"What wheels fit?" The ultimate wheel post.
Page: Previous  1, 2, 3 ... 174, 175, 176
S4VAGE
S4VAGE is offline
PostPosted: Wed Apr 16, 2025 6:21 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Jammasterjay wrote:
After lurking wheel fitment posts for months, I decided to try the Maxilite wheels and KO2’s. I would have liked 15” wheels for the sidewall profile, and I liked the old 14” KO2’s more square profile. The slider is .5-.75 clearance. Balancing was a little heavy because I didn’t want outer face weights.
Those look great!
Crooked Designer
Crooked Designer is offline
PostPosted: Thu Apr 24, 2025 8:47 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Well.. finally got there. After years of being on the fence, I took the leap and now am on 16" CLK320s with 215/65/16 Falken Wildpeak AT Trail tires.
For anyone considering new wheels / tires for a non-lifted westy, I can tell you that this is probably the answer for "how big of a tire can / should I get" I went back and forth for a long time on 215/65 vs 215/70 and I'm very happy with my choice. They look great, they run well (I have a subaru EJ25, so can't speak to pushing 27" wheels with an OEM motor) they don't rub at all. I have GoWesty "zero lift" springs all around with a few leveling spacers in the back.
Black satin powder coated rims. new R12 ball nuts and lug bolts, 45mm studs for the rear hubs, 5mm front 12mm rear spacers, and center caps with VW logos (now painted to match rims) from T3Technique. (Along with lots of free and great advice and timely email replies from Christopher. Thanks!) Silicone lug nut covers for the look and to keep corrosion down and crap out of the open ended lugs on the rear wheels. Fancy machined valve caps on OEM Mercedes valve stems (which for some reason come with tiny chrome caps that don't cover all of the threads on the valve stem)
For the install, the rear hubs had to come off to press in the new studs. I know you can probably do this without removing, but I also wanted to inspect wheel bearings, so was worth it. The grease caps have to come off the front wheels to get the spacers on, which means uninstalling / reinstalling the speedometer cable. Not a big deal, but something I didn't think of before getting into it. Rear wheel has plenty of clearance to slider door. Front tires don't rub even with the Terrawagen fender flares. Still need to figure out the spare under the front situation. Won't fit with just the added spacer to the bolt (that allowed the old 15" wheels to fit) but I have a "new clamshell solution" I'm hopefully going to figure out in the next week or so. Will def post about it if it works.
Hopes this info helps someone in the futurs. Thanks for all the DM replies from the various Samba people I hounded over the last year or so. I'll follow up after the next long trip to give a review on the tires in that thread.
Before (15" GoWesty rims and Michelin Agillis CrossClimate CMetric 205/65/15)
vs after
'85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit
5BWesty
5BWesty is offline
PostPosted: Mon May 05, 2025 2:50 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
cdussault wrote:
Installed the Mobelwagen Interceptors today...really like the fit. Running Geolander 215 60r16. They were a bit wonky to balance...
Can you tell me what center cap you're using here on the front wheels? Thanks.
Crooked Designer
PostPosted: Tue May 06, 2025 12:56 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Looks like the grease cap to me on the front.. So, no center caps.
cdussault
cdussault is offline
PostPosted: Thu May 08, 2025 9:56 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Correct! No center caps, though cleaned them up and painted to look presentable.
4Gears4Tires
4Gears4Tires is offline
PostPosted: Fri May 23, 2025 7:49 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
https://www.ebay.com/itm/126623731732?_skw=zender+...R4Dc6tnfZQ
One of my dream sets of wheels are up for sale. $1700 + Shipping. Surprised
Zender Turbo in 15x7 et 22
Jake de Villiers
Jake de Villiers is offline
PostPosted: Sat Jun 28, 2025 6:05 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
After spending a ton of money on body and paint and installing all new Sewfine cushions and covers, I sprang for new springs and shocks, too.
The Bilstein XHD shocks ride nicely but could use more rebound damping for a more controlled feel. The Schwenk Carat springs are progressive, so the ride height stays remarkably constant no matter how many guitars, double basses, etc. you cram into the van.
The T3 Big Bar up front really helps the tracking.
Chris at T3 guided me through installing a set of E320D Wagon wheels on the van. The 16 x 7.5 wheels with 225/55R16 Yokohama Advan tires make a difference to the responsiveness to steering corrections.
Super happy with the suspension at this point (except for the niggle with the shocks). I used to have Konis at full firm with OEM Carat springs and the performance was pretty good, though the ride was meant for a younger person! Very Happy
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
bajaleo Premium Member
bajaleo is offline
PostPosted: Sun Jul 13, 2025 9:31 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
These are from a W220 Mercedes sedan. Fronts are 8x18 ET30 and rears are 9x18 ET39. The fronts were a direct bolt on. The rears required a 15mm spacer. Spacers, lug nuts, lug nut covers and center caps are from Chris at T3 Technique.
Leo in San Juan Capistrano
1984 Wolfie Westy, Subaru EJ22 powered.
littlejoe
littlejoe is offline
PostPosted: Mon Aug 04, 2025 12:40 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Will these wheels fit without modification? 83 Westy.
Im told they're off a 1986 190E
I believe its a Gullideckel W126/107.
Looks to be 15x7 with a 25 offset. Center bore looks good. So that all seems to add up to work, but I'm not sure of the lug hole measurements, I think they're the 14mm?
[/img]
Current: 83 Westy WBX
Gone, but not forgotten: 57 Beetle, 71 Beetle, 82 Westy, 84 GTI, 01 New Beetle, 05 Passat Wagon, 06 Jetta, 08 Touareg, 09 Passat, 10 Touareg, 10 GTI, 19 GTI
Gone, firmly forgotten: 06 Jetta, 21 ID4
envirogisgirl
envirogisgirl is offline
PostPosted: Sun Oct 12, 2025 9:56 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Waldi wrote:
The MB part number for 6,5x15 37 steel rims is 210 400 0202
Edit: no spacers needed on syncro, dont know on 2-wd
What also fits on a Syncro (was in the mod of doing something stupid)
33x12.5x15 on 10x15 Jeep rims Wink
https://youtu.be/ViMVxyRLgvY
I was just digging thru the internet to find out of Jeep Wrangler JK era wheels would fit - you can get stock JK wheels left and right and BFG KO2 take-offs when jeepers size up right after purchase. .
Currently the syncro is running well trail chewed up 15" Mercedes stars w BFG K02s( however I do not yet know if there are spaceers, and or if these are knockoffs - They are sporting the Mercedes logo.
Reality is I would really prefer a set of Method wheels & if the Jeep JK bolt pattern will work _ I will keep my eyes peeled.
Thank you again!
dobryan Premium Member
dobryan is offline
PostPosted: Mon Oct 13, 2025 5:59 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Thank you again!
Contact Chris at T3 for the answer.
https://t3technique.com/
Dave O
Traveling after Building a bus for travel in Europe (euroBus)
The Western Syncro build
Twan
Twan is offline
PostPosted: Mon Oct 13, 2025 6:24 am    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Jeep JK is a 5x127(5x5) bolt pattern while Vanagon(and so many other German vehicles) are 5x112. Would take some big, ugly adapters to do that.
1984 2wd 7 Passenger Tin Top
tjet
tjet is offline
PostPosted: Thu Dec 11, 2025 12:29 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Those tires and wheels look great, and I like that stance, too Cool
What size and ET are the wheels? And tire size?
I had these on my '85, but they needed some thick adapters, so they didn't really work out too well. They came off a 944, and I think the size was 16x6 front, 16x7 rear. I sold them to a guy that was fixing up his Porsche.
Thanks!
LBC28730
LBC28730 is offline
PostPosted: Thu Jan 15, 2026 6:21 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
Also added to "What tires fit" although, this may ultimately be the right place!!
Wheels: 2003-2005 VOLKSWAGEN PASSAT Aluminium 15"
Factory OEM model 69830U20
These wheels also come with VW center cap and with standard lug nuts the caps can be slightly modified to fit.
Currently I have tall lugs so they will not fit in this configuration.
These are 15x7 , +37 offset, and need to be center bored to fit.
5mm spacers on each wheel.
Here is with LT215/75R-15 Yokohama Geolandar A/T G015 C
Schwenk Lift springs absolutely necessary to fit.
These JUST fit with no rubbing. At full right lock, it's VERY close to the fuel filler line but room to move without rubbing, and room to clear with full motion of suspension.
I'll have to measure to see what my current height/ground clearance is but, I was really surprised how noticeable this was. I definitely have to adjust my headlights.
1983.5 Westfalia
LBC28730
LBC28730 is offline
PostPosted: Thu Jan 15, 2026 6:26 pm    Post subject: Re: "What wheels fit?" The ultimate wheel post. Reply with quote
[/img]
Did you ever sort this out?
I have these wheels as well and have seen them used.
I feel that when I was looking at adapting them there was some fundamental element that made me decide against it however, that was years ago and the wheels are still sitting outside, and I've moved on to other wheel/tire configurations.
1983.5 Westfalia
Page 176 of 176
