Mr Margaret Scratcher Samba Member
Joined: February 10, 2013 Posts: 300 Location: Cambridge UK
Posted: Wed Jul 02, 2025 3:48 pm Post subject: Weber 34 ICT fuel line routing |
I got a pair of 34 ICTs a while back but they didn't come with any fitting instructions, and I wanted to confirm the fuel line routing.
Is this right?
Is the fuel hose okay resting on the tinware? |
daveblank Samba Member
Posted: Wed Jul 02, 2025 6:45 pm Post subject: Re: Weber 34 ICT fuel line routing |
I would try to secure them. Over time them rubbing on the tins due to vibration could wear a hole in the line |
gtixpress Samba Member
Joined: June 22, 2006 Posts: 320 Location: Mahomet, IL
Posted: Thu Jul 03, 2025 8:21 am Post subject: Re: Weber 34 ICT fuel line routing |
Mr Margaret Scratcher wrote: |
Is this right?
This looks like a manifold vacuum line, not fuel. _________________ Joe P.
1969 VW Type 3 Squareback
2002 VW GTI 337 (Limited Edition)
2018 VW Atlas SE VR6 4Motion
2019 VW Beetle S Final Edition Convertible |
boxer74 Samba Member
Joined: July 03, 2011 Posts: 860 Location: Ontario, Canada
Posted: Thu Jul 03, 2025 9:22 am Post subject: Re: Weber 34 ICT fuel line routing |
gtixpress wrote: |
Is this right?
This looks like a manifold vacuum line, not fuel. |
It's a balance tube and should be run to the other manifold, not connected into the fuel system. _________________ 74 Super
84 Westy |
Posted: Thu Jul 03, 2025 4:02 pm Post subject: Re: Weber 34 ICT fuel line routing |
boxer74 wrote: |
gtixpress wrote: |
Is this right?
It's a balance tube and should be run to the other manifold, not connected into the fuel system. |
Yep, that's the balance tube, but it is very snug against the HT lead - are there different (right angled?) leads that are more suitable? |
Posted: Thu Jul 03, 2025 4:03 pm Post subject: Re: Weber 34 ICT fuel line routing |
daveblank wrote: |
Yeah this is what I was thinking - what's the best way to go about that? |
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2475 Location: Gladstone, Ore
Posted: Thu Jul 03, 2025 4:43 pm Post subject: Re: Weber 34 ICT fuel line routing |
One way is to protect it. take a piece of your extra fuel line, split it length wise, wrap it around the existing line so it rubs against the tin. secure that to the line with a couple of zip ties. _________________ 1972 1302
HPMX 40's & 019 |
Posted: Fri Jul 04, 2025 3:47 am Post subject: Re: Weber 34 ICT fuel line routing |
cletus_zuber wrote: |
One way is to protect it. take a piece of your extra fuel line, split it length wise, wrap it around the existing line so it rubs against the tin. secure that to the line with a couple of zip ties. |
I like that idea |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3311 Location: Hamble, Hampshire, UK
Posted: Fri Jul 04, 2025 5:26 am Post subject: Re: Weber 34 ICT fuel line routing |
boxer74 wrote: |
gtixpress wrote: |
Is this right?
It is easier to find an elbow for the balance hose. Or even block it off and drill and tap somewhere more sensible for the fitting ( like pointing straight out to the side on the manifold.)
As the hose will also get in the way of a spark plug socket spanner. Which cannot have a 90 degree bend .. _________________ Ancient vehicles and vessels
