Type 3 wiring harness
dersy
dersy is offline
PostPosted: Thu Jul 31, 2025 10:53 pm    Post subject: Type 3 wiring harness Reply with quote
Hello. I need to know how to route the wireing harness through the car.
1971 Squareback
Bobnotch
Bobnotch is offline
PostPosted: Fri Aug 01, 2025 10:42 am    Post subject: Re: Type 3 wireing harness Reply with quote
For 66 on (prior to 66, the harness ran thru the left heater channel assembly), if you're meaning the main front (fuse box) to rear, most of it runs along side in the channel under the left door, then pops out near the voltage regulator, then goes up and over the inner fender well then to both the left rear tail light and thru a hole at the front of the engine compartment. From there it runs across the front of the engine compartment to the right side and pops out a hole to the right rear tail light.
In the 72-73 models the wiring harness continues on the inside under the rear seat cushion thru a hole into the engine compartment then splits to both rear tail lights. I hope this helps.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
