"Special" thick wall slip in 88 (both ends)
bcrazy
bcrazy is offline
PostPosted: Mon Jun 30, 2025 2:10 pm    Post subject: "Special" thick wall slip in 88 (both ends) Reply with quote
Came a cross a used set of 88mm slip in P&C
These seems to be thicker than the normal slip ins i have seen before.
If they have been machined down at the head register or designed that way i do not know.
Anyone have some info or seen these before
There is an old post on this forum about "VICSA" piston and cylinders.
Maybe this is what was used in the OEM Brasil 1679cc engines??
modok
modok is offline
PostPosted: Mon Jun 30, 2025 6:37 pm    Post subject: Re: "Special" thick wall slip in 88 (both ends) Reply with quote
Looks like regular old slip in 88's to me
I've seen that U shape logo a thousand times before but for some reason I can't remember what it means
Do they use 1.5mm rings?
67rustavenger
67rustavenger is offline
PostPosted: Mon Jun 30, 2025 9:12 pm    Post subject: Re: "Special" thick wall slip in 88 (both ends) Reply with quote
Isn't that a Mahle stamping?
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
modok
modok is offline
PostPosted: Mon Jun 30, 2025 9:17 pm    Post subject: Re: "Special" thick wall slip in 88 (both ends) Reply with quote
probably, just can't remember, caught me on a bad day..
modok
modok is offline
PostPosted: Mon Jun 30, 2025 9:20 pm    Post subject: Re: "Special" thick wall slip in 88 (both ends) Reply with quote
AHA! it's METAL LEVE
67rustavenger
PostPosted: Mon Jun 30, 2025 10:13 pm    Post subject: Re: "Special" thick wall slip in 88 (both ends) Reply with quote
Thumbs Up
Buy Once, Cry Once!
bcrazy
bcrazy is offline
PostPosted: Mon Jun 30, 2025 11:48 pm    Post subject: Re: "Special" thick wall slip in 88 (both ends) Reply with quote
Rings are 2,3 and 5mm
Someone got a set of 88slip in to compare?
modok
modok is offline
PostPosted: Tue Jul 01, 2025 12:55 am    Post subject: Re: "Special" thick wall slip in 88 (both ends) Reply with quote
I see
The cima/mahle 88 had 1.5-1.5-5 ring pack
DesertSasquatchXploration
DesertSasquatchXploration is offline
PostPosted: Tue Jul 01, 2025 9:22 am    Post subject: Re: "Special" thick wall slip in 88 (both ends) Reply with quote
What's the deal with 1.5 and 2mm rings? Are the 2mm supposed to last longer?
Key is to have downward travel Preload keep both wheels on the ground at all times once you lift a tire your DONE. Guys worry about clearance instead think of the opposite you want the suspension to drop that tire in the hole and keep you going. A spider for example they keep their body low but their legs can reach pretty far so they don't (bottom out)
chrisflstf
chrisflstf is offline
PostPosted: Tue Jul 01, 2025 10:02 am    Post subject: Re: "Special" thick wall slip in 88 (both ends) Reply with quote
Thinner rings mean less drag
vwracerdave
vwracerdave is offline
PostPosted: Tue Jul 01, 2025 10:16 am    Post subject: Re: "Special" thick wall slip in 88 (both ends) Reply with quote
bcrazy wrote:
Those are cast pistons. See the 2 metal tabs between the wrist pin bosses.
bcrazy
bcrazy is offline
PostPosted: Tue Jul 01, 2025 1:43 pm    Post subject: Re: "Special" thick wall slip in 88 (both ends) Reply with quote
If someone has a 88mm slip in cylinder on the shelf, and could measure the thickness at the fin area, that would be great
PostPosted: Tue Jul 01, 2025 1:57 pm    Post subject: Re: "Special" thick wall slip in 88 (both ends) Reply with quote
WOW
Talking ACVW, I would assume fatter rings will take longer to seize with carbon because of bigger holes. With the modern oils the fatter rings are outdated? But we still run hotter then water-cooled and more fuel. Even with that, the new oils can overcome this?
In short are 1.5mm top and middle rings the new base line Normal?
Wreck
Wreck is offline
PostPosted: Tue Jul 01, 2025 3:00 pm    Post subject: Re: "Special" thick wall slip in 88 (both ends) Reply with quote
The machine in AA's I have are not machined centred to the area you are talking about . varies from 9.5mm to about 7mm .
On the topic of pistons and rings , Toyota V6 + 0.020" are 87.95mm with a 1.2, 1.2, 3mm ring pack and pin height of 31.25 (from memory). So a 78mm crank and 5.5" rods get you in the ball park .
VWporscheGT3
VWporscheGT3 is offline
PostPosted: Wed Jul 02, 2025 6:15 am    Post subject: Re: "Special" thick wall slip in 88 (both ends) Reply with quote
DesertSasquatchXploration wrote:
WOW
1.5 top rings have been std for a long time , the American equivalent is 1/16. 2 mm is closer to 5/64.
when it comes to fatter rings it was mainly due to materials being used. modern rings are steel instead of a cast material , they are stronger and less material can be used for the same strength. Modern oils can come in to play , but its far less than you think. service interval and tune come into play.
GM LS engines would be a prime example of this, take your average 5.3L truck motor. typically those had a 1.2 1.2 2.8mm ring pack. while this created less drag it doesnt count for much if your service intervals are 6k and 8k. the oil tends to sludge and then start packing in the oil ring causing more oil consumption and smoking. Ford eco boost's are even worse at this. just because the manufacturer is recommending 6k 8k oil changes doesnt mean that the oil necessarily can handle that.
one of the benefits of the newer materials like steel in rings , as well as going thinner, is that they are more compliant to the cylinder surface. and as we know VW cylinders never stay straight. compliance to the surface obviously means better sealing over a longer period of time than a thicker ring.
i hope this helps.
bcrazy
bcrazy is offline
PostPosted: Thu Jul 03, 2025 12:55 pm    Post subject: Re: "Special" thick wall slip in 88 (both ends) Reply with quote
Got hold of another set of 88mm. No markings to suggest what brand.
The wall thickness of this set is about 0.6mm less than the one from Brasil
This suggest there might be some different spec 88mm slip in variants.
Would be interesting to see what wall thickness in the fin area 85.5mm cylinders have.
"ino brasil"
Uknown
NJ John
NJ John is offline
PostPosted: Thu Jul 03, 2025 3:50 pm    Post subject: Re: "Special" thick wall slip in 88 (both ends) Reply with quote
Here’s a coma set of slip-ins for sale for pic reference. The thick top 88’s are 5.25mm thick on top.
https://www.thesamba.com/vw/classifieds/detail.php?id=2656981
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
