70bus Samba Member
Posted: Mon Jun 23, 2025 6:59 pm Post subject: Re: Turn signal flasher relay images and part numbers |
SWF BGC 200532
6v 2x18W
_________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater |
70bus Samba Member
Posted: Mon Jun 23, 2025 7:03 pm Post subject: Re: Turn signal flasher relay images and part numbers |
SWF BGD
Multiple versions; see box for volts and watts of permutations
this appears to be BGD0, 12v 3x15W
70 Neunsitzer
65 Pritschenwagen
70bus Samba Member
Posted: Mon Jun 23, 2025 7:08 pm Post subject: Re: Turn signal flasher relay images and part numbers |
Tung-Sol 268
6v
70 Neunsitzer
65 Pritschenwagen
70bus Samba Member
Posted: Mon Jun 23, 2025 7:12 pm Post subject: Re: Turn signal flasher relay images and part numbers |
Wagner 559
Tung-Sol 559
12v
Tung-Sol in Wagner box. One version has paper disk with newer terminal ID _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
70bus Samba Member
Posted: Mon Jun 23, 2025 7:17 pm Post subject: Re: Turn signal flasher relay images and part numbers |
Webasto WBST29-2/18
6v 2x18W
70 Neunsitzer
65 Pritschenwagen
70bus Samba Member
Posted: Mon Jun 23, 2025 8:07 pm Post subject: Re: Turn signal flasher relay images and part numbers |
211953215a
12v 3 terminals; ground through screw or extra ground wire
SWF BGE 200722
70 Neunsitzer
65 Pritschenwagen
70bus Samba Member
Posted: Mon Jun 23, 2025 8:10 pm Post subject: Re: Turn signal flasher relay images and part numbers |
211953215c
12v
Bosch 0336401004
Hella 96M1J2(4)x21W
Stribel SKF 675
Hella may be USA, Stribel Europe
70 Neunsitzer
65 Pritschenwagen
