57 Kab Reconstruction/Restoration
WrennMetallWerks
WrennMetallWerks is offline
PostPosted: Thu May 15, 2025 6:20 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
βš’ Believe In The Power Of Positive Thinking βš’
Purpose Over Pleasure πŸ•Š
β€œHard Werk βš’ God First β€œ
WrennMetallWerks
PostPosted: Thu May 15, 2025 6:26 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
TRS63
TRS63 is offline
PostPosted: Fri May 16, 2025 2:35 am    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
This car really had ugly corners but you are making an amazing start on it !
Antoine
Antoine
My 62 ragtop daily driver:
My 52 Standard Zwitter :
Ian Godfrey
Ian Godfrey is offline
PostPosted: Fri May 16, 2025 3:43 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
Wonderful work to watch Smile
I was wondering what is the red primer you use and is it a 'weld through'. kind of primer?
Keep up the great work
WrennMetallWerks
PostPosted: Fri May 16, 2025 4:42 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
^^^ Hey There. Yes it is. Works very well.
WrennMetallWerks
PostPosted: Fri May 16, 2025 4:43 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
WrennMetallWerks
PostPosted: Fri May 16, 2025 4:45 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
WrennMetallWerks
PostPosted: Fri May 16, 2025 8:32 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
WrennMetallWerks
PostPosted: Fri May 16, 2025 8:36 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
Pull Max Werk
Working out the correct profile.
WrennMetallWerks
PostPosted: Sat May 17, 2025 10:16 am    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
Antoine
Thanks Brother. I appreciate that.
WrennMetallWerks
PostPosted: Sat May 17, 2025 10:30 am    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
The Layout Table doesn’t lie.
Only 0.1 degree difference front to back.
It will stay pinned down like this while we weld the cap on , when we flip it over to do the pan halves we will pin it down again while welding them in.
WrennMetallWerks
PostPosted: Sat May 17, 2025 10:28 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
DaveB9
DaveB9 is offline
PostPosted: Sun May 18, 2025 12:14 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
There were some horrors lurking in there for sure. Great to see the progress, it all looks fantastic as usual.
WrennMetallWerks
PostPosted: Thu May 22, 2025 7:01 am    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
^^^ Hey Dave^^^
Thanks for following along….
Cool
WrennMetallWerks
PostPosted: Tue Jun 03, 2025 7:55 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
Rebuilding with Washburns pins
WrennMetallWerks
PostPosted: Tue Jun 03, 2025 10:54 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
Building multiple Ghia’s at one time I got to stay
WrennMetallWerks
PostPosted: Wed Jun 04, 2025 7:14 am    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
So what I discovered when I first stared rebuilding hinges whether it be bug , bus , or ghia is that 9 times out of 10 just doing the pin is not enough. The slop between the male and female counterparts almost always needs to be built back up and taken back down again to make a tight fit. I use this copper rod when welding so that the center stays nice and circular.
I do not have a mill but have found doing this by hand with the micrometer is very achievable. When it’s all said and done the two halves are very snug.
WrennMetallWerks
PostPosted: Thu Jun 05, 2025 1:36 am    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
Time to hang the doors again and see how the look and fell after the hinges being sorted out.
We will also be leaving them on as we install the adjacent panels so we can make the appropriate gaps as we go.
They look and feel great so we are off to a good start.
Loren Premium Member
Loren is offline
PostPosted: Thu Jun 05, 2025 9:00 am    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
Looking great!
TRS63
TRS63 is offline
PostPosted: Wed Jun 11, 2025 10:30 pm    Post subject: Re: 57 Kab Reconstruction/Restoration Reply with quote
Fantastic work as always !
Antoine
Antoine
Page 5 of 6
