1960 single cab back of cab to treasure chest wall
vwbug14
vwbug14 is offline
PostPosted: Sun Jun 08, 2025 2:16 pm    Post subject: 1960 single cab back of cab to treasure chest wall Reply with quote
Hi. I can’t find pictures or a post so I thought I would post.
I’m welding in a repair panel for the single cab back wall and the treasure chest wall. While clamping and measuring I noticed that there cab floor meets up with this panel. That’s okay, but there are 3-4 cut outs that lead directly into the cab. In case I’m not explaining it well, the cab floor and back wall of the cab are welded from underneath but have oval cut holes that are not welded. Didn’t help did it lol. I want to know what it should look like ????
Mike
70bus Premium Member
70bus is offline
PostPosted: Sun Jun 08, 2025 2:47 pm    Post subject: Re: 1960 single cab back of cab to treasure chest wall Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?t=754924
Dig around; just about any part on a truck, he's taken it apart, taken pics, and showed how it went back together.
Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater
vwbug14
vwbug14 is offline
PostPosted: Sun Jun 08, 2025 6:27 pm    Post subject: Re: 1960 single cab back of cab to treasure chest wall Reply with quote
The photo might help.
Kb65single
Kb65single is offline
PostPosted: Mon Jun 09, 2025 4:12 am    Post subject: Re: 1960 single cab back of cab to treasure chest wall Reply with quote
Mike
There are 3 cutouts. One for the shifter linkage and two for the emergency brake cable tubes. Page 7 of my build thread that 70bus posted shows some of what you might find helpful. I cut holes for those pipes because I removed the pipes during the restoration. The factory provided relief because they installed the pipes before installing that panel (my best guess). That repair panel sets on top of the flange of the A-pillar top hat. Any way would be correct, the relief cuts just allow the panel passage from the top. Hope that helps.
Ken
