Murt Samba Member
Joined: October 01, 2017 Posts: 555 Location: Kent, England
Posted: Wed Jun 18, 2025 7:11 am Post subject: Replacement Seals for Cargo Doors |
Hi chaps
Looking for some advice.
I have started to look at the Cargo Door seals. I am pretty sure that the top seal hasn’t been changed since 1966 and there is no seal in the bottom.
I have just removed it and it is absolutely gone. I’m interested in confirming my belief that this seal is the original one, and also interested in the shape of this seal compared to what is available today ? I’m going to buy the 9 Piece replacement set, and wondering what you guys use ? Are the top and bottom seals a different profile to the doors ?
Cheers
A few photos
_________________ 1966 VW Beetle ‘Jules’
1967 Kombi Splitscreen ‘Barney’
2018 VW Caddy Maxi R Line
2017 Golf GTD saloon
2008 VW EOS 2.0 TFSi |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25988 Location: Olympia Wash Rinse & Repeat
Posted: Wed Jun 18, 2025 10:34 am Post subject: Re: Replacement Seals for Cargo Doors |
We like that!!!! the center top where the doors meet is always a possible drip leak area if the bus is tilted at all to the driver side.
Everything we know of today is sold with a rectangle cross section for all the cargo door seal pieces.
Just checked a MAR62 SO-34 we have that still has the original door deals and they are just the rectangle cross section seal. Wonder if what you have is a later improvement or was a test market for wetter climes try at a new improved seal..... Maybe check the "Progressive Refinements" to check for the former.
Looking forward to any additional info! _________________ In Stereo, Where Available! |
Murt Samba Member
Posted: Wed Jun 18, 2025 10:37 am Post subject: Re: Replacement Seals for Cargo Doors |
I’m going to dig around
Did you notice the piece of string that runs through it as well ? Very strange  _________________ 1966 VW Beetle ‘Jules’
Posted: Wed Jun 18, 2025 10:44 am Post subject: Re: Replacement Seals for Cargo Doors |
Murt wrote: |
Did you notice the piece of string that runs through it as well ? Very strange  |
Think the string was used as a metering device, to keep the rubber seal much more uniform shape and dimensions as it was being extruded around the string. _________________ In Stereo, Where Available! |
von_hansel  Samba Member
Joined: June 12, 2006 Posts: 815 Location: Inland Empire
Posted: Wed Jun 18, 2025 11:00 am Post subject: Re: Replacement Seals for Cargo Doors |
The top and lower seal are originally notched at the boxes where the cargo door rods go into the body. All of the aftermarket seals need to be cut / notched.
There is a thread titled WW WCM Front/ Cargo Door Gray Weatherstrip Rubber where Mark Rafferty aka Beaterbarndoor suggest procuring the cargo door seals from a company in the UK. If I were to buy the cargo door seals again, I would buy them from the company Mark recommends. When Mark speaks, I listen
I have the WW ones installed on my bus and they are dog poop. They are super thick and you have to cut the backs of them to make them work. I have already destroyed an NOS cargo door mechanism due to the WW being too thick and this was after spending hours cutting the backs of the seals to make the cargo doors shut nicely. _________________
Mugatu wrote: |
von_hansel is still so hot right now |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 473 Location: Mississippi
Posted: Wed Jun 18, 2025 1:04 pm Post subject: Re: Replacement Seals for Cargo Doors |
The "no reason to believe they aren't the original cargo door seals" I removed from my 66 gave off a hard "skunk" smell when I removed them and scraped out the glue residue that held them in. Like others, the WCM seals I replaced them with were the grey rectangle shaped stuff. I used a Dremel tool with a sanding drum bit to remove material on the backside where needed at the door hinges etc. I've never seen seals with the cross section as yours. _________________ Never argue with an Idiot. They'll only bring you down to their level and beat you with experience. |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15249 Location: Casa de Oro, California
Posted: Wed Jun 18, 2025 6:32 pm Post subject: Re: Replacement Seals for Cargo Doors |
Murt wrote: |
I’m interested in confirming my belief that this seal is the original one |
Original. It is a type of foam that expands but the area that forms against the mold hardens to become the outer crust. |
