clockworkbox Samba Member
Joined: July 12, 2020 Posts: 471 Location: Williamsport, PA
Posted: Thu May 29, 2025 2:01 pm Post subject: Empi Trigger Shift Knob Hack |
There is nothing like this for the Empi shifter so I got this for Christmas and decided to make it work. It leaves an ugly gap if you use it as is and I did not like it. I screwed the insert down tight and then took a cheap hf 3/4" countersink bit to the brass insert. I kept drilling and then checking until I got it to work when I pulled the trigger for reverse. Then I used red threadlocker to bind the insert to the knob in the correct orientation. I let it set over night and unscrewed the whole unit. Finally, I filled the void inside with JB Weld epoxy, the 2 part kind with the mixing tube to get in below the threads. That dried over night again and it fits and works perfectly with no gap.
Shift knob:
https://a.co/d/42aWjEu
_________________ '69 Beetle (pieces)
Learning the hard way is still learning... |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2880 Location: HdG, MD & NJ
Posted: Thu May 29, 2025 7:44 pm Post subject: Re: Empi Trigger Shift Knob Hack |
Nice work. I put a skull on my Hurst shifter in a similar fashion. Now it’s hanging on the wall and the black knob is my draw. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6109 Location: 37.5N 77.1W
Posted: Mon Jun 02, 2025 1:17 pm Post subject: Re: Empi Trigger Shift Knob Hack |
I gently filed the bottom insert until a blue #2 pool ball had the right 'direction' when tightened. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17584 Location: Left coast, Canada
Posted: Tue Jun 10, 2025 2:35 am Post subject: Re: Empi Trigger Shift Knob Hack |
Posted: Tue Jun 10, 2025 9:04 am Post subject: Re: Empi Trigger Shift Knob Hack |
Yep, that's what I was going for. Nice Hurst! _________________ '69 Beetle (pieces)
jpaull Samba Member
Joined: February 22, 2005 Posts: 3642 Location: Paradise, Ca
Posted: Tue Jun 10, 2025 10:18 am Post subject: Re: Empi Trigger Shift Knob Hack |
Great minds think alike.
I rebuilt a hurst and used one of bruce's plates, and hurst shift ball
_________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
