Gauge upgrades, when?
Schuylersister
Schuylersister is offline
PostPosted: Wed Jul 16, 2025 5:13 pm    Post subject: Gauge upgrades, when? Reply with quote
Help me think this through please:
I'm having the coolant flushed and the thermostat and thermostat housing upgraded to the aluminum style by a professional Vanagon shop, H2O Vanagon in Sacramento. Nothing wrong with the engine just time for a flush and it seems important to do the system upgrades then. Thinking I should monitor the temp guage with my existing guage after I do this to see if things are different or the same with my temp readings. I think the same readings would be good.
So next step is electrical upgrades. The fuel guage is not accurate and the others may be wonky too. My fuel tank, pump, and lines were upgraded in 2018. No fuel leaks. Would replacing my dash cluster guages make sense as a first step in correcting this problem?
1990 2.1 WBX 146K
Chris-a
Chris-a is offline
PostPosted: Wed Jul 16, 2025 5:24 pm    Post subject: Re: Guage upgrades, when ? Reply with quote
Replacing with? Speedhut or what? SURE, but it's not cheap. The only oem gauge of my van that works is the speedometer. Ive got a $30 amazon fuel gauge, a voltmeter from Napa, a generic oil pressure gauge and a VDO coolant gauge. I also have a scangauge(I already had from previous vehicle) that monitors the RPM's on my tdi. All of those excess gauges live in a couple 3 pack mounts, and velcroed to my dash.
Does it look a bit chaotic and strange, yes.
Im casually saving to replace them with a few matching new Speedhut gauges, but that's going to be over a grand and Ive got probably $125 in gauges and guage holders in my Frankenstein gauge set....
How do you want to spend your money?? Id rather buy diesel and travel instead of having matching gauges. YMMV
I gotta have nice tools, just look at the cars I drive.
?Waldo?
?Waldo? is offline
PostPosted: Wed Jul 16, 2025 5:28 pm    Post subject: Re: Guage upgrades, when ? Reply with quote
In what way is the fuel gauge wonky? The fuel gauge fluctuates significantly because of the design of the tank and the position of the sender within it. If that is what you mean by wonky, then gauge swaps are not going to be helpful.
E1
E1 is offline
PostPosted: Wed Jul 16, 2025 6:30 pm    Post subject: Re: Guage upgrades, when ? Reply with quote
The latter part of your sentence points to classic dash foil failure.
Greg Eaton’s factory-style upgrade to the VW foil is *awesome*. It works and is significantly less expensive than the other “non-original” designs out there.
[email protected]
1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
— Colin Chapman
SCM
SCM is offline
PostPosted: Wed Jul 16, 2025 6:49 pm    Post subject: Re: Guage upgrades, when ? Reply with quote
I’m with Waldo - elaborate on “wonky” because what you’re experiencing may just be “normal” Vanagon stuff.
Also, with your new aluminum t-stat housing you might experience a small difference in where your temp gage needle points even though the coolant temp is the same*. Probably best to get an infrared thermometer and take some base line measurements at different places (radiator, coolant hoses) before the work is done so you can have actual numbers to compare to afterwards.
* it has something to do with the difference in electrical resistance between the old plastic housing and the new aluminum one. GoWesty used to supply a little gizmo to adjust for that. I’m not sure if that’s still the case though.
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
4Gears4Tires
4Gears4Tires is offline
PostPosted: Wed Jul 16, 2025 8:23 pm    Post subject: Re: Gauge upgrades, when? Reply with quote
Did you replace the fuel level sender in 2018 when you did your tank upgrades?
Because I did when I redid my fuel tank and now my fuel gauge doesn't read accurately. I don't know if this is also a problem with 2wd vans, but the fuel level sender is definitely an issue with 4wd vans. Is 2/3s completely full?
zerotofifty
zerotofifty is offline
PostPosted: Wed Jul 16, 2025 9:26 pm    Post subject: Re: Gauge upgrades, when? Reply with quote
Having driven a VW that never had a gas gage most of my life, a wonky gas gage is of little concern, and the nice thing about the Van is that the speedometer includes a trip meter. My Bug had neither a gas gage nor a trip meter.
I use the trip meter in me Van to determine time to fill up. sure me gas gage works in the Van, but I just be used to using the trip meter.
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
Schuylersister
PostPosted: Thu Jul 17, 2025 6:21 am    Post subject: Re: Gauge upgrades, when? Reply with quote
Hey thank you all so far great info herein!
E1-that link will be very useful
Waldo-the wonky is like I fill up the tank, registers full then after about twenty miles on OD it's dropped to like 3/4 or 2/3 full.
