aquifer  Samba Member
Joined: August 30, 2021 Posts: 390 Location: Nebraska
Posted: Mon Jun 30, 2025 3:59 pm Post subject: Re: Bad starter solenoid confirmation? |
Bobs67vwagen wrote: |
I would be interested when you do finally find out the cause of this is, what is was. Hard to top all of the great troubleshooting advice you received on this topic. My guess would still be the ignition switch or the wire from the switch to the solenoid. Good luck-Bob |
OP here, back to follow up. Very helpful advice as Bob said.
I now have about .4 volt drop at the solenoid during cranking compared to the battery during cranking. Not too much of an improvement, but some. I didn't find anything glaring, but here's what I did:
The ground strap surfaces seemed fine but I cleaned and wire wheeled them anyway. I needed to work on my wipers so I pulled the wiper assembly out, which gave me access to the switches. I pulled the headlight switch out and cleaned the terminals, especially where the heavy battery wires connect. I also removed the ignition switch and pulled out the key cylinder (it needed cleaning anyway). I sprayed the cleaner around as best I could and worked the switch with a screwdriver before putting the key cylinder back in. I cleaned the terminals with a brass brush.
Not enough time as elapsed to determine if it's ok or not. If it acts up again I'll check the voltage at the solenoid. The solenoid should click even with relatively low voltage, even if it doesn't spin the starter, so I still think the solenoid might be bad, because there was zero click whatsoever when it acted up. But we'll see how it acts now, and if I learn anything new I will post it back here.
Thanks for all the great advice! _________________ Project vehicles:
1967 Beetle #1. Bought in 2024, mostly original, October 1966 build date.
1967 Beetle #2. Bought in the mid 80's, restored myself in the late 90's, June 1967 build date.
1998 Jaguar XJR. Bought in 2015, rust free AZ car, refurbished myself. Driven in nice weather.
Parts needed:
Front & rear NOS or used OEM door panels for a '67 in the original Gazelle color (dark tan/light brown). |
Luft kühl Samba Member
Joined: January 21, 2009 Posts: 1179 Location: Allentown, PA
Posted: Tue Jul 01, 2025 6:13 pm Post subject: Re: Bad starter solenoid confirmation? |
When you installed your rebuilt starter, did you also replace the starter bushing ( the one in the bell housing ) ?
A worn bushing can cause the solenoid plunger to bind intermittently .
Try rocking the car back and fourth while in gear, and then try again to see if you can get the solenoid to click. |
Posted: Tue Jul 01, 2025 7:00 pm Post subject: Re: Bad starter solenoid confirmation? |
Luft kühl wrote: |
Yes the bushing was new. Next time it happens I’ll try rocking the car, but I’m 99.999% sure it’s not binding. There was just no click whatsoever from the solenoid. No sound at all. If the starter was bound up, it would have had to happen the last time I started the car and I would think there would have been massive grinding noises when the engine started up. _________________ Project vehicles:
Parts needed:
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 1038 Location: South Florida
Posted: Wed Jul 02, 2025 4:49 pm Post subject: Re: Bad starter solenoid confirmation? |
@aquifer - Next time you get "no click" when attempting to start, try shorting ignition switch terminal #30 (or, #15 while switch is in ON position) to #50:
If this brings in your starter, then you will have narrow'd the trouble to being inside of ignition switch. When I had such trouble, it turn'd out to be a black film covering the contact at about 1:00 ~ 2:00 o'clock position of the part in middle of this pic:
More about it is in this post:
https://www.thesamba.com/vw/forum/viewtopic.php?p=8886078&highlight=#8886078
Edit - Going back to read earlier posts...
aquifer wrote: |
... when this happened again, I tried jumping the ignition switch and no dice ... |
Begging your pardon.  |
Posted: Fri Jul 04, 2025 12:02 pm Post subject: Re: Bad starter solenoid confirmation? |
Well I haven’t figured this out yet. Here is the current situation.
It acted up again this morning, fortunately it was on the hoist so I could get to everything. I shorted the ignition switch across. Big spark but nothing from the starter. No clicks, nothing. So I figured it must be the starter solenoid.
I had ordered a new solenoid in case I needed it, so I removed the starter and replaced the solenoid. Same problem. No clicking from the starter. So I shorted the starter across with a screwdriver (which I should have done first) and bingo! Solenoid engaged, engine turned over nice. But still doesn’t work from the switch, even by shorting it across.
So now I think the ignition wire from the switch to the solenoid is running to ground somewhere. There had been mice in the car before I bought it, so it is possible that the wire got chewed up somewhere, though there is no visible problem.
One of the reasons I think it might be running to ground at least partially is that it’s quite a huge spark when I shorted the ignition switch across and the screwdriver got pretty warm after less than a second.
As to why it’s acting up so bad now as opposed to a week or month ago, I have no idea. Maybe the wire got jostled somehow and now it’s touching ground or something.
In any case, I’m mulling what to do. I don’t think I want to use the wire even if I do a hard start relay. I think I’m going to get some heavy wire and run it in the open between the switch and the solenoid. If it works via the key, I’ll know that’s the problem and I’ll have to figure out a way to run a new wire back there.
All thoughts are welcome and appreciated! _________________ Project vehicles:
Parts needed:
slayer61 Samba Member
Posted: Fri Jul 04, 2025 12:27 pm Post subject: Re: Bad starter solenoid confirmation? |
So it sounds like you have it down to just one wire, right? Disconnect BOTH ends of the wire. Insulate the solenoid end of the wire, and go to the switch end of the wire with your ohm meter and test the wire to ground. You SHOULD see infinite ohms or something close to that. Your meter might say OL or open line. That's good. If it reads a low number, 0 or zero point something, that's bad. If there's another joint or splice in the wire, break that connection and repeat the test again looking both ways. If you have a short, this will tell you if it's in the front or the back.
Good luck. _________________
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes?  |
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
EMPI GTV 2 STG II wedge ports
MSD Box and distributor
Car Craft turbo header |
Posted: Fri Jul 04, 2025 1:29 pm Post subject: Re: Bad starter solenoid confirmation? |
slayer61 wrote: |
Good luck. |
This is helpful thank you.
So I did exactly that, and I’m still stuck.
I'm not an expert with the tester, but I taped off each end separately and put my leads on the wire and a good ground. I first had it set on continuity where it makes a tone if there is a circuit. No tone. Then I set the meter on ohms and it read 1 without hooking up the leads. It still read 1 after hooking up the leads and turning the dial to all the ohm settings because I don’t know which one to choose. Didn’t matter. No change at any setting. Reads 1 at every setting. Same from the switch side. I did put the leads on a piece of metal just to see if it was even working, and the ohm readings did change. So I think the tester works.
Two possibilities exist: 1) I didnt run the test right (though I think I did), or 2) the wire is not shorting to ground and I still have no idea what’s wrong.
I’m baffled even more now. Why was there such a big spark when I shorted the ignition switch, yet no sound from the starter? Why did it spark at all if not because the solenoid was engaging? I think I’ve established that I don’t have a short to ground between the switch and the solenoid either, so that’s not the cause of the spark either. Baffling.
Is there any other wires that could be messing with the starter circuit? There doesn’t appear to be from the wiring diagram. The headlights are bright, all other electrical things work perfectly.
Edited to add: could the ignition switch itself be shorting to ground when turned to the crank position? Just thought of that. If the “outgoing” terminal is shorted somehow, it might explain everything, including why it sparks so big when shorting the switch. Maybe? I’ll try to figure out how to test that similar to how I did the wire. _________________ Project vehicles:
Parts needed:
Fender38 Samba Member
Joined: April 11, 2015 Posts: 118 Location: Las Vegas, NV
Posted: Fri Jul 04, 2025 4:18 pm Post subject: Re: Bad starter solenoid confirmation? |
aquifer wrote: |
Edited to add: could the ignition switch itself be shorting to ground when turned to the crank position? Just thought of that. If the “outgoing” terminal is shorted somehow, it might explain everything, including why it sparks so big when shorting the switch. Maybe? I’ll try to figure out how to test that similar to how I did the wire. |
The best way to test your ohm meter is working is to simply touch the two probes together. I don't know what meter you're using, but possibly the "1" you're seeing is actually an I, for infinity, which is what an ohm meter would correctly read on a open.
It's good you ran the check to see if the wire is shorted to ground, but you should also use the meter to check that the wire isn't open. If a rat had chewed through it, as you mentioned, then this would be the way to check.
It's simple, connect one end of the wire to any ground source, then from the other end of the wire, using the ohm meter, measure between that end of the wire and any ground source. If the meter reads 0 ohms, then you have continuity across the wire (which is what you want). If you still read infinity, or very high ohms, then that indicates a break in the wire somewhere that you'll need to either locate and fix, or just run another wire to replace the old one.
Another thing to mention, if when doing this, you get some ambiguous readings. As in it doesn't read either 0 ohms or infinity, but rather somewhere in between, that could be an indicator that your chassis ground is not good. |
Posted: Fri Jul 04, 2025 5:01 pm Post subject: Re: Bad starter solenoid confirmation? |
Ah I see now! I didn’t do the test right. I thought that if the wire was unwittingly going to ground someplace along its path, I would have seen continuity to ground by the way I did the test. Which I did not. I think that’s probably true? Your way is better, but I think my way told me that the wire is not going to ground?
I did learn more since my last post. I phoned a friend to run the ignition switch while I measured voltage at the solenoid (at the wire coming from the switch). It was about 10 volts. The surroundings were quiet enough that I heard something. So we cranked it again and I heard the sound again. The starter motor was turning - slowly - but the solenoid had NOT engaged.
What does that mean? I don’t know, but maybe it’s possible that the wire has some broken strands inside the insulation someplace, so it’s not carrying enough juice. Maybe?
I’m going to get some wire, put ends on it, and run it from the ignition switch to the solenoid out in the open. Then I’ll crank the ignition. If it works, I’ll know there is SOMETHING wrong with the old original wire. At that point I will insulate the ends of the old wire and figure out how to run the new wire neatly from the switch to the solenoid.
If it doesn’t work, then it’s back to the drawing board. I’ll report back! Any other suggestions are welcome! Thanks again for all the advice. _________________ Project vehicles:
Parts needed:
Posted: Fri Jul 04, 2025 5:18 pm Post subject: Re: Bad starter solenoid confirmation? |
aquifer wrote: |
They're two different tests. One to see if the wire is shorted to ground, and one to see if the wire is open.
The test you performed previously was to check if it the wire was shorted to ground, and the procedure was explained correctly. You probably performed that test correctly.
What I was describing is a continuity test to make sure the wire isn't broken somewhere and you have a complete connection from the ignition switch to the starter solenoid. |
Posted: Fri Jul 04, 2025 5:40 pm Post subject: Re: Bad starter solenoid confirmation? |
Fender38 wrote: |
aquifer wrote: |
Oh I see where you’re going. I’m catching up now! Does the fact that I heard the starter motor turning tell me enough? There’s obviously current getting back there, but apparently not enough to engage the solenoid and turn the starter motor at the same time? Yet I’m pretty sure it’s not going to ground based on my prior test, so that probably means that the wire strands are broken somewhere that I can’t see. But not ALL the strands, right? Because there is SOME juice getting back there - enough to weakly engage the solenoid to turn the starter motor.
I think the old wire is 12 gauge. If I have to run a new one, should I run 10 gauge? Or is a new 12 gauge wire more than sufficient?
I appreciate your patience. I’m learning! _________________ Project vehicles:
Parts needed:
Posted: Fri Jul 04, 2025 6:11 pm Post subject: Re: Bad starter solenoid confirmation? |
aquifer wrote: |
I appreciate your patience. I’m learning! |
From where are you initiating the connection when you do hear the starter turn over? Are you shorting the connection across the ignition switch or shorting the connection across the solenoid? |
Posted: Fri Jul 04, 2025 7:00 pm Post subject: Re: Bad starter solenoid confirmation? |
Fender38 wrote: |
aquifer wrote: |
From turning the key. And it’s the same when we shorted the switch too. I think that tells me that the switch is fine, because the result is the same from either turning the key or from shorting the switch across. In either of those cases, the starter motor turns slowly, but the solenoid does not click to engage at full power.
What does make it work properly is shorting it at the solenoid, but that’s because it’s getting power from the main battery cable, not from the switch wire. Shorting at the solenoid brings full power. The solenoid clicks, the starter engages, and the engine turns over normally. If the key is turned on, the engine fires up. But that’s the only way to start it besides pushing it. _________________ Project vehicles:
Parts needed:
Posted: Sat Jul 05, 2025 8:07 am Post subject: Re: Bad starter solenoid confirmation? |
Still no luck. Here’s where I’m at.
I ran a new 12 gauge jumper wire from the solenoid to the ignition switch. Nada.
I then touched the jumper wire to the positive battery post. Bingo! Starter ran normally.
So I thought maybe the supply wire going forward from the regulator under the back seat to the headlight switch was defective somehow. So I got a new 10 gauge jumper wire and ran it from the regulator forward. Nada.
Then I touched the new 12 gauge solenoid jumper wire directly to the new 10 gauge jumper wire. Nada. So I’m thinking WHAT?? How is that possible? No way that wouldn’t work!
So I touched the solenoid jumper to the hot terminal on the regulator. Bingo! Starter engaged fine. That’s true every time. It always works when I touch it to the battery post or the live terminals on the regulator. Starter engages every time. But under no other scenario does it properly engage the starter.
