sharpstick Samba Member
Joined: July 27, 2005 Posts: 460 Location: Amarillo, TX
Posted: Tue Jun 03, 2025 12:25 pm Post subject: Gas tank question. Old vs New |
The gas tank on my 60 model is pretty rusty. I was looking at buying a new gas tank but they all seem to have holes for sending units. My 60 model tank did not have a sending unit. Do they make a block off plate to use with a newer style tank? |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26109 Location: Olympia Wash Rinse & Repeat
Posted: Tue Jun 03, 2025 12:39 pm Post subject: Re: Gas tank question. Old vs New |
A sender would fill the hole. Might post a WTB for a good used or bad sender.
Still might try Evaporust or the home brew equivalent for a lot less $$ to rescue your original tank.
https://www.youtube.com/results?search_query=Evaporust+recipe _________________ In Stereo, Where Available! |
thom Samba Member
Joined: October 12, 2000 Posts: 6207 Location: Sacramento
Posted: Tue Jun 03, 2025 1:00 pm Post subject: Re: Gas tank question. Old vs New |
After cleaning up the 3rd used tank only to find pinholes in it, I said to hell with it and bought one of the Wolfsburg West tanks, straps and blockoff kit. It's actually a decent repro - their 1st generation of repro tanks sucked. ProTip: install the blockoff before you install the tank.
_________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
Walk Thru KO Samba Member
Joined: August 14, 2003 Posts: 161 Location: North Carolina
Posted: Tue Jun 03, 2025 3:01 pm Post subject: Re: Gas tank question. Old vs New |
thom wrote: |
I like that - ProTip... made me smile |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 479 Location: Mississippi
Posted: Tue Jun 03, 2025 3:46 pm Post subject: Re: Gas tank question. Old vs New |
The Wolfsburg west repro fuel tank I purchased from them in 2021 or so had a block off plate and gasket installed where the fuel sender fits. So the option is there to update your vehicle with a sender and gauge or whatnot maybe a reserve tap but here's the deal:
IF your old fuel tank is rusty it will probably be the rustiest and most comprimised by rust at the low point where the fuel tap screws on to the outflow fitting, which is just above your starter that uses electricity and potential sparks in doing its job. You better check the integrity of the outflow fitting connection to the bottom of the tank before trying to clean the tank or whatever. You might get lucky and tightening the fitting might twist it off the bottom of the tank. Then you'll realize how much time you wasted trying to preserve a bad tank. Pro tip: just get a new good repro tank and be done with it. Cheapest insurance you can get.
Good Luck! _________________ Never argue with an Idiot. They'll only bring you down to their level and beat you with experience. |
