Broke67beetle Samba Member
Joined: March 01, 2025 Posts: 105 Location: Pennsylvania
Posted: Mon Jun 23, 2025 4:04 am Post subject: 67 beetle new alternator keeps killing my battery |
So I had the car running no problem it had generator and regulator that I had installed
My wires in the engine bay were heat rotted and the chrome heat shield was pinching them
I was concerned that I wouldn't be able to work on the wiring without breaking it. So i figured the mechanic I have been using would be a better option, just to neaten things up and put a grommet through the metal heat shield
I get the car back
he fix the horn, put a new turn signal relay and neated up the wires, it actually looks really nice. And probably some other things. I'm not really sure he kind of had his hands in everything.
Driving at home seems decent. Stop to buy my work and the generator light stayed on when I turn off the key. Turn on the key, only the oil pressure light so by the time I went a it to get some tools.
( I work at an auto parts store)
The generator is smoking i pulled the wires off the generator. I think the light was even still on so I pulled the battery terminals.
Call the guy, he picks up the car. Said that I should put an alternator in there that it'll fix my problem.
I'm not really sure what all has been done to the car, so I figure why not put the alternator in but now the battery just keeps dying. He says the battery is bad. Battery tests good.
So I guess my question is, where do I even start
Something is drawing power with the car off
I know nothing is supposed to work with key off except the headlights
The horn will work with the key off would that be enough to kill the battery?
I did install a cigarette lighter but I don't think that gets constant power.
He did say there was a parasitic draw of like, point something
i do believe beetles are supposed to have.No parasitic draw
I do believe if I take it back. There he's just going to put a brand new wiring harness in the entire car. I'm not really excited how about doing that?
I'm thinking about just asking him what system had the parasitic draw
I don't really know how a parasitic draw. Test works.
Would he know which system was drawing power? Or is it just like a general test ?
Thinking about adding a battery shut off there were a couple different options. I was looking at online. One of them has like a key fob any recommendations? |
slayer61 Samba Member
Posted: Mon Jun 23, 2025 4:47 am Post subject: Re: 67 beetle new alternator keeps killing my battery |
Parasitic draw test is easy. Break the + connection at the battery, put your ammeter across the battery stud and the clamp and the cable. If you have current flow, you have a parasitic draw. If you do, go to the Fuse box and redo the test on each fuse location looking for the draw. Good luck! _________________
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes?  |
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
MSD Box and distributor
1 5/8 merged collector w/ hater stinger |
zerotofifty Samba Member
Posted: Mon Jun 23, 2025 6:01 am Post subject: Re: 67 beetle new alternator keeps killing my battery |
The mechanic is defective. He created a problem, smoked your generator, installs an alternator, now he is blaming your battery which you say tests good, now a new wire harness is what he wants? As long as he has his hands on it, it will be a money pit. _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
Posted: Mon Jun 23, 2025 9:05 am Post subject: Re: 67 beetle new alternator keeps killing my battery |
If that's the case, what do you recommend?
I honestly think it might be beyond my understanding at this point.
I do have some pictures of original wiring up front.
And in the rear
Could potentially try to remove everything, put it back
And start from scratch, but I'm pretty sure the generator's fried.
I'm not even sure I got the. Regulator back, but that was toast inside. It was all melted.
It's really hard when you have something. Somebody's messed with to know what it is. They actually did.
I do know beetle wiring is fairly simple, but most of my wires were painted purple, so yeah, it will literally be a shot in the dark. |
wagen19 Samba Member
Joined: November 16, 2007 Posts: 673 Location: germany
Posted: Mon Jun 23, 2025 9:31 am Post subject: Re: 67 beetle new alternator keeps killing my battery |
Broke67beetle wrote: |
And in the rear
It sounds like you could benefit from a Mentor (book)
Found the following text here on Samba:
If you do not already have a copy, Buy an Idiot's Guide. It will put you in the right mindset to be one with your car.
eg:
https://www.amazon.ca/Keep-Volkswagen-Alive-Step-S...d_source=1 |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Mon Jun 23, 2025 11:28 am Post subject: Re: 67 beetle new alternator keeps killing my battery |
The generator light staying on with the ignition switched off indicates that the voltage regulator cut in contacts stuck closed. When this happens the battery will try to spin the generator as if it were an electric motor, which will create quite a bit of heat and can burn up the generator if left as is for anything more than a brief period of time as you found out.
That said, there is no way to say with any certainty whatsoever that the failure was the fault of the mechanic. Looking at the picture in your gallery of the new regulator that was installed shows that it appears to be a new aftermarket unit, and sadly most of these tend to be quite poor quality from the get go. Crappy aftermarket parts is by far the most likely explanation for what happened.
Fast forward to your new alternator and its apparent power off draw killing your battery. I'd bet dollars to donuts that your new alternator is also a cheap aftermarket unit of very dubious quality, and that one of the diodes is garbage which will lead to the battery getting drained when parked. Crappy parts strike again.
Maybe it is time to find a different mechanic, but then again, what if this is the best one you'll find in your area? Human nature has a tendency to make people immediately jump to the conclusion they're being screwed over or want to place blame for events that are likely just happenstance.
Before jumping directly into panic mode and throwing parts, time, and money at the issue, I'd recommend for now just disconnect the ground cable from the battery while the car is parked and focus on learning how the electrical systems on your car work. With added knowledge you'll be in a better position to decide what's the best way forward to fix the issue or it'll give you the confidence to fix it yourself. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Mon Jun 23, 2025 3:09 pm Post subject: Re: 67 beetle new alternator keeps killing my battery |
mukluk wrote: |
Before jumping directly into panic mode and throwing parts, time, and money at the issue, I'd recommend for now just disconnect the ground cable from the battery while the car is parked and focus on learning how the electrical systems on your car work. With added knowledge you'll be in a better position to decide what's the best way forward to fix the issue or it'll give you the confidence to fix it yourself. |
I don't know whatever the mechanic picked its a bosch
Honestly, I think he went with this one because you didn't have to change the fuel pump. Which I was super adamant, about not wanting to change
The wiring does look really good compared to previous
The video on jbug's website shows it wired a little differently.
I don't know if it matters.
I'm a little disappointed. He didn't get a chance to paint it.
And the pulley looks super weird, I want to get a bigger one if they make it
I'm going to be disconnecting the negative until I figure out what's wrong
I'm going to run that parasitic draw test. Too
Worst case scenario. It's under warranty, so maybe I'll burn up the alternator and need a new one. ???
Has anyone ever used the electronic battery disconnect? The one with the Little key fob I see on Amazon. ???
I have a mechanical one. I'm going to try installing right now.
Honestly, it looks easier just to pull the negative.
Lol |
my3bugs Samba Member
Joined: June 18, 2003 Posts: 861 Location: Moreno Valley
Posted: Mon Jun 23, 2025 3:12 pm Post subject: Re: 67 beetle new alternator keeps killing my battery |
i believe that to be the best original pump , its rebuild-able unlike the new disposable garbage sold today . he was right about keeping that !!! its called a square top pump in the hobby . yours was made in Mexico , some are German .
ya alternators fit with these pumps .
Posted: Mon Jun 23, 2025 3:58 pm Post subject: Re: 67 beetle new alternator keeps killing my battery |
Did parasitic draw test got 3.72
Does it matter if the green and blue wire are connected where the regulator was would that really make any difference
Installation guide says they should be connected. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16571 Location: North Florida, USA
Posted: Mon Jun 23, 2025 4:04 pm Post subject: Re: 67 beetle new alternator keeps killing my battery |
I'm gonna agree with mukluk. your VR or generator went bad (as evidenced by the GEN lamnp remaining ON while the key was OFF). This toasted the generator and/or VR. It may have also drained the battery. How old is your battery? Anything over 5yrs old and you are running on borrowed time. If the generator problem drained the battery it could have permanently damaged it. Batteries are only meant to be drained while cranking the engine for a few seconds. Once the engine is running the charging system quickly recharges the battery. Usually, deep discharging a battery is not good for it.
When you say the battery tests good, how did you test it. A state of charge test alone is not enough. You need a proper load test. Many digital battery testers do a simulated load test that works sometimes but may not accurately ID a battery that cannot carry the load. Take your battery to your FLAPS and see if they have the proper test equipment.
With your new alternator, start the engine and rev it a bit above idle and take a voltage reading at the battery terminals. You should see 13.8v ~ 14.5v at high idle. This confirms your charging system is working.
A parisitic drain is just something drawing current from your battery when it shouldn't (when the key is OFF). If you have a modern digital radio it will have a yellow wire that is connected to a battery constant power source. This wire is meant to keep power to the radio while the ignition is OFF so the memory and clock time is not lost. The amount of current draw from the radio is small. In the range of 100mA (0.1A) of less. Any current draw more than this will drain your battery if the car is left for more than a couple days.
If you remove the battery negative terminal and place a 12v test lamp between the end of the battery cable and the post of the battery and it lights up, it means current is flowing to/from the battery thru the test lamp. You have a prasitic leak.
If you have a Digital MM, set it to read <10A and put it in place of the 12v test lamp between the cable and battery post. Any current draw must pass thru the meter and you will see just how much current is being pulled from the battery. If it is more than 100mA (0.1A) you need to find the source. If less than this and you have a digital radio it may just be the radio. Disconnect the radio's yellow wire and see if the current drops to near zero. If there is little change it means something else is drawing current.
Leave the meter connected and move to the fuse box. Pull the fuses one at a time while you monitor the meter. When you pull a fuse and see the amp reading drop, you know there is somthing powered by that fuse which is pulling current while the key is OFF. A '67 Beetle should only have two fuses (#9 & #10) which are powered while the key is OFF. If removing either or both of these causes the current reading to drop to zero you know the problem is powered to one of these fuses.
If removing all the fuses makes no change to the current draw reading... disconnect the two wires DF and D+ from the alternator. Wrap them in a rag so they do not short to ground. Did the ampmeter readings change? At this point you have disconnected around 90% of devices. Next step would be to disconnect the ignition switch and the wires from the headlight switch.
Do some of the above a report back your findings. Good luck! _________________ AshMan40
Posted: Mon Jun 23, 2025 4:47 pm Post subject: Re: 67 beetle new alternator keeps killing my battery |
You should get a more correct aircleaner, one that has provision for crank case breathing, you got unplugged holes in the apron tin piece, which will allow hot air to be drawn into your cooling system and carb, not good.
Yes the regulator got fried, that is what caused the generator light to stay on.
You want a larger pulley? Which one? The lower pulley if larger will give faster fan speed, which can help cooling, the upper pulley if larger will reduce fan speed, not good!!! _________________ Sorry About That Chief.
Words to live by. |
Posted: Mon Jun 23, 2025 4:56 pm Post subject: Re: 67 beetle new alternator keeps killing my battery |
ashman40 wrote: |
Do some of the above a report back your findings. Good luck! |
So previously, I had change the generator and regulator. I did that work myself. Had a lot of issues getting everything squared away. Everything was working fine. For about a month.
I just took it in to have the wires neated up
I got it back, drove it for about twenty minutes more like fifteen
Stopped and the generator was smoking.
There's a chance that it was a cheap regulator and went bad. I had issues with the first regulator ever placed also
The mechanic that neated up the wires. Came and picked up the car for me. Told me the regulator and generator were both bad and the alternator is a much safer solution. The car died on him Thursday. He told me I needed a new battery.
The battery is around three months old or I purchased it tested.It said that it's good they put it on charge. And tested it twice. I'm not sure how they tested it.
Took the battery back to the mechanic, installed it friday and drove it home
No real issues. No generator light at all. Only the oil pressure light
Try to turn over the car Saturday. Nothing.
I have a spare battery. It doesn't really fit the car, but it's 12 V and enough for me to be able to run the tests
For parasitic draw
That's when I noticed the blue and green wires are not connected where the regulator used to be most of the installation guides say that it is necessary
And that's about where I am currently
When I did the parasitic draw test on the negative side, the test light lights up
My husband said for the volt meter, you should do it from the positive side, and he got 3.72
From the negative side, I pulled each and every fuse, singularly while he use the test light he said there was light, no matter what
I don't have a radio currently
I will try disconnect the alternator and testing same test as the parasitic draw test just with the alternator right? |
Posted: Mon Jun 23, 2025 5:18 pm Post subject: Re: 67 beetle new alternator keeps killing my battery |
zerotofifty wrote: |
You want a larger pulley? Which one? The lower pulley if larger will give faster fan speed, which can help cooling, the upper pulley if larger will reduce fan speed, not good!!! |
It doesn't have to be bigger in the center it just looks weird I know about the air cleaner been keeping my eyes open not looking till I make it run
But it is on the list |
Posted: Mon Jun 23, 2025 5:19 pm Post subject: Re: 67 beetle new alternator keeps killing my battery |
ashman40 wrote: |
So I pulled the alternator wires and touched
The test light between the negative terminal and the ground wire for the car
No light
What does that mean |
mukluk Samba Member
Posted: Mon Jun 23, 2025 5:57 pm Post subject: Re: 67 beetle new alternator keeps killing my battery |
I don't know whatever the mechanic picked its a bosch |
I stand corrected, a Bosch alternator is the best one that could have been installed. I was honestly expecting to see one of the cheap chromed Chinese jobs. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Tue Jun 24, 2025 7:45 am Post subject: Re: 67 beetle new alternator keeps killing my battery |
The battery is around three months old or I purchased it tested.It said that it's good they put it on charge. And tested it twice. I'm not sure how they tested it. |
So it was tested when you purchased it, but it hasn't been load tested since the generator went bad? The generator/VR problem (GEN lamp on while key was OFF) means your generator was trying to spin the stopped engine. This draws a lot of current from the battery draining it while it heats up the VR and generator. This could have damaged the battery permanantly, even if you recharge it. If you haven't had the battery recharged and tested since replacing the generator you should. It is relatively new, is it still under warranty?
No real issues. No generator light at all. Only the oil pressure light |
Ok, this is a big problem. I read this to say your GEN lamp has never turned ON since picking up your car from the mechanic? Not before you start the engine. Not while driving.
Unlike generators, alternators require the GEN lamp turning ON to begin charging. If your GEN lamp never turned ON at all then the alternator never starts charging. Specifically, when you turn the key to ON/RUN before starting the engine the GEN and OIL lamps should turn ON. If either or both do not turn ON with the key you need to investigate why. Them turning ON before starting the engine confirms the bulbs are working. For the charging system, the current flowing thru the GEN lamp flows into the D+ terminal of the alternator and charges the field coil in the new alternator. When the engine is started it begins charging. Once it has started charging the D+ terminal of the alternator self-sustains the field coil. Once it starts charging the GEN lamp turns OFF as an indicator it is charging and putting out enough voltage. If you remove the GEN lamp, disconnect the wire or the bulb burns out, the field coil never receives a charge and the alternator never starts charging.
If your GEN lamp never turned ON at all since your got your car back from the mechanic it could mean you have been running off the battery only. This would explain WHY you can no longer start it (drained battery)... or the battery, now having been discharged again, is further damaged. Recharge the battery and get it properly load tested with something that actually puts a 450A load on the battery.
For parasitic draw |
This is fine. As long as your normal battery is putting out some level of voltage you could have used it. Even 6v from the battery would be enough to run the parasitic drain test.
That's when I noticed the blue and green wires are not connected where the regulator used to be most of the installation guides say that it is necessary |
When swapping an alternator in place of a generator you will have extra wires.
The generator has one thick wire and two smaller wires running between the generator and VR:
D+ = thick red wire
D- = think brown wire
DF = think green wire.
Most new alternators are AL-82 models with just 2 wires:
B+ = thick red wire (the generator D+ wire repurposed)
D+ = thin wire (either the old green or brown wire can be repurposed).
The key point is the blue #61 wire coming from the GEN lamp which used to end at the VR under the left rear seat needs to be extended to reach the D+ terminal of the alternator. This is usually done by splicing the blue wire with the green DF wire and then connecting the engine end of the green wire to the D+ terminal. If this junction under the rear seat has come apart you need to fix this.
Test: turn on your ignition switch to the ON/RUN position (engine OFF). The GEN and OIL lamps should turn ON (I'm guessing your GEN lamp is not working?) Walk to the engine compartment and disconnect the D+ wire from the alternator. GEN lamp turns OFF. Touch the end of this wire (what color is this wire?) to the case of the alternator to ground it. The GEN lamp should turn ON. If this doesn't happen and only the OIL lamp is ON you have a disconnect between the GEN bulb and the alternator. You need to trace the wire and find out where it has become disconnected.
From the negative side, I pulled each and every fuse, singularly while he use the test light he said there was light, no matter what |
I'm hoping you mean he connected the multimeter set to read current (amps) between the battery post and the disconnected cable terminal? Current readings are taken "in-line" with all current flowing THRU the meter. The amp meter can be connected on either the positive or negative side of the battery. Any current flowing out from the positive post returns thru the negative post. Current flow thru an amp meter will show as either a positive or negative number. Any reading other than zero means current is flowing.
It is safer to handle the negative side connection at the battery because any short between the negative side and the body of the car will not cause a short, but accidentally shorting the positive side to the body cause a large spark and possibly a fire. This is why working with the negative post/terminal is preferred.
With everything turned OFF a current reading of 3.72A thru the meter is huge! This will quickly drain the battery. Is it possible the meter was reading in milliamps? 3.72mA (0.00372A) is well below the 100mA threshold.
If the meter was set to read volts and you connected it in-line, I don't know what kind of reading you will get? You would not connect a volt meter between the disconnected cable and the battery post. Volt meters are only useful when connected in parallel to the circuit.
As far as using a test lamp... it needs to be a 12v incandescent lamp which allows current flow in both directions. Some newer LED type test lamps only allow current flow in one direction. This won't work here. Place the two ends of your test lamp on the posts of the battery and make sure it turns ON. Then swap the leads and make sure it still turns ON. This confirms it works with current flowing thru the test lamp in either direction. If you connected the (bidirectional) test lamp between the battery post and the disconnected terminal and the lamp remained OFF thru the entire test, it suggests there is no parasitic drain.
Test: Disconnect the negative terminal from the battery. Place the test lamp between the battery (-) post and the disconnected negatove cable terminal. With the ignition OFF the lamp should be OFF (no current being drawn from the battery). Turn the dome light or parking lights ON to start drawing current from the battery and the lamp should turn ON indicating current is flowing thru it. If you cannot get the lamp to turn ON when you start to draw current from the battery and when you stop drawing current the lamp turns OFF... you have it wired wrong.
If you connect it as above and the lamp remains ON with everything powered OFF... you have a parasitic draw. The test of removing the fuses only works when you find a parasitic draw (lamp ON) and you remove fuses to determine which circuit is drawing the current. Removing the fuse powering the draw will cause the lamp to turn OFF. So if the lamp is never ON there is no use doing the fuse removal test.
For example, if turning the parking lights ON causes the test lamp to turn ON, then you remove the two parking light fuses the test lamp will turn OFF indicating you have stopped drawing current thru the test lamp.
I don't have a radio currently |
Ok, so we should be looking at almost zero current flow.
You could disconnect the 2 wires at the alternator (making sure neither touches anything when removed) and check if this changes the current draw at the battery. It is possible for an alternator to go bad internally and become a drain on the battery when the engine is not spinning it. _________________ AshMan40
Posted: Tue Jun 24, 2025 5:01 pm Post subject: Re: 67 beetle new alternator keeps killing my battery |
ashman40 wrote: |
So it was tested when you purchased it, but it hasn't been load tested since the generator went bad? . |
Yes also tried with a different battery.
Yes the battery is still under warranty.
[quote="ashman40"]
The generator light did not come on when I turned on the key. The oil pressure light did
The reason for this is the light was not connected.
ashman40 wrote: |
Unlike generators, alternators require the GEN lamp turning ON to begin charging. If your GEN lamp never turned ON at all then the alternator never starts charging.. |
Oddly enough, it does charge to fourteen volts.Nothing more
..... Actually, I didn't test until I reconnected the light....
But mechanics said it was working
ashman40 wrote: |
Once it starts charging the GEN lamp turns OFF as an indicator it is charging and putting out enough voltage. If you remove the GEN lamp, disconnect the wire or the bulb burns out, the field coil never receives a charge and the alternator never starts charging.. |
After I connected the light it stays on constant unless I turn the car over thin it goes out
ashman40 wrote: |
D+ = thick red wire
Test: turn on your ignition switch to the ON/RUN position (engine OFF). The GEN and OIL lamps should turn ON (I'm guessing your GEN lamp is not working?) Walk to the engine compartment and disconnect the D+ wire from the alternator. GEN lamp turns OFF. Touch the end of this wire (what color is this wire?) to the case of the alternator to ground it. The GEN lamp should turn ON. If this doesn't happen and only the OIL lamp is ON you have a disconnect between the GEN bulb and the alternator. You need to trace the wire and find out where it has become disconnected.. |
The green runs from the d+ to inside where the regulator was The other blue runs from where the regulator was to the light.
Installation guide says you need to connect them to make the warning light for the generator come on, as you previously mentioned. Other than that, there are the 3 red wires that are connected
I mean, I could run a brand new wire but I don't see any point in it
ashman40 wrote: |
I'm hoping you mean he connected the multimeter set to read current (amps) between the battery post and the disconnected cable terminal? . |
Yes
ashman40 wrote: |
If the meter was set to read volts and you connected it in-line, I don't know what kind of reading you will get? You would not connect a volt meter between the disconnected cable and the battery post. Volt meters are only useful when connected in parallel to the circuit.. |
I had my husband redo it
was set to 10(A)
He said its the right one
ashman40 wrote: |
As far as using a test lamp... it needs to be a 12v incandescent lamp which allows current flow in both directions. Some newer LED type test lamps only allow current flow in one direction. This won't work here. Place the two ends of your test lamp on the posts of the battery and make sure it turns ON. Then swap the leads and make sure it still turns ON. This confirms it works with current flowing thru the test lamp in either direction. If you connected the (bidirectional) test lamp between the battery post and the disconnected terminal and the lamp remained OFF thru the entire test, it suggests there is no parasitic drain.. |
So that's the test light is only one I know how to use. It's a bidirectional.
