74 Ghia Samba Member
Posted: Wed Jun 04, 2025 11:49 am Post subject: Engine Valve Adjustment |
Hi,
74 Ghia, stock 1600. My regular mechanic just retired, had been going to him for over 30 years. Just went to a new guy for an oil change and a valve adjustment. Quoted me $534 for a valve adjustment. As I was paying $50-$75, I declined. Any idea of the $ range I should expect? |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79441 Location: Sneaking up behind you
Posted: Wed Jun 04, 2025 12:18 pm Post subject: Re: Engine Valve Adjustment |
No more than an hour, assuming they're really slow. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
rg65 Samba Member
Joined: January 24, 2025 Posts: 5 Location: New Mexico
Posted: Wed Jun 04, 2025 12:22 pm Post subject: Re: Engine Valve Adjustment |
Don't know what the book rate is to set valves but would think 1 to 1.5 hours times the labor rate and parts (gasket set) would be a close estimate. $500.00 seems high. |
Era Vulgaris Samba Member
Joined: August 22, 2012 Posts: 1915 Location: Raleigh, NC
Posted: Wed Jun 04, 2025 2:50 pm Post subject: Re: Engine Valve Adjustment |
rg65 wrote: |
1 to 1.5 hours |
I could do it in 90 minutes if I drink a beer between each cylinder. Seriously though, it's not a difficult job and shouldn't take more then 20-30 minutes once you've done it a couple times and have the hang of it. $500+ is highway robbery. _________________ Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6094 Location: 37.5N 77.1W
Posted: Wed Jun 04, 2025 6:28 pm Post subject: Re: Engine Valve Adjustment |
Quote: |
Quoted me $534 for a valve adjustment |
He did that to scare you away...it worked  _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
Glenn  Mr. 010
Posted: Wed Jun 04, 2025 6:57 pm Post subject: Re: Engine Valve Adjustment |
runamoc wrote: |
He did that to scare you away...it worked  |
I like this. _________________ Glenn
Member #1009
#BlueSquare
Rome Samba Member
Joined: June 02, 2004 Posts: 10524 Location: Pearl River, NY
Posted: Mon Jun 09, 2025 3:47 pm Post subject: Re: Engine Valve Adjustment |
Valve lash needs to be done with the engine "stone cold", meaning probably leaving it overnight if you drive it to the shop so that the work is done in the morning with the car pushed into the shop. There should not be any cost involved to leave the car, since the mechanic is not actually working on it/spending time on it while its parked.
I agree that a practiced aircooled VW mechanic should EASILY do the actual adjustment work in 1/2 hr. Add 15 minutes to lift up and lower the car,, clean off spilled oil from the valve covers off the heater boxes, remove the prior gaskets from the valve covers and install new ones...
Did the new mechanic imply but not specifically mention doing some related work at same time while the car is in the air, such as replace the trans fluid, lube the front beam, check the rear brakes' adjustment and handbrake adjustment, check functionality of the heater cables, maybe even bleed the brakes? That $500+ is exceptionally high. |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2755 Location: Santa Cruz, CA
Posted: Tue Jun 10, 2025 11:46 am Post subject: Re: Engine Valve Adjustment |
74 Ghia wrote: |
Quoted me $534 for a valve adjustment. |
Find a new mechanic... _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7470 Location: Houston, Texas
Posted: Tue Jun 10, 2025 4:11 pm Post subject: Re: Engine Valve Adjustment |
Where are you located? _________________ www.vwnos.com [email protected]
Posted: Wed Jun 11, 2025 6:50 am Post subject: Re: Engine Valve Adjustment |
I am located in Southeastern Wisconsin. |
heimlich  VWNOS.com
Posted: Wed Jun 11, 2025 7:22 am Post subject: Re: Engine Valve Adjustment |
74 Ghia wrote: |
There's lots of people there with VWs. Maybe you could post a thread asking for recommendations for a new mechanic.
I have customers there. If you send me an email I can ask them as well. _________________ www.vwnos.com [email protected]
paul_round Samba Member
Posted: Wed Jun 11, 2025 9:09 am Post subject: Re: Engine Valve Adjustment |
Why not do it yourself, It's super easy. |
Glenn  Mr. 010
Posted: Wed Jun 11, 2025 9:23 am Post subject: Re: Engine Valve Adjustment |
paul_round wrote: |
This _________________ Glenn
Member #1009
#BlueSquare
wagen19 Samba Member
Joined: November 16, 2007 Posts: 655 Location: germany
Posted: Wed Jun 11, 2025 11:32 pm Post subject: Re: Engine Valve Adjustment |
Glenn wrote: |
paul_round wrote: |
This |
It seems, he has not done a valve adjustment since owning the car.
It sounds like he could benefit from a Mentor.
Found the following text here on Samba:
If you do not already have a copy, Buy an Idiot's Guide. It will put you in the right mindset to be one with your car.
eg:
https://www.amazon.ca/Keep-Volkswagen-Alive-Step-S...d_source=1 |
Posted: Thu Jun 12, 2025 6:23 am Post subject: Re: Engine Valve Adjustment |
paul_round wrote: |
'Garage' of YouTube has 2 'How to' videos...
https://www.youtube.com/results?search_query=adjusting+volkswagen+valves _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Posted: Thu Jun 12, 2025 2:50 pm Post subject: Re: Engine Valve Adjustment |
Imo it seems, the car possibly rather needs not only a valve adjustment, but rather more a "full service" tune up according to original VW maintenance scedule.
For that kind of service, more time as only one hour is needed and also some material.
Is there a book of documented services for that car?
(it seems, the owner never has really worked on his car, but I can be wrong)
When, how many miles or years ago was the last prophylaxis "full inspection" and how old are all the fluids, tires, spark plugs, brake linings etc. now?
I can´t believe, a really complete "full service", properly done, incl. all material could be done for only around 75 $ nowadays in "Good Old USA".
It´s not about cleaning and looking only.
Suggest to have a look on original VW service plans and ask at official VW dealer and any other mechanic, what a service only (without any repairs) would cost and compare. |
