Wreck Samba Member
Posted: Thu Jul 10, 2025 5:46 pm Post subject: Re: Endcastings flow? |
Earlier you stated this
"According to my mathing, with he help of some online calculators , a N/A 2276 turning 5500 rpm at 100% VE flows 220 cfm. If your running a single center mount carb then you have 2 endcastings, each capable of flowing minimum of 110 CFM to as much as 130 CFM.
Even if you only counted the flow per cylinder at a time, each one only flows 55 CFM , which is half what the endcasting is capable of.
Tell me if im missing something here?
I am attempting to get you to visualise how low 55cfm is and that the flow numbers for the end castings is per throat , not both . So a stock head at 0.100" lift is in the ball park of 55cfm .
If I get a chance tonight , I'll plug a 2.3lt 4 cylinder etc into pipemax and 5500 at 55CFM and see what the VE is . |
BFB Samba Member
Posted: Thu Jul 10, 2025 6:05 pm Post subject: Re: Endcastings flow? |
Wreck wrote: |
Oh i know 55 cfm is low. Have you ever plugged in the numbers for what a 1600’s cfm is? It’s stupid low, like 120 cfm , which is why ppl have trouble with much bigger carbs ( single ) than a pict. hell, this is the same scenario even with bigger engines too and why theres so many post of having flat spots and needing to “roll on the throttle” vs being able to floor it.
I also didnt say anything about those flow numbers being for both throats, i was meaning the numbers for both end castings, so the whole flow for the engine ( by using two endcastings). But being totally honest i did not think about only one throat being flowed at a time until you mentioned it.
However, my point then was that that would raise the total flow capability of the end casting as a whole, maybe not doubling the number but still more than the single throat’s cfm.
As far as you pipemax, i think your not listening and still dwelling on the 100% VE. I dont give a shit about VE, never did. Please re-read what ive written.
I think your trying so hard to make me see your point that you’re not seeing mine _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
modok Samba Member
Joined: October 30, 2009 Posts: 27662 Location: Colorado Springs
Posted: Fri Jul 11, 2025 7:05 pm Post subject: Re: Endcastings flow? |
I have a set of four 48 IDAs for a small block ford, 40mm vents
What is the cfm rating of that, in caveman units?
around 1500 or so?
I know it's not enough to make "real" power by todays standards
but beyond 450hp/6000k is where the block starts to crack in half so it's perfect IMO |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7834 Location: Videbaek Denmark
Posted: Sat Jul 12, 2025 1:20 am Post subject: Re: Endcastings flow? |
modok wrote: |
around 1500 or so?
On a V8 ? around 600 _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
BFB Samba Member
Posted: Sat Jul 12, 2025 10:26 am Post subject: Re: Endcastings flow? |
Alstrup wrote: |
modok wrote: |
around 1500 or so?
On a V8 ? around 600 |
600 what ? CFM or HP? _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
BFB Samba Member
Posted: Sat Jul 12, 2025 10:41 am Post subject: Re: Endcastings flow? |
As far as end castings, what about the T1 efi ones that are split. Anyone compare their flow to the “normal” DP ones? _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
modok Samba Member
Posted: Sat Jul 12, 2025 11:34 pm Post subject: Re: Endcastings flow? |
Not sure which ones you mean, but I'm pretty sure all the OEM EFi manifolds are significantly smaller diameter, under 30mm ID |
Wreck Samba Member
Posted: Tue Jul 15, 2025 9:10 pm Post subject: Re: Endcastings flow? |
throwing this out there .
Has anyone welded some helmholtz resonators to the end castings to even the intake volume per runner ,mainly to help with low rpm /idle quality and even AFR ? when using a larger duration cam . |
modok Samba Member
Posted: Tue Jul 15, 2025 10:02 pm Post subject: Re: Endcastings flow? |
I've looked into it, simulated putting a resonator anywhere I could think possibly make sense in the handlebar intake but so far found nothing useful.
The idea of small plenums on either side does not work well overall either. |
earthquake Samba Member
Joined: January 10, 2008 Posts: 4001 Location: SANDY VALLEY, NEVADA
Posted: Fri Jul 18, 2025 2:17 pm Post subject: Re: Endcastings flow? |
Has any body ever used a set of short K-dog manifolds and made a nice flowing upper manifold that bolts to them? It might be a little tall.
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Rob Combs Samba Member
Joined: December 30, 2020 Posts: 529 Location: South Bay LA, California
Posted: Fri Jul 18, 2025 2:38 pm Post subject: Re: Endcastings flow? |
earthquake wrote: |
eQ |
This just gave me an idea for what to do with my cracked race trim manifolds. A few pie cuts to make a sharper turn into a regular center section and back in business… |
BFB Samba Member
Posted: Fri Jul 18, 2025 3:47 pm Post subject: Re: Endcastings flow? |
earthquake wrote: |
eQ |
Pics? _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
BFB Samba Member
Posted: Fri Jul 18, 2025 4:18 pm Post subject: Re: Endcastings flow? |
so, im going to assume none of you know otherwise someone wouldve chimed in to educate me. But on further reading & research ( which btw is not easy to find ) , cfm ratings on intakes are not comparable to cylinder cfm ratings, in a similar way to carb cfm’s ratings being different, not only between 2 & 4bbl but between carbs, heads, and engine. Im not going to try to explain it because 1. I dont remember enough specifics ( although i did save what i found ) and 2 i spent too much time looking for what i found.
Also read a lot that stated making flow numbers of heads & intake your primary focus, is a huge mistake as it’s only one factor in several dozen. All the other points made a lot of sense. Really seems flow numbers are another one of the marketing ploys that weve been taught to focus on _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Brian_e  Samba Member
Joined: July 28, 2009 Posts: 3990 Location: Rapid City, South Dakota
Posted: Fri Jul 18, 2025 5:43 pm Post subject: Re: Endcastings flow? |
BFB wrote: |
Really seems flow numbers are another one of the marketing ploys that we've been taught to focus on |
Correct. Flow numbers are really irrelevant, and are a ways down on the list of important factors when choosing heads.
Average airspeed is FAR more important, and an easy way to determine how efficient a head really is.
Comparing two head flowed on different benches is also near worthless.
Flow numbers are just like comparing peak HP Dyno numbers. They really don’t tell much about the engine. Just like looking at average airspeed, a guy is much better off looking at the average torque numbers rather than peak numbers.
Brian _________________ So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts |
Posted: Sat Jul 19, 2025 5:58 am Post subject: Re: Endcastings flow? |
Rob Combs wrote: |
earthquake wrote: |
eQ |
K dog (Kadron) manifolds dont flow much better than a set of mildly massaged end castings unless they are heavily welded and modified. So not much idea in that. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
