Broken Syncro Front Transmission Mount Ear
caseyl
caseyl is offline
PostPosted: Mon Jun 09, 2025 9:45 am    Post subject: Broken Syncro Front Transmission Mount Ear Reply with quote
Hey Samba,
It looks like I broke this ear on my syncro transmission. Has anyone had any success welding this cast mount?
I could probably get creative and made a specifically shaped washer instead of welding.
Is the standard procedure to disassemble the case prior to welding?
I have a tig welder and would probably do it myself. Does anyone know what rod works best?
I believe the case is a later model (1990-1991 or so) aluminum one.
Thanks in advance everyone. I was pretty bummed out when I saw this.
Sodo
Sodo is offline
PostPosted: Mon Jun 09, 2025 10:14 am    Post subject: Re: Broken Syncro Front Transmission Mount Ear Reply with quote
All low-gear housings are aluminum and its a weldable aluminum.
It's a HUGE job to weld that.
You don't have to disassemble the trans.
But the trans has to come out.
The Low gear housing is NLA.
I hope you kept the broken piece, can weld it back on at trans rebuild ( or 3rd/4th hub replacement ! ) time
This mount is a simple function, but it requires BOTH ears.
It not only supports the trans - it resists output torque (to the front-prop-shaft).
I would fab a rectangular steel "washer" that nestles into the recess, just bridging over, with a 'leg' tacked on to make up for the missing aluminum ear (if that makes sense).
Maybe with Permatex Ultra-gray sealing between the steel and the aluminum.
If you have an aluminum-welder-guy, it could be made from aluminum.
....KTMs, GasGas, SPOT mtb
crazyvwvanman
crazyvwvanman is offline
PostPosted: Mon Jun 09, 2025 10:29 am    Post subject: Re: Broken Syncro Front Transmission Mount Ear Reply with quote
I've had a broken and missing ear welded back before.
My tranny guy had a donor ear to have welded on.
Those low gear housings can get badly cracked in the bearing area so then a bad one can become an ear donor for another.
The tranny was taken out of the van but wasn't opened up when mine was welded.
Mark
MsTaboo Premium Member
MsTaboo is offline
PostPosted: Mon Jun 09, 2025 2:34 pm    Post subject: Re: Broken Syncro Front Transmission Mount Ear Reply with quote
https://www.germantransaxle.com/product/pioneer-machine-werks-low-gear-housing/
Currently:
All that's needed for evil to prevail is for good people to do nothing.
4Gears4Tires
4Gears4Tires is offline
PostPosted: Mon Jun 09, 2025 9:06 pm    Post subject: Re: Broken Syncro Front Transmission Mount Ear Reply with quote
Well that's not cheap at all.
I'd try to get some angle iron, flat iron, or bar stock and make some sort of sleeve to go over the arm.
dhaavers
dhaavers is offline
PostPosted: Tue Jun 10, 2025 6:22 pm    Post subject: Re: Broken Syncro Front Transmission Mount Ear Reply with quote
4Gears4Tires wrote:
Well that's not cheap at all…
Hence: $$$yncro…
Good luck, I’ll be over in the 1WD/cheap & slow lane… Embarassed
Wink
- Dave
"The WonderVan"
zerotofifty
zerotofifty is offline
PostPosted: Tue Jun 10, 2025 10:14 pm    Post subject: Re: Broken Syncro Front Transmission Mount Ear Reply with quote
dhaavers wrote:
Hence: $$$yncro…
Wink
- Dave
That is one reason I bought a Jeep for off roading. Less coin and more capable.
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
markswagen
markswagen is offline
PostPosted: Tue Jun 10, 2025 10:26 pm    Post subject: Re: Broken Syncro Front Transmission Mount Ear Reply with quote
that's as maybe, but when you are on hells revenge and a bunch of razor side by side drivers get upset because the were taken out on an ''extreme trail'' because there are fucking volkswagens everywhere.
no sir, you can keep your jeep, the engine is in the wrong place anyway.
FWIW, my syncro transmission has had both support tabs welded back on, no idea the story behind it, it was long before my caretakership.
619 201 0310
Sodo
Sodo is offline
PostPosted: Wed Jun 11, 2025 7:47 am    Post subject: Re: Broken Syncro Front Transmission Mount Ear Reply with quote
syncro is expensive.
But you can't wake up in a jeep
    in a beautiful, almost inaccessible campsite,
    sit up,
    open the stove
    make coffee
One was broken somehow.
