Help with clearcoat sand thru and surprise pinholes
timdhawk
timdhawk is offline
PostPosted: Wed Jul 30, 2025 1:13 pm    Post subject: Help with clearcoat sand thru and surprise pinholes Reply with quote
Issue #1:
I got a pretty nasty run in my fresh clear coat and I managed to accidently get down to basecoat and even some faint sealer while working up through the grits: 400-1200. What would be the proper way to fix this, scuff area with 400-600, then a quick squirt of base color and then re-clear the area?
Issue #2:
Somehow I managed to miss these rather obnoxious pin/potholes near a lower door corner!! Is it worth the headache to try and fix them or should I just chalk it up to a learning experience and move on?
bomberbob
bomberbob is offline
PostPosted: Wed Jul 30, 2025 7:25 pm    Post subject: Re: Help with clearcoat sand thru and surprise pinholes Reply with quote
For issue #1, I don't try and sand runs down any more. I bought one of those metal things and just shave them down. Once you learn how they work its pretty slick. I think your plan should work, its what I would do. As long as you rough up the area so the new paint has some "teeth" to hang on to. Otherwise it will peel later.
Issue #2, depends on what kind of end result you desire. Daily driver? How many pin holes do you have?
1968 Beetle torn apart again
1990 Jetta GLI megasquirted, burning E85 (currently in storage)
2004 Jetta turbo GLI
Marion, Iowa
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Thu Jul 31, 2025 8:07 am    Post subject: Re: Help with clearcoat sand thru and surprise pinholes Reply with quote
For issue #1 bomberbobs advice is good. If you have one of the small touch up guns it makes it easier. For item#2 I would leave it as is as part of the cars " character".
jspbtown
jspbtown is offline
PostPosted: Mon Aug 04, 2025 6:25 pm    Post subject: Re: Help with clearcoat sand thru and surprise pinholes Reply with quote
I wish I had some great tips to help but I SUCK at paint corrections. I always ended up sanding the entire panel, some base, then re shooting clear. I would never fix my mistakes (I made TONS of them!) and always just ended up making them worse.
I can say that a nice guide coat before blocking goes a long way towards seeing those pinholes.
