1.9 Waterboxer won’t restart after just 2 minutes of running
Envious
Envious is offline
PostPosted: Tue Jul 22, 2025 4:28 pm    Post subject: 1.9 Waterboxer won’t restart after just 2 minutes of running Reply with quote
Bit of history. Only issue was a leaking water pump. After the new pump and thermostat, motor wouldn’t start.
Replaced the temp 2 sensor but still won’t start unless I unplug the sensor or I give it gas while trying to start.
Installed new plugs, new coil, new wires because spark looked a little weak.
Starts right up now BUT will not restart after just a couple minutes of running.
Thoughts?
71 Type 1302 Custom
64 Type 151
63 Type 117 L469 Anthracite
64 Type 361 L575 Nutria
64 Porsche 356c
56 Type 113 L227 Strato Silver
52 BSA C11G
59 Heilite Single Wheel Camping Trailer
56 Allstate Single Wheel
84 Vanagon Westfalia
http://www.thesamba.com/vw/forum/viewtopic.php?t=388225
Wildthings
Wildthings is offline
PostPosted: Tue Jul 22, 2025 4:35 pm    Post subject: Re: 1.9 Waterboxer won’t restart after just 2 minutes of running Reply with quote
Sure you have the wire running to the FI brain hooked to the correct terminal on the coil?
A bad ground would be another likely culprit.
