1970 beetle
459032 is offline
PostPosted: Tue May 27, 2025 3:07 pm    Post subject: 1970 beetle Reply with quote
Helping a friend with his beetle which we believe to be a 1970.
1) how can we make sure the year and if it’s super beetle or not.
2) block has a serial number that starts with H5. Is that a 1500?
3) noisy generator and G on dash lights up. Is the generator the same on 1500 and 1600?
4)clutch slips when releasing clutch pedal in 2nd gear. Is there an adjustment?
5) where can I get the electric choke? I broke the spade connector
6) pulls to the right when I hit the brakes. Where do I start?
Thanks in advance
1978 VW Beetle convertible w/ FI
1978 VW Bus w/ FI
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue May 27, 2025 3:26 pm    Post subject: Re: 1970 beetle Reply with quote
What's the 3rd digit of the VIN, should be a 0
Look at the spare tire, if it's flat it's a Super, if it's on an angle then it's not.
BTW, 1971 was the 1st year of the Super.
Started life as a 1500, larger 85.5 cylinder can be dropped in if it was rebuilt
They are the same
There's a wingnut on the end of the cable under the left side of the car.
Check the free classified
Bleed and adjust the shoes
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
459032
459032 is offline
PostPosted: Tue May 27, 2025 7:49 pm    Post subject: Re: 1970 beetle Reply with quote
Lots of great informations! Thank you. I think I found someone on the classified that’s pretty close to me.
Another question.
The bracket the holds the generator is loose. Is there supposed to be something between the bracket and the generator?
1978 VW Bus w/ FI
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Thu May 29, 2025 4:03 pm    Post subject: Re: 1970 beetle Reply with quote
The bracket should be around the generator stand rear side and around the generator itself and fastened with a 13mm bolt and nut. Hope this helps.
Cusser
Cusser is offline
PostPosted: Thu May 29, 2025 7:01 pm    Post subject: Re: 1970 beetle Reply with quote
The correct bracket/clamp really only goes on one correct way.
459032
459032 is offline
PostPosted: Mon Jun 09, 2025 8:30 pm    Post subject: Re: 1970 beetle Reply with quote
The generator breaker was broken and the previous owners just stuffed it between the stand and generator
The generator pulley was left loose so it was noisy and the generator light was on because the wires on the generator were flipped.
My new question is about the gasket that goes around the engine. I believe it’s called the engine gasket. It’s helps with cooling. It’s missing and the spacing between the engine and engine compartment is really uneven. Can the tins be adjusted?
1978 VW Bus w/ FI
Bobs67vwagen
PostPosted: Tue Jun 10, 2025 3:47 am    Post subject: Re: 1970 beetle Reply with quote
If it is the rubber strip which fits around the perimeter of the engine compartment you are referring to it is replaceable although not easy with the engine in the car. It is very important to keep exhaust heat out of the engine compartment. The tins are not adjustable. Good luck.
jinx758
jinx758 is offline
PostPosted: Tue Jun 10, 2025 4:24 pm    Post subject: Re: 1970 beetle Reply with quote
Back around 2019 I had to drop my engine. I replaced the engine bay gasket & had to spend a few straightening the channel it slides into. Some people claim to use a lubricant to help install. I left the channel slightly loose & hammered it closed with a hard rubber hammer.
Also there's a gasket for a bus that others say seals well & is an easy install.
Top of clutch pedal should move almost an inch before resistance is felt. I used my hand for precision.
Is generator polarized, belt adjusted, & all contacts shiny - including transaxle strap ?
Maybe solder that tab back on ?
I go for function - doesn't have to be pretty.
Good luck ... stay safe
jinx
" It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference ...
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor
