Ring and pinion advice.
plotch
plotch is offline
PostPosted: Sun Nov 05, 2023 6:02 pm    Post subject: Ring and pinion advice. Reply with quote
I have a 75 standard with the stock transaxle. Using 225/75x15 tires in the back. Lots of clutch slipping to go slowly enough on the class 4 roads around here. The 75 has a different nose cone mount which might limit swapping.
Needing advice as to which gearing would work best. Hope to tackle the Trans america trail at some point, probably hauling a small trailer. Thanks residents of the dirtpile.
DesertSasquatchXploration
DesertSasquatchXploration is offline
PostPosted: Mon Nov 06, 2023 12:58 pm    Post subject: Re: Ring and pinion advice. Reply with quote
A 4.37 is great with 29 inch tires 235/75x15.
The rear tires you have its going to be a buzz box on the highway. 4.12 would be better if your doing a bit of on road driving. IDK what came standard in 75 you might have a 3.88 or 4.12?
joemama
joemama is offline
PostPosted: Mon Nov 06, 2023 3:52 pm    Post subject: Re: Ring and pinion advice. Reply with quote
I think '75 got the single side cover transmission. If so, stock its 3.88. You should read the sticky on this forum "Transmissions for Dummies". I had a class 11 bug with a 1776, the single side cover 3.88 trans, 215/75/15 tires, and it was a dog on the street, let alone trails. I also have a fiberglass buggy, that has a 1915, 30x9.5x15 tires, and its on its second trans with 4.37 gears. I wouldnt go with anything else. It might not be awesome on the freeway, but its fine, and great off road.
If you do have a single side cover transmission, its the strongest type 1 case built, so you might want to have it rebuilt and modified for 4.37. Both the transmissions on my buggy (one was swing axle, and the 2nd one is now IRS, and a single side cover with 4.37) are prostreet style, meaning 3rd and 4th are stock, not close ratio, so on the sand, or large hills, I rarely hit 3rd, staying mostly in 2nd. The prostreet has several other modifications to help it last. I actually had a 5 rib bus trans in my buggy for a while (4.86), but didnt like the slower shifting and heavier feel, so went back to the type 1 with the 4.37. More fun to drive.
I hope this helps.
plotch
plotch is offline
PostPosted: Mon Nov 06, 2023 5:07 pm    Post subject: Re: Ring and pinion advice. Reply with quote
Thanks guys. Yes it is a single side cover. On the hills around here it is sometimes hard to get out of second. I read all 28 pages last night. It needs to be edited to be of much use. PS: traction is great on the mud, wet leaves and rocks.
plotch
plotch is offline
PostPosted: Tue Feb 20, 2024 9:23 am    Post subject: Re: Ring and pinion advice. Reply with quote
To purchase the correct ring and pinion, to fit transaxle AT 15 11 4; where do i look to determine 8 bolt or 6 bolt? Or if any of you know, thanks.
Mal evolent
Mal evolent is offline
PostPosted: Tue Feb 20, 2024 3:25 pm    Post subject: Re: Ring and pinion advice. Reply with quote
6 bolt was for swingarm. 8 bolt is for IRS.
73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index
plotch
plotch is offline
PostPosted: Tue Feb 20, 2024 6:38 pm    Post subject: Re: Ring and pinion advice. Reply with quote
Thank you.
Stinky123
Stinky123 is offline
PostPosted: Tue Feb 20, 2024 7:27 pm    Post subject: Re: Ring and pinion advice. Reply with quote
You want the lowest that you can get.
4.86 would be perfect....assuming the same price.
There is a rpm calculator on the net. That would help you answer the question if you want close ratio 3rd n 4th.
I wouldn't change tires just yet. But, 235/75 is more common and maybe even cheaper (because it is more common). They would be, theoretically, 75% of 10 mm taller (7-8mm, about 1/4").
You want 2nd gear to be ur best gear. IOW, as soon as you get rolling, you want to shft to 2nd. 1st is weak as it only has a few teeth on it. 2nd has more teeth engaged at the same time.
Mal evolent
PostPosted: Wed Feb 21, 2024 7:21 am    Post subject: Re: Ring and pinion advice. Reply with quote
RPM - MPO Calculator"
MPH = RPM X LRTR / GR X 168
whereRPM means RPM LRTR means Loaded Rear Tire Radius, and GR means FINAL DRIVE GEAR RATIO.
4th gear is an overdrive on my '73, .89:1, so you multiply the ring and pinion ratio by 89 for the final drive ratio/
sodbuster
sodbuster is offline
PostPosted: Mon Sep 23, 2024 10:56 am    Post subject: Re: Ring and pinion advice. Reply with quote
6 bolt is for early 6 volt short axle swingarm boxes. 8 bolt is for 12 volt long axle swingarm and IRS boxes.
There fixed it for you. Smile
Plus if you search them out you can find 8.37 to 1 ring and pinions that have 8 bolt ring gears. These can be scavenged from some mid 60's bus transaxles as well as some Brazilian type 1 trans cores.
Stinky123
PostPosted: Mon Sep 23, 2024 7:43 pm    Post subject: Re: Ring and pinion advice. Reply with quote
https://spicerparts.com/calculators/engine-rpm-calculator
claudio_nahmad
claudio_nahmad is offline
PostPosted: Thu Jul 17, 2025 3:01 pm    Post subject: Re: Ring and pinion advice. Reply with quote
Hey, im at a similar situation.
Ive a stock 1600 type 1 with 205/75x15 tires and a swing axle 4.12 tranny (mexican, stock), the final part of the project is to convert to IRS since there is a considerable camber problem, but im kinda stuck in the drawboard:
- Could buy a full used rear suspension but it comes with a 3.88 AT (~1972-ish single side cover, superbeetle) tranny, i'm against this option since the bug will loose torque at all gears, but the option seems ok since the suspension is in a good state.
- Could buy a used rear suspension without transmission and "convert" the swing axle transmission into IRS, -since 4.12 is ok for me- but im not sure about the process to do so.
Cannot upgrade engine to a bigger one for the moment, so in youropinion what would be the best way to tackle this problem?
thanks
slow & relaxed
- stock 1600 (1584) cc type 1
ORANGECRUSHer
ORANGECRUSHer is offline
PostPosted: Thu Jul 17, 2025 3:25 pm    Post subject: Re: Ring and pinion advice. Reply with quote
what type is rig is this?
bug bodied?
rail?
Makes a big difference.
If it was a bodied car I'd suggest finding a different car with irs. Yes it gets done, but unless you're really good at fabrication I'd leave it alone. IRS pockets can be welded in and use different spring plates and bars and arms obviously. With a body there's a little more concern about getting the right fit.
If it's a rail just find a trashed IRS pan or rail or even better torsion separated from the rig and weld in the torsion with the arms and all.
Not necessary to have the transmission with it in either case. Any IRS would do.
Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes
Scott SD
Scott SD is offline
PostPosted: Fri Jul 18, 2025 12:16 am    Post subject: Re: Ring and pinion advice. Reply with quote
If it has a Mexican swing axle, most likely it is a 4.37 R&P. The Mexican boxes have all the worst parts VW ever used in a trans.
