Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79441 Location: Sneaking up behind you
Posted: Tue May 27, 2025 6:04 pm Post subject: Lowered Bus, what size tires? |
So we installed an Airkewld straight axles tranasaxle and and lowered spindles along with their disc brake conversion.
Pete suggested 185/60-15 tires. The customer said when he has 3 passengers in it the front tires rub at times and when making turns.
Any suggestion on smaller tires?
185/55-15?
175/55-15?
What are you guys using front and rear? _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Split 66' Samba Member
Joined: October 07, 2010 Posts: 1367 Location: Bay Area, California
Posted: Tue May 27, 2025 6:52 pm Post subject: Re: Lowered Bus, what size tires? |
I lowered my '66 back in '89, it was recommended by Bus Boys back then to use stock 14" wheels with their stock width adjustable beam (all there was back then).
36 years later and I've never rubbed with 185-60-14 or lower profile tires - but never slammed it. I've had about 450 lbs. in the front seats at a time or two.
Currently have WW babystang disc brakes up front for stock 14", with 185-60-15's in the rear.
_________________ "OG = Original German" -- TheSamba.com dictionary |
karl h Samba Member
Joined: October 10, 2005 Posts: 642 Location: austria
Fleetline15 Samba Member
Joined: October 12, 2006 Posts: 15 Location: An tInbhear Mór
Posted: Wed May 28, 2025 2:51 am Post subject: Re: Lowered Bus, what size tires? |
My single cab is fairly low, I run 165/50/R15 on the front (no tubs) & no issue with rubbing. Rears are 205/65/R15. _________________ aka MENACE |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1565 Location: Eerie PA
Posted: Wed May 28, 2025 9:18 am Post subject: Re: Lowered Bus, what size tires? |
Might have to sacrifice style for function here and raise the beam up an inch. Or tub it. Cheapest way to do it other than new tires. But even then you’re going to running really low profile so the ride is going to be harsh and the danger of blowing a tire and bending rims. Then you have the steering box issue, raising it? A lot to consider here. How far is your customer willing to go for the look? Maybe not putting three people up front? _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk |
Glenn  Mr. 010
Posted: Wed May 28, 2025 9:30 am Post subject: Re: Lowered Bus, what size tires? |
pondoras box wrote: |
Might have to sacrifice style for function here and raise the beam up an inch. |
dropped spindles _________________ Glenn
Member #1009
#BlueSquare
Posted: Wed May 28, 2025 10:01 am Post subject: Re: Lowered Bus, what size tires? |
Probably need a narrowed beam with the disc brakes. Nobody’s disc brakes are zero offset I don’t care what they say. What rims is he running? Rubbing inside or outside of wheel tub? Still a lot of variables. Smaller tires are usually a band aid. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop
Glenn  Mr. 010
Posted: Wed May 28, 2025 10:05 am Post subject: Re: Lowered Bus, what size tires? |
Probably need a narrowed beam with the disc brakes. Nobody’s disc brakes are zero offset I don’t care what they say. What rims is he running? Rubbing inside or outside of wheel tub? Still a lot of variables. Smaller tires are usually a band aid. |
They are the original spindles that were modified to lower the front the match the rear which had the reduction boxes removed. _________________ Glenn
Member #1009
#BlueSquare
Erik G Samba Member
Joined: October 16, 2002 Posts: 13546 Location: Tejas!
Posted: Wed May 28, 2025 10:17 am Post subject: Re: Lowered Bus, what size tires? |
185-60-15 was a dumb suggestion
165-65-15 will work but will drop it lower. We used to use 165-50-15 to get real low. Or don't put 3 peeps up front _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Airkewld Samba Member
Joined: November 14, 2003 Posts: 3190 Location: Goodyear, AZ USA
Posted: Wed May 28, 2025 3:01 pm Post subject: Re: Lowered Bus, what size tires? |
Erik G wrote: |
165-65-15 will work but will drop it lower. We used to use 165-50-15 to get real low. Or don't put 3 peeps up front |
He doesn't want to get real low. The 185/60-15 works amazing on my bus with zero rubbing and is 1.75" smaller in diameter than stock. 4" smaller tire is not what Glenn or his customer wants.
Glenn, I got you with this as we are also talking via email. Adjust those shocks and you should be there. Good luck brother! _________________ TheSamba members-only discount - TheSamba
FAQ - https://airkewld.co/FAQ
View our Industry Leading Products - https://www.airkewld.com/Products-s/2322.htm
We made a iPhone Ringtone with a Classic VW Turbo Engine - https://airkewld.co/RingtoneTurbo
YouTube Channel - https://airkewld.co/SubSamba |
Shoyrtt Samba Member
Joined: August 21, 2010 Posts: 1098 Location: Redlands, CA
Posted: Wed May 28, 2025 3:57 pm Post subject: Re: Lowered Bus, what size tires? |
175/65/15s up front and 215/70/15s in the rear.
Glenn  Mr. 010
Posted: Wed May 28, 2025 4:26 pm Post subject: Re: Lowered Bus, what size tires? |
Airkewld wrote: |
Glenn, I got you with this as we are also talking via email. Adjust those shocks and you should be there. Good luck brother! |
Pete, yes thanks for reminding me that the shocks are adjustable. As soon at the customer drops it off we'll adjust the shocks and take it for a ride.
Unfortunately the customer didn't have it registered and insured so we put very few miles on it before he took it. If it was legal we would of adjusted them before.
Btw, the says it drives amazingly _________________ Glenn
Member #1009
#BlueSquare
EasyNow Samba Member
Posted: Wed May 28, 2025 7:55 pm Post subject: Re: Lowered Bus, what size tires? |
I have the very same straight axle, flipped spindles kit from Airkewld on a stock front beam. While I haven't tried three passengers in front, no rubbing with two front passengers.
Front - 185/60-15
Rear - 205/60-15
Sits level with no +/- rake.
Posted: Thu May 29, 2025 4:34 am Post subject: Re: Lowered Bus, what size tires? |
EasyNow wrote: |
Front - 185/60-15
Rear - 205/60-15
Looks perfect! Fantastic job! _________________ TheSamba members-only discount - TheSamba
nandonation Samba Member
Posted: Tue Jun 24, 2025 3:14 pm Post subject: Re: Lowered Bus, what size tires? |
Very informative post regarding lowered buses and tire size. I'm currently in the process of lowering my 1967 vw bus. My suspension consist of the following. Up front, 4 inch drop spindles on a stock beam, stock shocks. The rear stock transaxle, RGB delete, straight axle conversion kit, adjustable spring plates, stock shocks. Rims African Sprintstars. Front 15x4.5 and the rear 15x6.
My question to you guys is tire size option for this suspension setup. I've been told to run a 155/60 up front and 195/65 in the rear. I don't want to have the bus so slammed so I'm asking for your feedback on other tall tire size recommendations that will work with no rub or hopefully minimal rubbing along with shocks options too.
if anyone is asking why I chose to go with a 4 inch drop spindle? I was constantly told a 4 inch drop spindle keeps the front suspension geometry in the stock position and in addition, you can use all stock components or something along those lines. So that's why. Thanks again in advance for your feedback!
front tire option:
1-155/60/15
2-165/50/15
3-165/65/15
4-185/55/15
5-185/60/15
rear tire option:
1-195/65/15
2-205/60/15 |
NUTSFORBUSES Samba Member
Joined: December 08, 2016 Posts: 580 Location: I don't recognize it anymore
Posted: Tue Jun 24, 2025 8:43 pm Post subject: Re: Lowered Bus, what size tires? |
R:IRS installed w 15" 205/65
F:Flipped spindles w 15" 185/55 - Stock Beam-added sway bar
I used 15" wheels, but Moved the centers OUTBOARD about 5/8"+
Cut the center out, then welded them back OUTWARD to get more meat on the ground & under the Bus. 4 wheel disc's.
Never rubs
Tough to do with custom wheels, but I did not try.
Used Koni's and it rides well. Didn't want to use rubber band size tires also.
Pushing 200 HP so I needed the rubber & a bit closer to the asphalt.
When loaded up w people, dog, and Stuff, she handles pretty good, but high enough to stay away from the front legs & the street< the 15" helped a lot. Gimme an extra 1/2 " and I can do wonders!
I like the OG wheel look w CAP, it just say's "VW"
****FORGOT TO ADD : These are 5.5" wheels all around-Moving the center section allows the wider wheel in front on a stock beam
_________________ kaiser kills kids.com
Last edited by NUTSFORBUSES on Wed Jun 25, 2025 5:40 am; edited 2 times in total |
Teeroy  Samba Member
Joined: April 20, 2003 Posts: 3840 Location: Eastern WA
Posted: Tue Jun 24, 2025 11:17 pm Post subject: Re: Lowered Bus, what size tires? |
They also make a 165 60 15, I'm running them on the front and 185 65 15 on my 65 micro with 4.5" front and 5.5" rear wheel
_________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Glenn  Mr. 010
Posted: Wed Jul 09, 2025 3:50 pm Post subject: Re: Lowered Bus, what size tires? |
Update:
Setting the shocks to a firmer setting and going to a smaller tire solved the problem. _________________ Glenn
Member #1009
#BlueSquare
Posted: Wed Jul 09, 2025 4:00 pm Post subject: Re: Lowered Bus, what size tires? |
Glenn, what brand adjustable shocks are you using in the front and running in the rear? |
Glenn  Mr. 010
Posted: Wed Jul 09, 2025 4:45 pm Post subject: Re: Lowered Bus, what size tires? |
nandonation wrote: |
If I remember correctly they are Fox, they came from Airkewld, so maybe Pete can expand _________________ Glenn
Member #1009
#BlueSquare
