WrennMetallWerks Samba Member
Joined: December 06, 2007 Posts: 3367 Location: Rescue ca
Posted: Fri Jun 20, 2025 9:40 am Post subject: Oval Kab Resurrection Project |
Hey Folks…..
Starting this mid week we are diving into this Oval Kab…
It is in my rotations starting out at a slower pace than usual but I will be updating as we progress. Thought I would start out with some shots post blaster and sealer powder coat primer. We haven’t done an early beetle in a while so I’m really looking forward to this one.
_________________ ⚒ Believe In The Power Of Positive Thinking ⚒
Purpose Over Pleasure 🕊
“Hard Werk ⚒ God First “
Last edited by WrennMetallWerks on Fri Jun 20, 2025 3:20 pm; edited 2 times in total |
Loren  Samba Member
Posted: Fri Jun 20, 2025 12:33 pm Post subject: Re: Oval Kab Resurrection Project |
Almost as bad as the Ghia cabriolet you did for me. Can't wait to see this go back together. |
Posted: Fri Jun 20, 2025 1:15 pm Post subject: Re: Oval Kab Resurrection Project |
Hey Mr Loren…. That was a fantastic time doing that with you. I can’t thank you enough for making it such an enjoyable journey.
https://www.thesamba.com/vw/forum/viewtopic.php?t=403985
This Kab definitely needs some serious love but I’m confident we will get it all sorted out. One major challenge is the driver side A Pilar. It will most likely need to be removed/replaced with a donor before the Wolf parts full front quarter can go on.
I got the Beetle Body Jig out of hibernation and put a fresh coat of paint on it. I have the body sitting in it as we speak to save footprints in the shop but once get going I will need to take it back out to finish the demo on the support rails. Once that is done is should fit nice and snug in the Jig so we can start attaching panels. This fixture makes things very nice for us. This will be a blast.
“Hard Werk ⚒ God First “ |
obus  Samba Member
Joined: March 08, 2001 Posts: 11644 Location: just off Garden State Parkway Exit 81
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11188 Location: Huntington Beach, CA
Posted: Fri Jun 20, 2025 5:56 pm Post subject: Re: Oval Kab Resurrection Project |
This ought to be a good thread to follow! Love seeing your work! From what I can see, it looks like it might be in okay shape?.? I am sure you will illuminate the areas in need of attention! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
sunroof Samba Member
Joined: October 06, 2006 Posts: 2032 Location: Winnipeg
Posted: Sat Jun 21, 2025 9:20 am Post subject: Re: Oval Kab Resurrection Project |
So glad you guys are posting this. It will be a fun build to watch.
Don _________________ Better and better mistakes! |
Posted: Sat Jun 21, 2025 11:42 am Post subject: Re: Oval Kab Resurrection Project |
Loving it Folks. Thanks for following along.
Here is the current situation.
As of the last couple years I have been focusing on doing the doors on a project first. Once the damage is repaired and the hinges rebuilt I can then hang them on the car and use them in a “Perimeter Layout Process “ this allows me to properly layout the adjacent panels based off their location. This is especially helpful/ necessary with a convertible body.
Posted: Sun Jun 22, 2025 12:37 pm Post subject: Re: Oval Kab Resurrection Project |
With this resurrection I would consider it the majority of damage and less about rust repair.
The Kar most likely has spent a lot of time inside and or covered. The rust is minimal which is not common with the convertibles.
The driver side rear quarter has been replaced at one point in its life but very poorly executed. The good thing is that the donor panel is a good candidate to be reworked to remain a viable replacement.
As I mentioned before the driver side A pillar is most likely going to replaced and the Fixture will help tremendously with this task. One unusual thing to note is the heavy amount of lead used on the A pillar past repair, that typically means these repairs plate very old…. Probably in the 60’s or 70’s
Here are some shots of the must troubled areas.
Posted: Wed Jun 25, 2025 10:15 am Post subject: Re: Oval Kab Resurrection Project |
Diving into the removables.
Staring on the decklid with Ox Handheld Air Hammer
This tool is fantastic far metal shaping.
Posted: Wed Jun 25, 2025 4:48 pm Post subject: Re: Oval Kab Resurrection Project |
Posted: Wed Jun 25, 2025 9:25 pm Post subject: Re: Oval Kab Resurrection Project |
Nice work! It would be so cool to see this happen! Thanks for sharing what you do! _________________ Jimbo
TDCTDI wrote: |
Posted: Thu Jun 26, 2025 3:52 pm Post subject: Re: Oval Kab Resurrection Project |
ronjonlasvegas Samba Member
Joined: October 08, 2004 Posts: 946 Location: Las Vegas, NV
Posted: Fri Jun 27, 2025 11:26 am Post subject: Re: Oval Kab Resurrection Project |
WrennMetallWerks wrote: |
[img]
Hopefully the 1958+ four tab hood will be updated to a period correct one. I had that same style front hood for my 1957 convertible and had my metal guy drilled out the spot welds for the inner support structure and replaced it with the correct year one. I found a donor hood that had been cut in half back in the day to make a Baja hood. My metal guy was able to take the inner support structure out of that donor one and weld it to my 1958-1959 hood so now it looks correct when the hood is open. _________________ September 1964 Standard Sunroof walk through SWR/BG original paint. |
Posted: Fri Jun 27, 2025 11:36 am Post subject: Re: Oval Kab Resurrection Project |
Hey there. I agree with you. We should make it as correct as possible. I have been out of the shop for 3 weeks and will return in 2 more. In the mean time I will try to track down a good donor for the inner structure. In fact I will see about chasing down another hood entirely. Stay tuned. _________________ ⚒ Believe In The Power Of Positive Thinking ⚒
Posted: Fri Jun 27, 2025 1:34 pm Post subject: Re: Oval Kab Resurrection Project |
Hey there. I agree with you. We should make it as correct as possible. I have been out of the shop for 3 weeks and will return in 2 more. In the mean time I will try to track down a good donor for the inner structure. In fact I will see about chasing down another hood entirely. Stay tuned. |
There is one for sale in Nine Mile Falls, WA on Facebook marketplace right now for a really good price if you have a way to get it shipped. I guess you could buy it and ask the seller to cut out the inner support sections to make it less expensive to ship,
https://www.facebook.com/share/p/18QFajqLrr/?mibextid=wwXIfr _________________ September 1964 Standard Sunroof walk through SWR/BG original paint. |
Posted: Wed Jul 02, 2025 4:01 pm Post subject: Re: Oval Kab Resurrection Project |
Posted: Thu Jul 03, 2025 7:18 am Post subject: Re: Oval Kab Resurrection Project |
Ordered up the correct hinge pins.
splitjunkie Samba Member
Posted: Thu Jul 03, 2025 2:10 pm Post subject: Re: Oval Kab Resurrection Project |
Nice.
That hand air hammer is pretty neat. The silver part is a palm air nailer for driving nails in close quarters. Looks like a nice adaptation.
[url][/url] _________________ Chris
Posted: Thu Jul 03, 2025 2:21 pm Post subject: Re: Oval Kab Resurrection Project |
YeSir!!!
For years now’ folks have been rocking the palm nailer with homemade dies. I never got around to trying it. I always had my I on the Eckold
hand held hammer that was designed/ purpose built for metal shaping but it was always out of my price range. When I first came across the Ox hammer I admit I was a bit sceptic so didn’t give it much thought. Then I started seeing folks giving excellent feedback and I decided to take a chance. It’s fantastic… I was really Impressed.
I would say it’s been about 15 years or more since I first saw the nailer being used but instead of trying it I just used the same concept of custom handmade dies but just used the good old air hammer. It served me well… in fact I still have applications to use it, like flow forming and such. You can never have to many useful tools _________________ ⚒ Believe In The Power Of Positive Thinking ⚒
Last edited by WrennMetallWerks on Thu Jul 03, 2025 6:30 pm; edited 1 time in total |
Posted: Thu Jul 03, 2025 2:27 pm Post subject: Re: Oval Kab Resurrection Project |
Here it is …. You can see from the price why I never pulled the trigger on it. Haha