Then they drove it with only one ear and propshaft torque twisted the other ear off?
zerotofifty
PostPosted: Wed Jun 11, 2025 5:54 pm    Post subject: Re: Broken Syncro Front Transmission Mount Ear Reply with quote
    sit up,
    open the stove
    make coffee
Actually I can wake up in my jeep, I have a bed in it, and I can wake up open up the stove and make tea (I am a tea guy, not a coffee guy) The Jeep will take me places the vanagon cannot go.
I still have the Vanagon and it does remarkably well off road, but no way can it do the trails my Jeep can. I like the remoteness of where the Jeep can take me, as I am an anti social kind of guy Rolling Eyes
My Jeep is very affordable verses a syncro too.
Both are good vehicles, with some aspects being better on one verses the other.
Words to live by.
zerotofifty
PostPosted: Wed Jun 11, 2025 5:59 pm    Post subject: Re: Broken Syncro Front Transmission Mount Ear Reply with quote
When you get stuck on a trail, I will be happy to pull you out with my
old Jeep as in general I like to help folks, specially old VW folks.
And yes it is less costly than a syncro. My Jeep is considered some what mild in the off road world, yet is more capable on the trails by far than any Vanagon I have ever seen.
Words to live by.
Sodo
Sodo is offline
PostPosted: Wed Jun 11, 2025 6:12 pm    Post subject: Re: Broken Syncro Front Transmission Mount Ear Reply with quote
OK then, UNCLE !
Bet you can't sleep or make tea in a Razor.
MarkWard
MarkWard is offline
PostPosted: Thu Jun 12, 2025 10:27 am    Post subject: Re: Broken Syncro Front Transmission Mount Ear Reply with quote
OP, I might have a cracked case I would sell on as a donor. PM me if you need to go that route. I’ll wait to hear before digging it out.
WiboBusMan
WiboBusMan is offline
PostPosted: Thu Jun 12, 2025 5:32 pm    Post subject: Re: Broken Syncro Front Transmission Mount Ear Reply with quote
If you can, welding would be the preferred fix, but...
If you still have the ear, a top quality structural epoxy, with impeccable surface prep, reinforced with a steel pin or two, and fiberglass mat, or better, carbon fibre, will fix this very solidly.
W
Science has sacrificed Truth on the altar of its narrative.
?Waldo?
?Waldo? is offline
PostPosted: Thu Jun 12, 2025 6:53 pm    Post subject: Re: Broken Syncro Front Transmission Mount Ear Reply with quote
Considering that he has a TIG and apparently the ability to use it, that seems to me to be the way to go, and other options seem much less desirable. I have a TIG welder, and if it were mine, I wouldn't even consider the other options that have been mentioned.
caseyl
caseyl is offline
PostPosted: Tue Jun 17, 2025 5:04 pm    Post subject: Re: Broken Syncro Front Transmission Mount Ear Reply with quote
Thanks for all of the replies everyone. Hopefully soon I can drop this transmission and get a better look at the damage.
I will be sure to update the thread with the fix.
zerotofifty
PostPosted: Tue Jun 17, 2025 5:45 pm    Post subject: Re: Broken Syncro Front Transmission Mount Ear Reply with quote
If you be welding the repair, consider adding some more metal so in as to beef it up better than stock, perhaps likewise on any other ear. Evidently other folks have these break so it is a design weakness.
If you do all the prep work, adding some more reinforcement should be little extra effort.
Anyhows, that be what I be thinking of doing. Dont let this happen again.
good luck, keep us informed on your fix.
Words to live by.
Phishman068
Phishman068 is offline
PostPosted: Wed Jun 18, 2025 4:27 pm    Post subject: Re: Broken Syncro Front Transmission Mount Ear Reply with quote
I haven't welded an ear on a syncro transmission- but I do teach welding, and have disassembled some transmissions. I definitely think you could weld it on without disassembling the entire transmission/getting it rebuilt. Just gota get it clean, get a little heat in there, work it fast with lots of amps, then cool it down before the heat can move to much- but even then..... transmission cases move heat around, that's what they do, I wouldn't personally worry about warping anything.
http://www.thesamba.com/vw/forum/viewtopic.php?t=559766&highlight=winter+rust
http://www.thesamba.com/vw/forum/viewtopic.php?t=482402&highlight=sunroof+syncro
http://www.thesamba.com/vw/forum/viewtopic.php?t=569774
http://www.thesamba.com/vw/forum/viewtopic.php?p=6864936#6864936
"Along with the ability to go fast, one looses the desire to hurry."
