Does this look right?
bnam
bnam is offline
PostPosted: Thu May 22, 2025 6:47 am    Post subject: Does this look right? Reply with quote
Sorry - for the blurry picture, but here'e my question:
The portion below the headlights had to be rebuilt and in previous repairs removed any traces of the original alignment of the mounting holes for the front turn signals. However, a user here had posted clear measurements that showed that the turn signals were not aligned exactly on the centerline but angled a bit from the center.
Using those measurements, when we fitted the lights, I noticed that the turnsignals did not point directly ahead, but were canted outward (see second pic). Is that how it is supposed to be?
Click to view image
1952 Citroen TA 11BL
runamoc Premium Member
runamoc is offline
PostPosted: Thu May 22, 2025 10:51 am    Post subject: Re: Does this look right? Reply with quote
When I eliminated the '72 big turn signals and put bullet fixtures in place of them. I just market a 'center line' from the fender 'ridge' with a plumb bob, like you, then and put the wire hole in the middle distance between the bottom of the headlight and the top of the bumper.
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
DaveB9
DaveB9 is offline
PostPosted: Thu May 22, 2025 1:44 pm    Post subject: Re: Does this look right? Reply with quote
I'm not sure how helpful this will be, because my indicators are the slightly earlier two piece housings, but for what it is worth they point straight forward, not canted to the side:
I am not sure this helps much either because the headlight area is so mangled, but this is the wing front cut off my car, in case you can make any kind of comparison of the hole locations:
sputnick60
sputnick60 is offline
PostPosted: Fri May 23, 2025 2:03 am    Post subject: Re: Does this look right? Reply with quote
Image of original German metal
Looks offset to in both photos. I wish I could provide you with the dimensions but the car is an ocean away.
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
bnam
bnam is offline
PostPosted: Fri May 23, 2025 3:56 am    Post subject: Re: Does this look right? Reply with quote
Thanks! My main question isn’t whether the lights once mounted point exactly straight ahead or slightly outward as they are in mine? Can any one else confirm?
Click to view image
Era Vulgaris
Era Vulgaris is offline
PostPosted: Fri May 23, 2025 5:25 am    Post subject: Re: Does this look right? Reply with quote
The turn signal holes had rotted on my 66, so I had to patch and re-cut them like you did. I used these as my guide
John Ghia wrote:
kiwighia68 wrote:
Mine are straight down from the headlight bucket, pointing straight forward
And here's a shot of the 67 I used to own, that had never been welded. The photo isn't taken direct on in front of the lights, so the camera lens curvature makes it look like it's pointing out, but you can see the base is directly below the headlight ring mounting screw
Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue
Rome
Rome is offline
PostPosted: Mon May 26, 2025 12:35 pm    Post subject: Re: Does this look right? Reply with quote
My '64 also had significant rust above and below the headlights when I bought it over 45 years ago. I took measurements of the blinker position from the less rusty side of the car and transferred them to patch panels that I brazed in at home. IIRC the 2 fastener holes for the blinker mounting studs are aligned directly below, and centered under the headlamp center. I never considered that there might be a small sideways outward alignment difference per your photo... My blinkers thereby point straight forward...
runamoc is offline
PostPosted: Mon May 26, 2025 1:00 pm    Post subject: Re: Does this look right? Reply with quote
Original '72 Ghia turn signals cost to much and IMO 'ugly". Went older style. Center on headlights and in the middle of bumper and headlight.
Era Vulgaris
PostPosted: Mon May 26, 2025 1:23 pm    Post subject: Re: Does this look right? Reply with quote
I knew in the back of my head that I had a drawn out diagram somewhere from when I had to do this with my car, but I couldn't find it earlier when I posted above. It was because of the name of the thread it was in (bullet blinkers) wasn't a search term I had considered. Finally tracked it down. This might help
https://www.thesamba.com/vw/forum/viewtopic.php?p=9684425#9684425
Currently own:
Previously owned:
