Engine Won't Fit On Transmission - What Am I Doing Wrong?
andreasschmieg
andreasschmieg is offline
PostPosted: Wed Oct 07, 2015 1:45 pm    Post subject: Engine Won't Fit On Transmission - What Am I Doing Wrong? Reply with quote
I bought a 1967 VW Beetle with an AE 1600 dual port engine in cardboard boxes. I did a ghetto rebuild on the engine reusing everything that still looked decent. Now I tried to install the engine and it will not completely push into the transmission bell housing. I tried for quiet a while. The flywheel seems to fit in the hole.
Any idea what I am doing wrong?
Once I am done being pissed off, I will bolt the clutch assembly to an identical flywheel (without an engine attached to it) and try to just push the clutch and flywheel assembly into the transmission housing.
Or maybe the Beetle knows that this is not the original engine and rejects it :-).
Grrr!!!
~~~ Dont trust cars under 30! ~~~
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Wed Oct 07, 2015 1:49 pm    Post subject: Reply with quote
assuming you used a pilot tool when installing clutch, put the car in gear and the e brake on then rotate the pulley while trying to push the engine in the rest of the way. or hold your tongue on the other side of your mouth Wink
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
Northof49
Northof49 is offline
PostPosted: Wed Oct 07, 2015 2:19 pm    Post subject: Reply with quote
Does the clutch plate match the style of throwout bearing? There is an issue of some needing the ring on the pressure plate, and others won't work with it in place if not needed.
There are some good illustrations on this site of the way matching tranny's and clutch plates should look. Wrong combo and it won't go on the final 3/4".
1958 Karmann Ghia owner
grandpa pete
grandpa pete is offline
PostPosted: Wed Oct 07, 2015 2:23 pm    Post subject: Reply with quote
If that doesn't work ; Check the trans numbers...any chance a PO put in an early trans ?
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
Northof49
PostPosted: Wed Oct 07, 2015 2:30 pm    Post subject: Reply with quote
Check out this excellent thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=148307
andreasschmieg
PostPosted: Wed Oct 07, 2015 5:10 pm    Post subject: Reply with quote
Excellent thread indeed.
Here is what mine looks like:
Maxoceanblue
Maxoceanblue is offline
PostPosted: Wed Oct 07, 2015 5:49 pm    Post subject: Reply with quote
Wouldn't it be better to have the car in neutral and parking brake off? So the drive shaft can rotate as it slides into the engine. Did you use a clutch alignment tool?
1964 Beetle Sedan/1600cc DP 12v converted
andreasschmieg
PostPosted: Wed Oct 07, 2015 5:56 pm    Post subject: Reply with quote
Maybe I should use some KY. :-)
Bruce
Bruce is offline
PostPosted: Wed Oct 07, 2015 9:13 pm    Post subject: Reply with quote
You're not ready to install the engine yet.
That filthy input shaft will cause you lots of problems. First, take the TO bearing off so you can spend some quality time with a wire brush on the splines. They have to be clean and smooth. Use an old clutch disc to see that it slides like butter on them. If you don't have an old disc, take the one off the engine.
Once you have that clean, get some 320-400 grit sandpaper and polish the tip of the input shaft. It is the inner race of a roller bearing so it needs to be smooth and clean.
Clean out the bearing inside the gland nut and spread some new grease in it. Then coat the splines with a THIN coating of grease. Also grease the tip of the input shaft.
With all that oil inside your bell housing, you probably need to put a new input shaft seal in.
Now you can put the TO bearing back on and try to install the engine.
For future reference, your trans is a 1970.
KTPhil Premium Member
KTPhil is offline
PostPosted: Thu Oct 08, 2015 9:19 am    Post subject: Reply with quote
Excellent advice, and I'd add that a check of the TO bearing shaft is worthwhile now, too. Check the two "fingers" for bending or cracks where they are welded to the shaft. Many are reporting breakage these days.
yammi450
yammi450 is offline
PostPosted: Thu Oct 08, 2015 8:44 pm    Post subject: Reply with quote
I once had a aftermarket HD shaft from EmpI that was welded wrong, and it would hold the throw out bearing to far out and wouldn't allow the engine to mate up to the tranny all the way.
bluebus86
Banned
bluebus86 is offline
PostPosted: Thu Oct 08, 2015 9:18 pm    Post subject: Reply with quote
if that is gear oil on the bell housing then you got a tranny leak, fit it before installing the engine or the clutch will be ruined in short order. you may need a new seal at the tranny input shaft.
and the shaft needs to be cleaned up and rust removed. a bearing rides on the end of that shaft, the bearing wont last long with all that rust.
Dougy Dee
Dougy Dee is offline
PostPosted: Fri Oct 09, 2015 6:09 am    Post subject: Reply with quote
I had a similar problem several years ago. turns out the new bolts I installed with the new motor mounts were a mm too long and fouled the flywheel. Took a while to find... Bugger!
Dr OnHolliday
Dr OnHolliday is offline
PostPosted: Fri Oct 09, 2015 7:22 am    Post subject: Reply with quote
I hope that ghetto rebuild works out for you.
1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust
andreasschmieg
PostPosted: Sat Oct 10, 2015 4:03 pm    Post subject: Reply with quote
The engine is in now and cranking over. It is a good day.
grandpa pete
PostPosted: Sat Oct 10, 2015 4:15 pm    Post subject: Reply with quote
Tell what you found so you can help the next guy ;please
63 two fold rag
andreasschmieg
PostPosted: Sat Oct 10, 2015 4:50 pm    Post subject: Reply with quote
What worked: I cleaned and greased the transmission shaft as suggested above. Used very little grease, so it doesn't smear all over the clutch.
Then I mounted the clutch and cover plate on an identical flywheel that was not attached to an engine. 20 pounds are a lot less than 240 pounds. Once the flywheel and clutch assembly fit all the way in, I put the clutch and clutch cover back on the engine.
Then I used three car jacks to lift the engine in place. Two little ones on each side of a plywood board to lift it up, and a big one to tip it. I stood there in disbelief when it slid right in.
I hooked up the battery and got it cranking over nicely. That also fills all the oil galleys. I will leave the rest of the hookup, timing, and tuneup to my local shop.
Jerome Bosch
Jerome Bosch is offline
PostPosted: Sat Jul 05, 2025 2:00 am    Post subject: Reply with quote
Exactly what happened to me today!!! Installing a new engine, so I thought I'd replace the trans mounts at the same time. When I tried to install the new engine, it wasn't closing the gap to the transmission. Thought it might be something with the new engine, but then I found this thread and this comment. Went back and checked the length of the bolts on the new trans mount vs. the old ones, and boom, about 2mm longer. I took the engine back out and noticed some witness marks on the end of the bolts. Ground them down and yep, all good now!! Thank you!!
First pic shows the bolts with the witness marks, hard to see.
Second pic shows the bottom bolt ground down, the upper bolt is not ground yet.
Cusser
Cusser is offline
PostPosted: Sat Jul 05, 2025 7:32 am    Post subject: Reply with quote
So sad that too-many places cannot even copy a part correctly !!!!
Not VW:
