW |
cjsuner Samba Member
Joined: January 04, 2013 Posts: 513 Location: Bay area CA
Posted: Wed May 14, 2025 10:35 am Post subject: Re: AN fittings for fuel hoses |
I'm currently in the process of doing it on mine too, I used -6.
What I am mainly concerned about with mine is the fittings on the carbs, as I don't have threaded fuel inlets, they are press in brass fittings.
(Ignore the leak... has be dealt with) _________________ 71 Super Convertible (Orange)
74 Standard Beetle (Light Blue) |
sidemarkers Samba Member
Posted: Wed May 14, 2025 11:35 am Post subject: Re: AN fittings for fuel hoses |
Recently bought a pair of quality stainless hose shears. Wish I would have done that 30 years ago. |
Augie Samba Member
Joined: February 15, 2004 Posts: 173 Location: LI, NY
Posted: Wed May 14, 2025 7:03 pm Post subject: Re: AN fittings for fuel hoses |
I have -4, got line and fittings from Earls.
slalombuggy Samba Member
Posted: Thu May 15, 2025 5:10 am Post subject: Re: AN fittings for fuel hoses |
cjsuner wrote: |
(Ignore the leak... has be dealt with) |
As long as uoi use a qualitÿ fitting and insrall it well, tgere is no problems using a compressuon fitting for your AN adapter. I had to use them a couple of times and have nevrr had a leak. |
