perello Samba Member
Joined: April 15, 2005 Posts: 894 Location: where social security comes for free
Posted: Mon May 12, 2025 1:02 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
not unique and even less oddball, I've just cleaned and checked for wear out this 034
then I tested it on my 181 and works like a charm, I only post here because of the different looking vacuum canister
_________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
Joined: April 27, 2002 Posts: 6816 Location: Pentwater, Michigan
Posted: Mon May 12, 2025 7:05 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
That appears to be an aftermarket vacuum canister as it lacks a Bosch logo on the center of the rear facing canister side. The pull arm should have the numbers 579 if it is an original. There were a lot of 034 clones produced so there a lot of non original canisters out there too. _________________ Roads Scholar
Member# 2059 |
Posted: Tue May 13, 2025 3:23 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
agree that there is no bosch marking, but there is the number 527
1974 German Thing
1978 Bug 1200 |
Posted: Tue May 13, 2025 4:22 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
That arm number indicates it is probably a Bosch part. That number is not for a canister used by VW. It likely might be ok to use. _________________ Roads Scholar
Member# 2059 |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7509 Location: Houston, Texas
Posted: Wed May 14, 2025 8:16 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Your vacuum canister does have the small bend in the nipple. That is usually what you see. I am surprised you have a stamped one and no Bosch logo. Sometimes the Bosch logo is hard to see. It is very small.
527 maps to VW number 056 905 271 A. it was used on a 1.5 Golf or Scirocco. _________________ www.vwnos.com [email protected]
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15294 Location: Casa de Oro, California
Posted: Thu May 15, 2025 3:35 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
I'm posting these for the Gurus to tell me if any are rare unique or oddball or worth keeping or using.
211 905 205B
211 905 227B
heimlich  VWNOS.com
Posted: Thu May 15, 2025 3:51 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
BarryL wrote: |
I've seen them all. They have different applications. Keep them. They are all useful if you have a bunch of VW.
What carburetors do you use the most? _________________ www.vwnos.com [email protected]
70bus Samba Member
Posted: Thu May 15, 2025 5:56 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
I am running that 113905205M on my truck with 30P1; has a different timing requirement than a 111905205 dizzy. Found out the hard way when shop set my timing to the 111 spec and it ran terrible. Was good on the gasalyzer, tho! Runs nice with proper timing.
Have a 113905205T on the 70.
So those are handy for 1500 - 1600 motors.
Others might be worth trading to a restorer for a refurb on the ones you keep. That's what i did with my boxes of carbs, pumps and dizzys. A stash is great, but only if you'll need what's in it. The rest is baggage. I did keep some cast-iron ones, tho. _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater |
Posted: Thu May 15, 2025 5:58 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
131 205 is Bus only 1966-67. It’s sought after
113 T is very common 1969-70 Beetle and Bus
113 M very common 1968 Beetle Bus
178 009 bazillions of them. They would, if place end to end, reach to the moon and back.
173 028 very common 1973-79 Beetle and Thing
113 K very common 1966-67 Beetle and Bus
211 B is a Garbe Lahmeyer distributor for infrequent Beetle, Bus, Type III not rare
VJU4BR8 very common 36 hp Beetle
None of the distributors pictured are Rare Unique or Oddball. _________________ Roads Scholar
Member# 2059 |
BarryL  Samba Member
Posted: Thu May 15, 2025 6:40 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Thanks for all that.
tasb wrote: |
211 B is a Garbe Lahmeyer distributor for infrequent Beetle, Bus, Type III not rare |
Both the 211 905 205B and the 211 905 227B ? |
Posted: Fri May 16, 2025 2:09 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
That part number is for the vacuum canister only. The actual distributors were used on all three models at the time. The part number for the distributor was on a triangle shaped paper sticker that over time has gone missing.
Member# 2059 |
BarryL  Samba Member
Posted: Fri May 16, 2025 11:42 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
heimlich wrote: |
What carburetors do you use the most? |
30Pict1 |
heimlich  VWNOS.com
Posted: Fri May 16, 2025 11:47 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
BarryL wrote: |
heimlich wrote: |
30Pict1 |
All of those short aluminum with large vacuum canister are going to be good for you. _________________ www.vwnos.com [email protected]
BarryL  Samba Member
Posted: Fri May 16, 2025 11:48 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
BarryL wrote: |
tasb wrote: |
tasb wrote: |
That part number is for the vacuum canister only....
My numbers I listed are stamped on the points plates. |
Posted: Sat May 17, 2025 9:24 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Ah, Ok. Typically when people ask about them or advertise them they incorrectly use the number on the vacuum canister because it is most prominent. Honestly I’ve never given the points plate part numbers much thought since they are interchangeable. I Will investigate and report back. _________________ Roads Scholar
Member# 2059
BarryL  Samba Member
Posted: Sat May 17, 2025 6:24 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Also, tasb, are any of the photos I posted that end in 009 the "009" that VW people refer to when they brag about having an 009? |
Posted: Sat May 17, 2025 7:34 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
You have three pics of 009’s. The first is without a vacuum canister. This is THE 009 that is ubiquitous. I would not brag about running one of these. They lack a VW part number just the Bosch and were never factory installed on an engine. The other two are VW# 113 905 205 K’s and should have a vacuum canister on them. Their Bosch part number ends in 009. They were stock on Beetle and Bus 1966-1967. _________________ Roads Scholar
Member# 2059 |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79788 Location: Sneaking up behind you
Posted: Sun May 18, 2025 4:44 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
But I have the rare cast iron 009
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
BarryL  Samba Member
Posted: Sun May 18, 2025 11:39 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
OK using the information from this thread I threw away all the common distributors but I kept one of the Garbe Lahmeyer 211 905 205B.
Tasb Photo:
In the boxes where these marked 111 998 061:
What are the extra parts?
Also, tasb, I did not toss the Mexico body. I am sending it to you for your collection as you requested. |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26535 Location: Douglas, WY
Posted: Sun May 18, 2025 1:26 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Wait, you just tossed them? I forgot to comment above, those centrifugal 009s you depicted, there were two of them, one with JF 4 below the part number and another with Z 42 there. Those were German made 009s, which are generally more desirable than the later ones made in Brazil. (Brazil made ones have JF 4 above the part number) _________________ Andy T.
"What is Glutamodo, Horror of Toyko, besides total, fiendish, quality-a-you brain!" |
