1967 front shift coupler is loose
NAES
NAES is offline
PostPosted: Thu Jul 17, 2025 11:05 am    Post subject: 1967 front shift coupler is loose Reply with quote
Worked on a good friends 67 westy yesterday figuring out some shifting issues.
While inspecting everything I found the front shift coupler is loose. Its a single screw type shaped like a ring. I tightened it down well past the point of comfort and it was still loose. I removed the grub screw and swapped it with another, same result.
So I would say the ring shaped coupler is wallowed out bit as is the long shift rod dimple.
My first thought is to drill the dimple all the way through and bolt it together. I could try to replace the ring by itself but I still think the shift rod hole won't hold it in place. If you have any other suggestions please post them. It's an odd design having the entire thing held together with a single screw and the ring with minimal surface area.
Thanks everyone!
Barndoor Mafia
Box On Wheels
SBS #00
pondoras box
pondoras box is offline
PostPosted: Thu Jul 17, 2025 4:23 pm    Post subject: Re: 1967 front shift coupler is loose Reply with quote
The set screw is supposed to go into a hole drilled in the shift rod itself. It’s how it indexes the two rods together and have the shifter in the front cup of the shift rod the set screw doesn’t clamp down on the shift rod but just goes into the existing hole and keeps the two parts from pulling apart.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop
Another 65 hardtop
1973 standard bug
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion
NAES
NAES is offline
PostPosted: Fri Jul 18, 2025 8:00 am    Post subject: Re: 1967 front shift coupler is loose Reply with quote
Yup. Got the grub screw in the dimple. Problem is the dimple is wallowed out so no matter how tight its going to wiggle.
Thanks man.
Barndoor Mafia
Box On Wheels
SBS #00
srfndoc
srfndoc is offline
PostPosted: Fri Jul 18, 2025 8:01 am    Post subject: Re: 1967 front shift coupler is loose Reply with quote
Previous comment unrelated.
Ollie W
Ollie W is offline
PostPosted: Fri Jul 18, 2025 8:18 am    Post subject: Re: 1967 front shift coupler is loose Reply with quote
He's talking about this coupler.
campingbox Premium Member
campingbox is offline
PostPosted: Fri Jul 18, 2025 9:05 am    Post subject: Re: 1967 front shift coupler is loose Reply with quote
I think on a 67 both rods just have holes, no dimple. If the nut is tight and it still doesn’t clamp down you might pull it apart and see which piece or pieces are worn.
70bus Premium Member
70bus is offline
PostPosted: Fri Jul 18, 2025 9:31 am    Post subject: Re: 1967 front shift coupler is loose Reply with quote
I've seen one where the collar was rotated and a new hole drilled through the screw hole into the shafts, creating a new and tight connection. The issue is holding everything absolutely still so you don't get your shifting messed up by changing the clock of the tubes. That particular front rod had 2 extra holes, so I imagine they found out the hard way about clocking.
Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater
