Turn signal oddity
aquifer Premium Member
aquifer is offline
PostPosted: Thu May 08, 2025 3:27 pm    Post subject: Turn signal oddity Reply with quote
My turn signals quit working suddenly. The lights all work, including the park lights. The emergency flashers still work, but the bulb itself, inside the flasher switch, only flashes when I put the turn signal stalk in an up or down position.
The wiring looks right according to Bentley. Bit of a head scratcher here. I suppose the relay must be bad? The blinkers worked fine a few minutes earlier, and I wasn't working on anything related to wiring, but the next time I turned on the blinker, nothing happened. The battery is fully charged.
Any suggestions? Thank you!
Parts needed:
Front & rear NOS or used OEM door panels for a '67 in the original Gazelle color (dark tan/light brown).
Also looking for used white headliner pieces, both perforated and non-perforated.
67rustavenger
67rustavenger is offline
PostPosted: Thu May 08, 2025 3:48 pm    Post subject: Re: Turn signal oddity Reply with quote
How are your fuses looking?
One of my 67's did this. I remedied it by rotating the fuse closest to the steering column.
The fuses get a little corroded and rotating them makes a decent temporary connection.
I got fed up with the above and changed the fuse block to a more modern blade fuse deal.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
OldSchoolVW's Premium Member
OldSchoolVW's is offline
PostPosted: Thu May 08, 2025 4:40 pm    Post subject: Re: Turn signal oddity Reply with quote
Need a little clarification ...
When you have the ignition in the run position and the turn signal switch either up or down what happens?
The lights on the fenders go on-off-on-off as they should, but the green indicator in the speedo does not light at all?
None of the fender lights goes on-off-on-off and the green light in the speedo does not light at all?
Neither of these.
If the first scenario, rev the engine a bit to see if the indicator in the speedo starts to go on/off. If so, it is likely a poor contact in the flasher. Depending on which flasher you have you may be able to get the speedo indicator working by moving its connector to another terminal. Can you post a photo of your flasher that shows the terminal labels so we can give specific suggestions for this solution?
Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Thu May 08, 2025 6:05 pm    Post subject: Re: Turn signal oddity Reply with quote
The relay box and wiring are a little goofy but not too hard to troubleshoot.
I’d start with a printed color wiring diagram and check each connection.. i don’t remember if you’ve put a new harness in or not but the old terminals will crack and get loose causing different weird gremlins.
Maybe try tightening the screw in for the relay. That’s the ground for it
Robert in Memphis
Engine rebuild thread
aquifer is offline
PostPosted: Thu May 08, 2025 6:11 pm    Post subject: Re: Turn signal oddity Reply with quote
Neither of these.
With the key turned on and the signal lever either up or down, neither the fender nor rear signals turn on-off-on. The indicator between the oil and generator lights does not light up or blink. Nothing happens whatsoever.
With the headlights turned on, the dimmer switch works fine. The blue hi-beam light works fine. Moving the turn signal switch up or down with the lights on makes no difference. The blinkers do not work. But the headlights and dimmer switch continue to function normally.
With the emergency flasher switch pulled out, the hazard lights on the fenders flash normally, but the indicator light inside the red lens does NOT blink. However, if I move the turn signal lever up or down, the red indicator on the emergency flasher switch DOES blink. At all times, the flasher lights blink on-off-on out on the fenders.
The indicator between the idiot lights does not flash, but that could be a bulb. Would that matter? I don’t remember if it worked before, unfortunately.
At no time can I get the turn signal lever to make the blinkers work. Seemingly the ONLY thing that moving the turn signal lever affects is whether the red indicator in the emergency flasher switch works or not.
I did scratch on the fuse surface mentioned, but no dice there either.
It’s almost like there is a grounding issue somehow. Sometimes that can cause funky behavior like this. Nothing stands out to me right now yet though.
Parts needed:
aquifer is offline
PostPosted: Thu May 08, 2025 6:15 pm    Post subject: Re: Turn signal oddity Reply with quote
<deleted>
Parts needed:
aquifer is offline
PostPosted: Thu May 08, 2025 6:18 pm    Post subject: Re: Turn signal oddity Reply with quote
I will dig into this a little more. The problem does feel a little ground-ish to me. I wouldn’t be surprised if this is the problem. And no, I haven’t replaced any wiring, but there are a few crispy wires for sure.
Parts needed:
EVfun Premium Member
EVfun is offline
PostPosted: Thu May 08, 2025 6:34 pm    Post subject: Re: Turn signal oddity Reply with quote
aquifer wrote:
My turn signals quit working suddenly. The lights all work, including the park lights. The emergency flashers still work, but the bulb itself, inside the flasher switch, only flashes when I put the turn signal stalk in an up or down position. [1]
The wiring looks right according to Bentley. Bit of a head scratcher here. I suppose the relay must be bad? The blinkers worked fine a few minutes earlier, and I wasn't working on anything related to wiring, but the next time I turned on the blinker, nothing happened.[2] The battery is fully charged.
