Case Mating Surfaces
SeVVenth
SeVVenth is offline
PostPosted: Thu Sep 22, 2005 1:31 pm    Post subject: Case Mating Surfaces Reply with quote
Just wondering, but what do you guys do for the mating surfaces? Make them clean as hell and slap it together, or do you put in some liquid gasket like stuff?
vwracerdave
vwracerdave is offline
PostPosted: Thu Sep 22, 2005 2:38 pm    Post subject: Reply with quote
I use Permatex Aviation sealer on the case halves.
vicsvw
vicsvw is offline
PostPosted: Thu Sep 22, 2005 2:43 pm    Post subject: Sealer Reply with quote
Moust use Curl-2 or gasgacinch (our faverate) Just don't use silicon Seal. Gasket Sealer "Gasgicinch" http://1800vw.bizhosting.com/gasket_sealer.html
SeVVenth
SeVVenth is offline
PostPosted: Thu Sep 22, 2005 9:11 pm    Post subject: Reply with quote
What about ultimate grey?
turboblue
turboblue is offline
PostPosted: Fri Sep 23, 2005 8:26 am    Post subject: Reply with quote
If that's silicone, no.
Use Permatex Aviation sealer like Dave suggested.
That is the only thing I've ever used.
Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!"
jamestwo
jamestwo is offline
PostPosted: Fri Sep 23, 2005 10:48 am    Post subject: Reply with quote
you have to have a non harding sealant. silicon will harden and may prevent the case from seating correctly. This in turn will affect bearing crush.
Best thing is to get both case halfs clean and use a thin coat of aviation sealer. although they do make a non harding silcon sealant that you can use. I used it before , but it's real greasy and I didn't like it.
Mr. Unpopular
Mr. Unpopular is offline
PostPosted: Fri Sep 23, 2005 1:55 pm    Post subject: Reply with quote
I think that's the Permatex name for the "Hondabond" stuff. I wouldn't suggest using that stuff because once its together it just flat doesn't want to come apart. I would be afraid of braking the case when trying to split the halves.
RonR
RonR is offline
PostPosted: Fri Sep 23, 2005 7:51 pm    Post subject: case sealer Reply with quote
Ya, stay away from that "Yamabond" stuff. You dam near have to machine it off. Aviation "Form-a-Gasket" is what I use on all my cases. Never leeks.
Rome
Rome is offline
PostPosted: Sat Sep 24, 2005 9:30 am    Post subject: Reply with quote
"Moust use Curl-2..."
SeVVenth, "vics" meant Curil-2. Might not find it in a better auto supply store if you don't have it spelled right.
Also consider "Hylomar", which I've used recently with success, but I've only built about ten engines; the other fellas probably tens of dozens and can therefore observe the results of their sealants quicker than I can with mine.
