ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 3489 Location: West Coast (Michigan's)
Posted: Fri Jul 11, 2025 8:13 am Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me |
Look like the Led Gravity lights for $700. ouch! _________________ Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes |
indianpeaksjoe Samba Member
Posted: Fri Jul 11, 2025 11:23 am Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me |
ORANGECRUSHer wrote: |
Look like the Led Gravity lights for $700. ouch! |
Had I known I was rebuilding the engine, trans and a ton of other stuff, I probably would have bought something cheaper
-Joe _________________ Adventures in owning a 66 beetle |
DesertSasquatchXploration Samba Member
Posted: Fri Jul 11, 2025 12:06 pm Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me |
No matter how bright mounting the lights 2 feet off the ground up front is pointless just going to light up the ground 10 feet in front or the woop 3 feet ahead. Angle them back you just light up the sky and blind the shit out of other drivers. Put them on the roof or at least on the hood. _________________ Key is to have downward travel Preload keep both wheels on the ground at all times once you lift a tire your DONE. Guys worry about clearance instead think of the opposite you want the suspension to drop that tire in the hole and keep you going. A spider for example they keep their body low but their legs can reach pretty far so they don't (bottom out) |
Posted: Fri Jul 11, 2025 12:21 pm Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me |
I have driving spots on the roof, flood spots on the bumper and headlights in the ... headlights? I like em! I just cruise double track and appreciate that the multiple sets of lights get rid of those shadows that make every rock look like a cliff at night.
The stock LEDs in my wife's LJ are brighter than those KC headlights on the beetle and when you drive the Jeep at night people think you have the high beams on. I think those mopar lights are pretty expensive though.
Schepp Samba Member
Posted: Fri Jul 11, 2025 1:27 pm Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me |
Low mounted yellow lights are great for fog and dust visibility.
I put the Lasfit (Diode Dynamics Knockoffs) fog pods on all our cars. Crisp clean cut-off lenses don't blind other drivers. Factory wired for waterproof DT connectors. $130/pair. So far they've survived 10yrs of daily use with no condensation inside.
Money spent on quality round 7" headlights is a good investment. I put Jeep lights in my car. Wish I would've spent a little more on a better brand like Joe did. Being able to see well at night will help keep you safe. |
Posted: Fri Jul 11, 2025 4:22 pm Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me |
She's alive!
jimmyhoffa Samba Member
Joined: February 16, 2014 Posts: 1176 Location: St. Louis
Posted: Sat Jul 12, 2025 9:15 pm Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me |
Nice! That sounds decently responsive for a single that doesn't have much tuning time on it. Moab was the best my single ever ran, just due to atmospheric conditions in general, I suspect.
Sidenote, I didn't know you guys even knew about Diode Dynamics I guess I assumed it was sort of a toasted ravioli situation. I just figured all the Midwest and Northern, and maybe East coast guys used Diode Dynamics, and you guys out west all ran Baja Designs. I live about 30 mins from Diode Manufacturing HQ, I guess it really has blown up over the last few years! DD company open house is August 9th if anyone happens to be in StL, I'll show ya around. _________________ 1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous. |
Posted: Tue Jul 15, 2025 9:46 am Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me |
The engine and new clutch are in. Hoses and wires getting hooked up today.
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11021 Location: Oregon
Posted: Tue Jul 15, 2025 10:13 am Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me |
Getting closer to the day it's finally coming home.  _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!  |
Posted: Tue Jul 15, 2025 10:30 am Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me |
I have to admit there has been a little bit of scope creep in this project.
I originally called them to put on rear discs, a spin on oil filter adapter and new shocks. Which then turned into rebuilding the motor and trans because I knew they were messed up but was in denial. They were just worse than I had assumed. And then we added an LSD, modding up the motor for more power, new front bumper, repainting the old rear bumper, adding oil temp, pressure and tach, new shifter bushings, new clutch, remote oil filter, oil breather, etc.
I really should have had them cut off the trailer hitch on the rear bumper before getting it powder coated, oh well...
Posted: Tue Jul 15, 2025 10:44 am Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me |
they sure are taking their time _________________ Brian H.
Posted: Tue Jul 15, 2025 11:32 am Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me |
they sure are taking their time |
Shhhh, Brian. You're saying the quiet part out loud. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Tue Jul 15, 2025 12:39 pm Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me |
that's cuz I'm stoopid  _________________ Brian H.
Posted: Tue Jul 15, 2025 3:23 pm Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me |
Yeah, I know, I was out of town for 6 weeks and did not push them, so part my fault but also... nothing I can do about it.
Posted: Today 11:42 am Post subject: Re: Who's baja is getting a motor rebuild and trans rebuild? Me |
indianpeaksjoe wrote: |
It drives!!!
-Joe |
Sweet!
The only things missing in that video is, You your dog and the car offroading in Moab. Lol! _________________ I have learned over the years.
Buy Once, Cry Once!
