4" Clock/Tach options?
cvsisinthehouse
cvsisinthehouse is offline
PostPosted: Sun Jun 01, 2025 8:40 pm    Post subject: 4" Clock/Tach options? Reply with quote
I have the original 6 volt clock in my '65 Ghia, which is now 12 volt. I dont need a clock but dont really need a tach as well. What is my easiest or cheapest option to put something there that works? Thanks,
Working on a big funeral...
'65 Ghia Coupe
'09 Pontiac Solstice Coupe
Many motorcycles
2 Seaters owned: '88 CRX, '73 & '76 TR6, '93 MR2, '99 SLK, '93 Corvette, '12 Mini Cooper Coupe
bnam
bnam is offline
PostPosted: Mon Jun 02, 2025 12:20 am    Post subject: Re: 4" Clock/Tach options? Reply with quote
Just run the same 6V clock. It should run on 12v as well. It did for me.
Click to view image
1952 Citroen TA 11BL
sputnick60
sputnick60 is offline
PostPosted: Mon Jun 02, 2025 1:57 am    Post subject: Re: 4" Clock/Tach options? Reply with quote
Yes, worked for me too
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
cvsisinthehouse
PostPosted: Mon Jun 02, 2025 7:08 am    Post subject: Re: 4" Clock/Tach options? Reply with quote
Thanks, I will try it. It wasnt working before.
'65 Ghia Coupe
Many motorcycles
Era Vulgaris
Era Vulgaris is offline
PostPosted: Mon Jun 02, 2025 11:59 am    Post subject: Re: 4" Clock/Tach options? Reply with quote
The cheapest and easiest thing, if your clock is actually broken, would be to simply not worry about it and leave it as is.
The 2nd cheapest would be to look for another clock that is tested working here in the classifieds, but make sure you keep a battery tender on the car if you don't drive it alot.
The easiest thing if you want a tach would be to send your clock to North Hollywood Speedometer and have them do the work to convert it to a tach. But it's really really not cheap.
Or, ISP West sells a early Ghia tachs that kinda match the early speedometers. Much much cheaper than having NHS do it, but it doesn't match exactly if that may or may not bother you.
https://vwispwest.com/gauges/tachometers/karmann-ghia/
Another option, one that cost me less than the ISP West tach, is you can make your own tach using a Porsche 914 tach, your old clock, and another speedo (just for the needle) like I did. But it's a good bit of work.
Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue
yorkjj
yorkjj is offline
PostPosted: Tue Jun 03, 2025 2:51 am    Post subject: Re: 4" Clock/Tach options? Reply with quote
Looking at the 914 tachs, it appears that they have far fewer lights and indicators which the Ghia clock has. If that is important, live with what you've got or have a clock converted to preserve the lights and additional gauges. My 74 clock was converted to a tach by North Hollywood, and it preserved the lights and the gas gauge.
A battery tender is important if you don't drive it daily.
Era Vulgaris
PostPosted: Tue Jun 03, 2025 5:14 am    Post subject: Re: 4" Clock/Tach options? Reply with quote
There are no indicators in the 66 and earlier clocks, only a backlight (OP has a 65). The Ghia clock has one backlight, and the 914 tach housing has two.
Currently own:
Previously owned:
cvsisinthehouse
PostPosted: Tue Jun 03, 2025 7:30 am    Post subject: Re: 4" Clock/Tach options? Reply with quote
I hooked up my clock to a good battery last night. I connected the positive to the only connection on the back, and touched the negative to the case. It didnt work. Is this the way to check it?
I dont need a tach as I have one that came with my fuel injection monitor.
'65 Ghia Coupe
Many motorcycles
yorkjj
yorkjj is offline
PostPosted: Tue Jun 03, 2025 8:31 am    Post subject: Re: 4" Clock/Tach options? Reply with quote
Thank you for the clarification; I stand corrected. I looked at the '65 owner's manual and could not get a clear picture of the clock. It must just be the later models with the clock with all the indicators.
bnam
bnam is offline
PostPosted: Tue Jun 03, 2025 11:04 am    Post subject: Re: 4" Clock/Tach options? Reply with quote
If you search, you’ll find some posts and videos on how to get a nonfunctioning clock to start again. I was able to do that - both that was 7 years ago and Indont remember the details well. There is a contact point with a blob of solder iirc.
Byas
Click to view image
Era Vulgaris
PostPosted: Tue Jun 03, 2025 11:29 am    Post subject: Re: 4" Clock/Tach options? Reply with quote
Yep, it's only 72-74 with the clock/gas multi-gauge that has the indicators in it.
Currently own:
Previously owned:
sputnick60
PostPosted: Wed Jun 04, 2025 4:15 am    Post subject: Re: 4" Clock/Tach options? Reply with quote
Try looking through this...
https://www.thesamba.com/vw/forum/viewtopic.php?t=247180&highlight=clock
Nicholas