What I’m seeing is not possible, yet there it is.
I should add that I did get the starter to engage a couple random times when I touched the solenoid jumper wire to the old supply wire on the headlight switch, and once when I touched the two new jumpers together. But 2 seconds later when I tried it again it did not work. The only time it works flawlessly is by touching the positive battery post or the hot regulator posts.
One interesting thing is that when it’s not working, there is a huge spark when I touch the wires together. On the extremely rare case that it does work, there is almost no spark and the starter engages normally. When I touch the battery post there is minimal spark and the starter engages normally.
Is it possible that my rebuilt original starter is defective, and only a direct connection to the battery itself can supply enough juice to overcome the defect and cause it to work? I’m grasping at straws now. Nothing I’m seeing makes sense to me. Maybe I’ll order a new starter and see if it works. Maybe the rebuilt starter has a bad spot that goes to ground or something.
Hmmm. _________________ Project vehicles:
Parts needed:
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26125 Location: Olympia Wash Rinse & Repeat
Posted: Sat Jul 05, 2025 9:37 am Post subject: Re: Bad starter solenoid confirmation? |
aquifer wrote: |
Hmmm. |
Could be, but could be one or more grounds need to be cleaned and dielectric greased up.
Have you cleaned the surfaces between the starter and transaxle?
Same for the surfaces between the starter body and the solenoid.
Plus both ends of both battery cables.... _________________ In Stereo, Where Available! |
Posted: Sat Jul 05, 2025 4:28 pm Post subject: Re: Bad starter solenoid confirmation? |
Eric&Barb wrote: |
aquifer wrote: |
Hmmm. |
Plus both ends of both battery cables.... |
Yes, the ground surfaces are so clean you can eat off em! I even ran a pencil shaped wire brush in a drill through the negative battery cable threads in the chassis. The threads sparkle. Both battery cables are new (not today, but recently new from other work I’ve done). If it’s a ground problem, then the dozens of other cars I’ve had in my life should have NEVER started! Haha.
My jumper wires are new wires with new terminals, heavy gauge wire (12 and 10), with as short of length as practical. There is no reason on earth that it shouldn’t work.
I hope there’s something wrong with my starter, because I am out of ideas. I ordered a new one, so we’ll see. I appreciate all ideas and suggestions, because you never know what will work! _________________ Project vehicles:
Parts needed:
Posted: Tue Jul 08, 2025 6:31 pm Post subject: Re: Bad starter solenoid confirmation? |
OP here: Well I guess the “rebuilt” starter was bad. I installed a new Bosch starter today and it instantly fired right up! I started it several times, test drove it, checked again - works like a champ.
Something inside the old starter must have been shorting to ground, at least sometimes, because my jumper wires would spark like crazy but the starter wouldn’t work 99% of the time. The starter is original to the car and I had it rebuilt several months ago, and it had worked fine since. I suppose that means that the shop that rebuilt it was careless or missed something.
I don’t know much about starters or electric motors, so my follow up questions are:
1. Is there such a thing as an un-rebuildable starter? It’s original to the car, so I would MUCH rather try fixing it again even if I keep on using the new starter for now.
2. Can an ordinary person like me rebuild it myself?
Thanks for all the advice on this. I hesitated to believe it was the starter for a long time because it had recently been rebuilt, but I guess that’s no guarantee. I did learn a lot and I fixed a few little things that I came across during the process, so it wasn’t all a waste of time! _________________ Project vehicles:
Parts needed:
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11276 Location: Huntington Beach, CA
Posted: Tue Jul 08, 2025 10:54 pm Post subject: Re: Bad starter solenoid confirmation? |
aquifer wrote: |
Thanks for all the advice on this. I hesitated to believe it was the starter for a long time because it had recently been rebuilt, but I guess that’s no guarantee. I did learn a lot and I fixed a few little things that I came across during the process, so it wasn’t all a waste of time! |
You sure can! Watch a YouTube video on the subject. I breezed over my rebuilding of the starter motor on page 98 of my 54 Oval. Not hard, but you have to be confident and have a few tools. I had to clean up the armature on my lathe. Anyways, you got nothing to lose, trying. Worst case is you put it back together and turn that in for a core. _________________ Jimbo
TDCTDI wrote: |
GFY's Xevin and VW_Jimbo!  |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 589 Location: Eastern north carolina
Posted: Wed Jul 09, 2025 5:58 am Post subject: Re: Bad starter solenoid confirmation? |
That was a long and exhausting journey to find out the part you had rebuilt was the culprit. At least all the troubleshooting offered in this thread will be of help to others experiencing similar problems. Bob |