It doesn't give me exact measurements. But if the light's on, there's definitely power
If I disconnect the alternator and connect The light ,there is no light
If the alternator is connected, there is a light, no matter what fuse is disconnected i could try and turn on the headlights or something. But I don't really see a point in it.
ashman40 wrote: |
For example, if turning the parking lights ON causes the test lamp to turn ON, then you remove the two parking light fuses the test lamp will turn OFF indicating you have stopped drawing current thru the test |
[quote="ashman40"]
You could disconnect the 2 wires at the alternator (making sure neither touches anything when removed) and check if this changes the current draw at the battery. It is possible for an alternator to go bad internally and become a drain on the battery when the engine is not spinning it .[/quote.]
Yeah, I wrapped them in a towel.
Mechanic doesn't think store will warranty alternator
Considering all the testing that's been done, could there be any other reason? The battery is draining.
Just to reiterate...
If I disconnect the alternator and do the battery parasitic draw test?
I get no voltage drain. And no test light.
With all fuses and everything else connected. With the alternator connected
There is a 3.7~ draw
There were a lot of changes made when the wires were fixed up
A lot done to the front
Added:
horn
Reverse lights.
Turn signal regulator.(new)
Looking at it, some things look like they've been switched around. unfortunately, I don't have good pictures of what it looked like right before it went in i had done some work to get headlights and brake lights.
But I don't have parasitic draw without the alternator connected. So I'm not sure that makes any difference. |
Posted: Wed Jun 25, 2025 12:02 am Post subject: Re: 67 beetle new alternator keeps killing my battery |
Suggest to check 3 possible issues here:
a) new alternator, diodes are shot, if so, why?
b) your wiring has one or more shorts
c) your wiring is not original
to a: battery connected, engine and ignition switched off
If there goes current from B+ to D+ terminals of alternator, or from B+ to Ground inside of alternator, then the alternator diodes are shot.
1.) > disconnect wire D+ from alt. (gen lanp in speedo must go off if there is no short in D+ wire from alt. to lamp)
2.) > connect a test lamp at terminal D+ at alternator and on wire D+ (lamp on or off?) (>> if there comes voltage out of gen, when engine is off > diodes are shot)
3.) > disconnect wire D+ from alt. > connect test lamp on terminal D+ of altern.. and GROUND (lamp on or off?) or take voltmeter (if the light is on, there comes voltage through the alternator because diodes are shot)
4.) > connect an ampere meter on D+ of alternator and Ground (what current here?)
If the diodes of alternator are shot, voltage, current goes from B+ to D+ through the alternator, making the gen light in speedo on (when engine and ignition is switched off)
Over all, I´m afraid, some wires can have shorts, maybe only when engine is on and moves a bit (in area of chrome engine tin) that can have shot the some diodes inside of new alternator.
I´m thinking in that direction, because you have said, some days or some weeks after the new alternator was installed, everything was OK. (if I got it right) |
Posted: Wed Jun 25, 2025 2:39 am Post subject: Re: 67 beetle new alternator keeps killing my battery |
No, the alternator never worked.
The battery died at the shop. Where the mechanic worked on it
He said, I needed a new battery.
The place where I got the battery charged and tested.
Said, battery is good, it doesn't want to replace
I installed the battery, it died overnight.
Tried a different battery
Connected Gen light.
Generator light stays on
Then I ran the parasitic draw tests. |
Posted: Wed Jun 25, 2025 2:51 am Post subject: Re: 67 beetle new alternator keeps killing my battery |
What´s about the generator lamp in speedo?
Was it ON, when engine was OFF when you picked up your car at shop, mechanic?
I got it that way, for a period of time after you had got your car back from shop, the gen lamp has worked, as it should.
A alternator can only work properly, as long as the Gen light is connected and correct wired.
The Gen lamp in speedo needs terminal 61 D+, blue wire AND switched + from terminal 15 black wire (not GROUND !)
With luck and I hope that for you, uncorrect wiring of Gen lamp causes non charging of alternator which if hopefully still not shot. |