[1] - 2 questions. What does "only flashes when I put the turn signal stalk in and up or down position" mean? Isn't that when it is supposed to flash? The second part to this, do you mean the indicator in the speedometer flashes? If you have a turn signal indicator built into the turn signal switch it isn't a VW part and wider look at the wiring is needed to understand what you have.
[2] - You wrote, "the next time I turned on the blinker nothing happened." Is that different from the symptoms described in #1, "only flashes when I put the turn signal stalk in and up or down position"? I'm trying to put together an idea of what is has changed to try and figure out what is wrong.
PostPosted: Thu May 08, 2025 6:57 pm    Post subject: Re: Turn signal oddity Reply with quote
Since it is a sudden, complete failure rather than intermittent, I'd check the power source connections (Flasher 30 red wire to fuse panel and Flasher 15 black wire to fuse panel) as well as the ground connection. Try attaching a jumper wire from the flasher housing to a good ground and see if that helps.
Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
aquifer is offline
PostPosted: Fri May 09, 2025 7:07 am    Post subject: Re: Turn signal oddity Reply with quote
#1 - No, I'm talking about the little bulb inside the red lens in the flasher knob on the dash. When the flasher knob is pulled, the only time the red light blinks is if the turn signal stalk is up or down. The indicator between the idiot lights on the speedo NEVER blinks for me. But the emergency flashers work normally on the fenders regardless of whether the red light in the knob is blinking or not. But the turn signals do not work regardless of any knob or lever positions.
#2 - Again, that was a reference to the little red indicator light inside the emergency flasher knob. When the flashers are turned on, the red light inside the knob only flashes if I move the turn signal lever. When I said "...turned on the blinker and nothing happened", I mean that moving the turn signal lever up or down does not turn on the blinkers.
The indicator light inside the emergency flasher knob is a novel problem, but is likely related to the turn signals not working. There's no way that the position of the turn signal lever should affect whether the red light blinks or not, but it does.
I apologize that I'm not explaining it better. But the more I think about it and read these replies, the more I'm convinced it has something to do with the ground, or lack thereof. I don't know what could have changed from the time it was operating normally to now, because I wasn't working on the electrical system. But something could have gotten jostled or bumped I guess. That's the road I'm going to travel next and see where it leads.
I appreciate the thoughts!
Parts needed:
MrGoodtunes
MrGoodtunes is offline
PostPosted: Fri May 09, 2025 12:38 pm    Post subject: Re: Turn signal oddity Reply with quote
@ aquifer, your symtoms are almost exactly what happens with my buggy's blinkers after not being used for several days; except for one thing, when my turn signals are failing, hazard flashers work (including red knob light) regardless of turn signal switch position. The fix for me (which has been doing the trick for years now, but may not work for you 'cuz I'm using a mid70s hazard switch) is to fiddle with hazard switch while turn signal stalk is either up (right turn) or down (left turn). By pulling the hazard switch only part way out and jiggling it, turn signals begin to work and will stay good (until next similar failure after long period without use).
Zwitterkafer
Zwitterkafer is offline
PostPosted: Sat May 10, 2025 10:15 am    Post subject: Re: Turn signal oddity Reply with quote
Make sure that the emergency flasher switch is tight in the dash and well grounded. That ground is essential for the emergency flasher to be activated and for the flasher switch bulb to blink. The switch must be tight in the dash and any fresh paint scraped away a bit to allow for a ground connection. IIRC there exists a version of the switch with a dedicated ground wire, in recognition of this grounding problem.
When the '66 - '67 type switch is pulled, "s" on the flasher is connected to ground, to start the flasher. At the same time, the switch connects "49a" on the flasher to the bulb in the flasher switch. If jiggling the switch in various positions influences functionality, the grounding or internal contacts are suspect.
Confirm first that both tell-tale bulbs are good, and that the flasher ground and power source are both faultless. No LED type bulbs in use, right?
- Zeuxius, 400 BC
scrivyscriv
Samba Electrician
PostPosted: Sat May 10, 2025 10:22 am    Post subject: Re: Turn signal oddity Reply with quote
I looked through the wiring diagram some more and I think it may be on the black/ white and green stripe wire circuit. It carries the pulsing 12v to the turn signal switch, where it’s directed to left side or right side lights circuits. Five bucks or a boojee coffee says the wire terminal 49a on the flasher relay came loose or fell off!
On the flasher relay, terminals VL and VR send the pulsed voltage to BOTH left and right lights circuits at a factory T splice, Only when the hazard knob is pulled. I think the light in the hazard knob is back feeding through the turn signal switch when you move the turn switch.
Robert in Memphis
aquifer is offline
PostPosted: Sat May 10, 2025 11:13 am    Post subject: Re: Turn signal oddity Reply with quote
Thank you for digging into this a little more. I haven’t found the problem yet, but after digging into the wiring diagram today, I’m suspicious that the problem is in the relay like you mentioned, so I ordered one from WW.
I printed the wiring diagram and laid it in the trunk and carefully verified that the wires were all connected where they should be. I started with the turn signal circuit, but it evolved into everything connected to the fuse box because I couldn’t help myself. Haha.
