Spowers Samba Member
Posted: Tue Jul 15, 2025 10:35 am Post subject: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? |
Only about 500 miles on a 1971 rebuilt 1600cc. While driving at a steady 50mph the engine suddenly shuts off and I easily coast to a safe spot on the side of the road. Maybe overheating since it is July? After waiting about 45 minutes I crank the engine but something doesn't sound right. Low compression?
I pop off the valve covers to have a look and as my friend is cranking the engine, the cylinders seem to move freely but there is no intake/exhaust valve movement on either side.
Did the cam shaft disengage from the crank shaft? If so, how is that possible since they are directly geared to each other? Did the cam just break between the gear teeth and the lobes?
Has anyone heard of this happening?? Any advice would be much appreciated. Thanks![/b] |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 343 Location: Eastern north carolina
Posted: Tue Jul 15, 2025 10:42 am Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? |
If none of the valves are moving when you rotate the engine it would seem that the camshaft gear is either stripped or broken. That would be my guess. Good luck-Bob |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11080 Location: Oregon
Posted: Tue Jul 15, 2025 10:58 am Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? |
Never heard of this happening but, I guess anything is possible.
Pistons moving and camshaft not moving may indicate a broken crankshaft.
It happens. I don't recall seeing a crank broken on the cam gear end. The ones I have seen usually break near the #2 main bearing.
OP, grab the crankshaft pulley and see it it turns rather freely, like it's not connected to anything inside the engine. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7834 Location: Videbaek Denmark
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3315 Location: Hamble, Hampshire, UK
Posted: Tue Jul 15, 2025 11:29 am Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? |
Maybe somebody left out the Woodruff key on the camshaft drive gear on the crank and it took a bit of heat to let go and start spinning. _________________ Ancient vehicles and vessels
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52777 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Jul 15, 2025 11:41 am Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? |
I'm betting the oil has a silvery sheen. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33083 Location: Hot Arizona
Posted: Tue Jul 15, 2025 2:03 pm Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? |
Spowers wrote: |
Only about 500 miles on a 1971 rebuilt 1600cc. |
Did a shop rebuild this?
Did you?
What's the experience level of the rebuilder? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Jul 15, 2025 2:16 pm Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? |
It was rebuilt in a shop but the 12 month warranty is expired. I guess I'll tear it down to see what happened. This will be my first time into the crank case of a VW. First time for everything...Wish me luck...Thanks for the feedback... |
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1404 Location: North Carolina
Posted: Tue Jul 15, 2025 2:20 pm Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? |
Back in the late 70s or early 80s I had to go help a friend tow his bug back home that had suddenly quit running for no apparent reason. Similar to the op…no valve train movement while cranking engine over. When we opened the case we found the camshaft broken in 2 places. Cam was an AP2 which was produced by Resolit of Brazil back in the 70s. |
Brian_e  Samba Member
Joined: July 28, 2009 Posts: 3990 Location: Rapid City, South Dakota
Posted: Tue Jul 15, 2025 2:23 pm Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? |
I had a core engine that broke the cam right behind the flange for the gear.
Brian _________________ So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23131 Location: Oklahoma City
Posted: Tue Jul 15, 2025 2:52 pm Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? |
I am betting the cam broke. I have had a cam gear on type 4 strip the teeth off from a nut that came loose from the oil pump.
No matter what strips all the teeth off, it will not be a silent stoppage when it happens.
Ray |
BFB Samba Member
Posted: Tue Jul 15, 2025 4:18 pm Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? |
Spowers wrote: |
… Any advice would be much appreciated. Thanks![/b] |
If the cylinders are moving , that there may be your problem.
Joking aside, and assuming you meant the pistons seem to move freely, how’d you determine that? _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
Posted: Tue Jul 15, 2025 4:50 pm Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? |
Spowers good luck on the teardown, tough break but you may be able to salvage some parts of your engine. If you do not already have a copy, I suggest you get How to rebuild your Volkswagen engine by Tom Wilson. It will help you with the proper sequence with the disassembly to try to salvage what you can. Good luck-Bob |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4926 Location: sanger ca
Posted: Tue Jul 15, 2025 5:19 pm Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? |
BFB wrote: |
Spowers wrote: |
Joking aside, and assuming you meant the pistons seem to move freely, how’d you determine that? |
Start with this _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Cusser Samba Member
Posted: Tue Jul 15, 2025 5:46 pm Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? |
If it does turn out to be camshaft-related, I just want to throw in that I have stock VW camshafts and gear in both my 1835cc and 1600cc rebuilt engines. 1835cc was built by me in 1986, and the 1600cc in 2017. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2882 Location: HdG, MD & NJ
Posted: Tue Jul 15, 2025 7:15 pm Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? |
Broken cam bolts? Please report what you find. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
earthquake Samba Member
Joined: January 10, 2008 Posts: 4001 Location: SANDY VALLEY, NEVADA
Posted: Mon Jul 21, 2025 3:38 pm Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? |
Did someone say " Catastrophic Failure"?
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
nsracing Samba Member
Posted: Thu Jul 24, 2025 6:21 am Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? |
Spowers wrote: |
Over 12 mos and only 500 miles?
well- time for you to learn the hard way. As I always say to people - if you will be w/ this VW have 2 motors. Always.
Enjoy. |
veedubcrazy Samba Member
Joined: February 14, 2005 Posts: 2175 Location: La Porte, Tx.
Posted: Thu Jul 24, 2025 8:02 am Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? |
earthquake wrote: |
eQ |
OMG!  _________________ 1967 Deluxe Sedan
1971 Squareback - "The Silver Surfer" |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11158 Location: Huntington Beach, CA
Posted: Thu Jul 24, 2025 8:18 am Post subject: Re: Catastrophic Failure in a rebuilt 1971 Super Beetle 1600? |
veedubcrazy wrote: |
earthquake wrote: |
eQ |
OMG!  |
That should buff right out!
OP - camshaft snap. Gear strip. Especially on rebound units. You might want to ask if that was the case. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