4Gears4Tires- not sure if the sender was replaced with the tank but I'm going assume yes.
I've been keeping mpg on trips and around town. Basically getting between
15-18 mpg. Using the trip OD so never go much more than 200 miles between fueling up. But, gosh I'd like to push that further. What trip mileage do you all use for fill ups? I mostly (95%) use 91 octane gas and mostly fill up at Chevron with Techron in USA but when in Baja I use 89 or 92 octane.
SCM
SCM is offline
PostPosted: Thu Jul 17, 2025 6:28 am    Post subject: Re: Gauge upgrades, when? Reply with quote
I also start looking for a gas station at 200 miles but, driving my automatic at 75 mph, 14 mpg is my normal fuel economy so that range is about what I can expect.
dabaron
dabaron is offline
PostPosted: Thu Jul 17, 2025 7:37 am    Post subject: Re: Gauge upgrades, when? Reply with quote
i get about 18-19 at 70mph, slow down, save fuel Smile
in May i was on 287 and i KNEW i had plenty of fuel left, but the needle was showing empty, going up a hill. on level ground, i had 1/4 tank... i use the trip mileage and like many others, start thinking about fuel after driving 200 miles.
if a vendor came out with a fuel tank that eliminated the camel humps and used a better internal design (baffles!), i'd drop $300 on it no problem.
1991 Vanagon GL Camper
DanHoug
DanHoug is offline
PostPosted: Thu Jul 17, 2025 7:40 am    Post subject: Re: Gauge upgrades, when? Reply with quote
the fuel and coolant temp gauges are adequate when properly working. clean or install a new ground for the gas gauge, verify coolant temp gauge operation with an independent thermometer. if BOTH gauges are acting 'wonky', you may have a dash voltage regulator issue and you can measure voltage to verify its operation.
then, with that many miles on a 2.1, i'd install an oil pressure gauge to watch the trend of oil pressure during hot engine operation and as more miles accumulate. it will be your canary in the proverbial coal mine.
-dan
www.thefixitworkshop.com
nosliwmit
nosliwmit is offline
PostPosted: Thu Jul 17, 2025 9:24 am    Post subject: Re: Gauge upgrades, when? Reply with quote
That's the way mine is too ('87 2-wheel drive). After 25 miles it looks like I've burned a quarter tank, and by 100 miles I'm sitting at a half tank or slightly less. The good thing is it's consistent. My mileage is also very consistent (20 to 22 MPG), so with a 16 gallon tank I know I can do 250 miles with lots of margin. It does take a while to get used to ignoring a fuel gauge on E.
Wildthings
Wildthings is offline
PostPosted: Thu Jul 17, 2025 9:37 am    Post subject: Re: Gauge upgrades, when? Reply with quote
My wife always went by mileage (even though the gauge worked normally) and doing so worked fine for her but three times over the years I hopped into one of our Vans after she had been using it and didn't make it to the filling station 4 easy miles down the road. Sad
riceye
riceye is online now
PostPosted: Thu Jul 17, 2025 9:46 am    Post subject: Re: Gauge upgrades, when? Reply with quote
A few years back I was doing something to the back of the gauge cluster (Replacing bulbs? I don't recall) and I decided to loosen and retighten the brass nuts that secure the dash foil. The fuel gauge responded by behaving in a more rational fashion. Before, after a fill, the needle never quite made it to the top of the range, after it did. It now seems to read more accurately but still wanders with the crown of the road or the direction of the last curve. And upgrade or down to a lesser degree.
'87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig
SoquelDude
SoquelDude is offline
PostPosted: Thu Jul 17, 2025 12:36 pm    Post subject: Re: Gauge upgrades, when? Reply with quote
Sorry, no suggestions for gauge/no-gauge usage, but here's a shout-out to H2O Vanagon. Whatever you decide to do, I'm sure that Stephan's got your back!
'90 Vanagon Westy GL, AT, EJ22E conversion (1993 2.2L Legacy Engine)
SCM
SCM is offline
PostPosted: Thu Jul 17, 2025 3:32 pm    Post subject: Re: Gauge upgrades, when? Reply with quote
The local speed limits on my highways is usually 80 mph so going 75 IS slow.
I'm not going to try and track it down again but the EPA fuel economy for our vans can be found online and on this forum. Autos were rated at something like 14-16 mpg when they were new. I actually get a very consistent 14 mpg in mixed driving too. The only notable improvement I've experienced was 20 mpg during a long downhill drive on a dirt road going 25-30 mph for a couple hours.
The elevations that I drive at could also be a factor.