Anyway, I took time to remove the spade connectors and scratched the surfaces a little to be sure everything was making contact. It didn’t help the turn signal issue, but I’m pretty confident that the wiring is ok and the connections are good. I also verified that the relay was well grounded. Nothing was rusty or corroded. I used a continuity tester to verify the ground, and also verified that there was 12 volts present everywhere that the diagram led me to think there should be.
So I’ll wire in the new relay when it gets here and report back.
Parts needed:
aquifer is offline
PostPosted: Thu May 15, 2025 7:07 pm    Post subject: Re: Turn signal oddity Reply with quote
Well the new relay didn’t fix it. Still no turn signals. The red light in the emergency flasher knob only flashes when I move the turn signal lever lever up or down.
I think I misread what scrivy said above, and I now agree that it must be backfeeding through the turn signal switch on the steering column. I really thought the feedback was inside the relay. But nope. I’ll dig deeper into the switch itself.
Any other ideas are welcome as well.
Parts needed:
EVfun is offline
PostPosted: Fri May 16, 2025 8:05 am    Post subject: Re: Turn signal oddity Reply with quote
The problem is, I don't think any of us really know what is inside of the 9 pin turn signal flasher. It is likely partly solid state, and that can make for some unusual failure modes, or unexpected sensitivity to grounds or power sources.
Functionally, the 9 pin flasher is a heavy duty flasher and relay with 3 sets of normally open contacts and 1 set of double throw contacts (likely in the form of a 4PDT relay). When the emergency flasher switch is pulled it will turn the relay on and using the now closed normally open contacts send flasher power to both sides of the turn signal switch and to the bulb in the flasher knob. The double throw contact set powers the flasher and when it switches it changes the power supply to the flasher from a terminal 15 fuse (ignition switched hot) to a terminal 30 fuse (always hot). The dash turn signal indicator is handled by the flasher like on other Bugs.
aquifer is offline
PostPosted: Fri May 16, 2025 8:36 am    Post subject: Re: Turn signal oddity Reply with quote
One cool thing regarding the relay I bought from WW: the black OEM relay cover fits perfectly on the WW relay which had a blue cover. All I had to do was remove the e-clips and swap the covers. Also, the color coded paper guide that goes over the spade connectors was a perfect swap too. So now I have a brand new relay, but with the OEM black cover and the original paper color code piece. The original cover and the paper were both in almost perfect condition, so I was tickled to see that they could be so easily swapped to preserve the OEM look.
As it turns out, I didn't need to buy the WW relay, but now I have a spare I guess. Probably not a bad idea anyway as things like this will be harder to find someday.
Parts needed:
EVfun is offline
PostPosted: Fri May 16, 2025 9:40 am    Post subject: Re: Turn signal oddity Reply with quote
Since you have had the cover off, what is inside of the OEM or WW 9 pin flasher? If the full wiring diagram can be figured out, including what is inside the flasher and inside the emergency flasher switch then the circuit as a whole could be better analyzed to try and figure out what problem could cause your symptoms.
If I understand your symptoms correctly, the turn signals don't work (1) and the emergency flasher do work except that the switch light doesn't flash unless you turn signal switch on (2). This failure was sudden, it all worked correctly one day but not the next.
aquifer is offline
PostPosted: Fri May 16, 2025 10:48 am    Post subject: Re: Turn signal oddity Reply with quote
Since you have had the cover off, what is inside of the OEM or WW 9 pin flasher? If the full wiring diagram can be figured out, including what is inside the flasher and inside the emergency flasher switch (I believe I have found that) then the circuit as a whole could be better analyzed to try and figure out what problem could cause your symptoms.
Your summary is correct. I did not try to figure out the internal wiring of the relay(s), but it may be of interest to try to figure it out.
Since the the new relay didn't fix the problem, I am going to take the turn signal switch off the steering column and see if I can identify the problem there. I had it apart a few months back because it wouldn't return to the center position with the steering wheel. One of the return arms had came loose, which I repaired, and it worked fine. So did the blinkers themselves - until the other day. Maybe one or two of the microscopic springs suddenly popped out of place somehow. I'll dig into it this weekend.
Parts needed:
scrivyscriv
Samba Electrician
PostPosted: Fri May 16, 2025 5:00 pm    Post subject: Re: Turn signal oddity Reply with quote
Ooh! Ooh! Teacher! I know this one!! Very Happy
Here ya go. This is the guts of a stock 9-pin flasher from my 1967 sunroof beetle. It’s mostly relay logic with some transistor switching and a handful of basic electronic components, but no solid state.
The double relays on one side of the board
And the electronics running ‘em on the other side. It’s a single layer PCB with through-hole mounting, very very easy to work on and repair. I’ve got the failure-prone parts in my digi-key wish list, but since I made a workaround using a pair of relays, the project went back burner.
Component values as indicated by their markings, if anyone is interested. The electrolytic capacitors are the most suspect parts and should be replaced if there’s any doubt to their integrity. There are eight carbon film resistors, one diode, four transistors, three electrolytic capacitors, and one choke or coil (not totally sure of its function at present).
Robert in Memphis
