Chootrain470 Samba Member
Joined: March 01, 2023 Posts: 228 Location: Simi Valley, CA
Posted: Fri May 16, 2025 9:36 am Post subject: Brake Nightmares |
What started as a simple front brake hose replacement turned into a mess last night. I began by spraying penetrating oil and using a flare wrench to no avail. The nut began to round off so I stopped.
Next attempt I cut off the rubber hose and used a deep socket. I heated the fitting up with a torch and whacked with a hammer. No use. The nut is now completely rounded. I ended up cutting off the hard line and now need to figure out how to cut the fitting off the bracket without removing the bracket.
Iโm going to try vice grips first. Then a nut extraction tool. And last resort a dremel. Wish me luck.
And other suggestions are appreciated. |
1988M5 Samba Member
Joined: January 23, 2016 Posts: 853 Location: Tucson, AZ
Posted: Fri May 16, 2025 10:17 am Post subject: Re: Brake Nightmares |
Pull the spring clip up and away, the line will come off as-is.
EDIT; I looked at pictures of the clip and it's a closed circle on one end, I remember it as a double fork. You could still mangle it out, but you'd need a replacement.
BK _________________ 1991 tin top GL
Some BMWs.
pathao Samba Member
Joined: November 01, 2012 Posts: 340 Location: Montreal, Canada
Posted: Fri May 16, 2025 10:21 am Post subject: Re: Brake Nightmares |
I've always been told:
Everything that affects the brakes you will have top heat it up to shinny-red-hot-cherry-red, otherwise...
especially the bleeder screws.
That's why I have a small oxygen system. MAPP alone isn't enough.
Hang in there, You'll figure out a way. _________________ 1982 AC P27 - 2.0 FI FED - 091 - BA6
English is a second language to me |
1988M5 Samba Member
Posted: Fri May 16, 2025 10:32 am Post subject: Re: Brake Nightmares |
| pathao wrote: |
Hang in there, You'll figure out a way. |
I dunno about that. There is important rubber seals close by, especially the rear wheel cylinders. Penetrating oil, a good smack with a hammer and a 6 point socket has worked for me.
Some BMWs. |
Posted: Fri May 16, 2025 10:53 am Post subject: Re: Brake Nightmares |
| 1988M5 wrote: |
BK |
I actually preemptively order a new spring today. I'll see if just cutting the spring is enough to remove this. Seems like the easiest route if possible |
a914622 Samba Member
Joined: July 29, 2004 Posts: 957 Location: Westend of HWY2 , Wash
Posted: Fri May 16, 2025 10:54 am Post subject: Re: Brake Nightmares |
Small pipe wrench!! 4 or 6 inch one _________________ 87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 6020 Location: Bemidji, MN
Posted: Fri May 16, 2025 11:10 am Post subject: Re: Brake Nightmares |
| Chootrain470 wrote: |
| What started as a simple front brake hose replacement turned into a mess last night. |
that's exactly what i expect on 40 year old vehicles! my question always is.. "How far back am I going to have to go?" i try to approach brake work with *no* expectations of a timeline. just keep at it until it is done. i try to keep enough fittings and raw brake line on hand to deal with the inevitable "oh crap" moment. doesn't matter if it is a VW or a Chev truck. they all rust up here in the salty north. Cunifer is my friend. i feel your pain. _________________ -dan
www.thefixitworkshop.com |
drj434343 Samba Member
Joined: January 31, 2016 Posts: 457 Location: Portland, OR
Posted: Fri May 16, 2025 1:57 pm Post subject: Re: Brake Nightmares |
I have been in your position many times over the years. I've employed all the strategies already mentioned above, sometimes successfully, sometimes not.
One thing to add, which I started using a few years ago, is locking pliers designed for hex.
https://toolguyd.com/gedore-grip-wrench-locking-pliers-with-hex-jaws/
I have the Irwin version shown in that article, but there are several variations. The Irwins have literally never failed to dislodge a hard line nut, even if was rounded by previous efforts. It works on the flats, not the edges of the hex.
I swear by them now and sometimes even skip penetrating oil and heat. |
Posted: Fri May 16, 2025 2:26 pm Post subject: Re: Brake Nightmares |
| drj434343 wrote: |
I actually just ordered one. It sounds like a good buy. |
Posted: Fri May 16, 2025 7:46 pm Post subject: Re: Brake Nightmares |
Good news.
1. I cut the retaining spring and was able to get the old connection out. A new spring is coming so I should be able to fix this next week when the new hard line arrives.
2. I did the other brake hose up front with no issues. |
skemems Samba Member
Joined: February 23, 2017 Posts: 254 Location: Oregon
Posted: Fri May 16, 2025 10:41 pm Post subject: Re: Brake Nightmares |
This happened on my van on both front brake lines. No need to purchase another hard line. Just cut off the hard line as close to the nut as possible, purchase new metric flare nuts (M10x1.0 I think), and reflare brake line w flaring tool. _________________ 87 VW Westfalia - EJ25
86 VW Westfalia - EJ22
85 VW Westfalia - WBX 2.1 project |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24510 Location: NYC/Upstate/ROW
Posted: Sat May 17, 2025 1:11 am Post subject: Re: Brake Nightmares |
When I moved to LI I gave my welder and oxy setup to a young guy in the business, but kept my little consumer brand oxy mapp for just this work.
You can heat anything on a caliper to cherry without damaging seals, just use your head and fingers to track the heat. Just too hot to touch is ok for seals
Red will move bleeders, lines, flares like magic. Aldo good for those big nuts that the tailless monkeys like to bash with hammers or buy stupid expensive โ torque multipliersโ. You need chemistry, not torque on stuck stuff.
$75 today, they were $50 before the Orange Cheetoh farted
https://www.amazon.com/RX-WELD-Portable-Cylinder-C...&psc=1 _________________ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐ ๐ ๐ |
Posted: Sat May 17, 2025 12:44 pm Post subject: Re: Brake Nightmares |
Buy a new piece of tubing and sawzal the tubing nut off and move on. You are already buying the hose and the spring so you will be all set. Beware that some tubing wrenches are junk, I bought a NAPA wrench when I couldn't find my decades old craftsman and it wouldn't loosen even a slightly tight nut without spreading. This is one place where springing for a Snap-on or Mac tool is probably worth it. I later bought another Craftsman for almost nothing, I went into a Sears to buy something and saw they had a full bin of tubing wrenches in just the right size for this application for like $1 each, so I bought a handful and handed them out to my VW friends.
A pair of Vice Grips will often break one of these nuts loose, but it may collapse the nut rendering it questionable to reuse. |
Posted: Sat May 17, 2025 5:01 pm Post subject: Re: Brake Nightmares |
While Iโm waiting on parts to address my front brake, I went ahead with the others.
The other front brake hose was done without issues. One rear drum was a real pain but I eventually got it off with a blow torch and hammer. The rear brake hoses were also not an issue.
One question:
My rear brake adjuster seems too long. I am fairly certain that I assembled it correctly. Will this be an issue? I tried bending the adjuster plate a bit but I can do more if need be.
Posted: Sat May 17, 2025 5:34 pm Post subject: Re: Brake Nightmares |
| What if I put some spacer washers on the adjusting arm? |
Posted: Sat May 17, 2025 9:39 pm Post subject: Re: Brake Nightmares |
I just added the adjusters from a Bay Window bus to the block at the bottom of the shoes and adjusted the shoes up to minimal clearance just like I would do on a Bay when putting in new shoes. I used JB Weld on the threads so they wouldn't loosen up. So far I am happy with the improvement in the geometry. |
Posted: Mon May 19, 2025 11:15 am Post subject: Re: Brake Nightmares |
| I am still confused. Is it common to have this alignment issue? Can you see any issue if I just add some washers as shims? |
1988M5 Samba Member
Posted: Mon May 19, 2025 1:09 pm Post subject: Re: Brake Nightmares |
So, with brand new shoes (max outer diameter) and brand-new drums (minimum inner diameter) the adjuster needs to be that wide to get any resistance?
Doesn't make sense. Sum Ting Wong.
Some BMWs. |
Posted: Mon May 19, 2025 1:26 pm Post subject: Re: Brake Nightmares |
| 1988M5 wrote: |
BK |
Yes, they are completely new drums and shoes. The other side doesnโt have this issue. Iโll check again but Iโm fairly certain all of the springs are assembled correctly. |
tdivan82 Samba Member
Posted: Mon May 19, 2025 1:37 pm Post subject: Re: Brake Nightmares |
On some models, VW used a "U" shaped brake clip. On others, it's a "C" shaped clip with a through hole. Some VW models used both.
In the case of stuck brake line, the U clip will pull out usually with not much trouble. The C clip, as shown above, you simply cut the clip and the line is free from the body. That allows you to get a vicegrip on the nut and turn it.
Don't use mapp gas on brake lines. It's foolish to put that much heat into such thin metal. Iron calipers sure, but not the lines. You'll just end up damaging the line.
Everything costs more now after four years of Dementia Autopen, and his Wuhan flu. _________________ 82 Westy TDI (ahu) = 70 mph uphill + 28 mpg
See my Classified ads for some super deals on Diesel Vanagon parts! |
