Oil Pressure Switch
leohtbaere
leohtbaere is offline
PostPosted: Mon Aug 04, 2025 10:45 am    Post subject: Oil Pressure Switch Reply with quote
I'm rebuilding/restoring a 73 Super Beetle. I'm new to beetles but it my understanding that my transmission has two sensors on it: the reverse light switch and the oil pressure switch. I have to replace what I think is the oil pressure switch. It's located on the left hand side of the front of the transmission, as shown here.
I bought a replacement switch (https://www.jbugs.com/product/021919081B.html) but when it arrived I found that the threaded section was much smaller that the threads on the transmission. Is there some specific sensor I need to buy that fits here?
baldessariclan
baldessariclan is offline
PostPosted: Mon Aug 04, 2025 11:34 am    Post subject: Re: Oil Pressure Switch Reply with quote
Assuming you have an autostick Beetle/transmission, that hole might be for a neutral safety switch, or oil temperature switch — ref. parts catalog page links below:
http://oacdp.org/type1part/9057.png
http://oacdp.org/type1part/9063.png
vamram Premium Member
vamram is offline
PostPosted: Mon Aug 04, 2025 11:41 am    Post subject: Re: Oil Pressure Switch Reply with quote
From another thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=785183&highlight=neutral+switch
sb001 wrote:
The switch you are seeing on the nose cone is indeed the neutral safety switch for an autostick transmission. Yes the thicker red/ black starter wire went to it first to prevent the autostick from being started in gear.
The other wire you are seeing under the rear seat was for the ATF temperature switch warning light in the dash. On the earlier autosticks there were two temperature sensors- one for Drive 1 gear and one for Drive 2. These sensors were located on the back side of the transmission bell housing, and then the wires coming off both of those went to a temperature switch selector mounted on the passenger side of the autostick transmission housing. If one of the temp sensors sensed the ATF getting too hot, it would send a signal to that selector switch which then sent a signal up through that wire to the ATF warning light mounted in the speedometer. Later autosticks did away with the temp sensor for Drive 1 and the selector switch and just used a single temp sensor for Drive 2 gear and sent the signal directly from the sensor to the ATF warning light.
Here are the wiring diagrams for both the early and later versions of the autsotick:
'75 Super Le Grande...we hardly knew ye. Sold 2025 for peanuts.
Click to view image
Save the Supers!!
leohtbaere
PostPosted: Mon Aug 04, 2025 11:52 am    Post subject: Re: Oil Pressure Switch Reply with quote
Thanks for the suggestions, but it's a manual trans. According to this post here
it's a "Bug IRS-Late" type, the one on the right specifically. Notice the two switches towards the front. The one that faces forward is, I think, the backup light switch. The on facing towards what would be the driver's side is the switch I'm missing. It should only have one blade connector as the wire that connects to it has just the one spade connector.
baldessariclan
PostPosted: Mon Aug 04, 2025 1:36 pm    Post subject: Re: Oil Pressure Switch Reply with quote
Transmission switch for safety belt warning system, maybe? (per 1973 factory wiring diagram).
Cusser
Cusser is offline
PostPosted: Mon Aug 04, 2025 1:45 pm    Post subject: Re: Oil Pressure Switch Reply with quote
I believe that other switch location was for the ridiculous federally-mandated seat belt thing from 1972-1974.
The switch https://www.jbugs.com/product/021919081B.html is the ENGINE oil pressure sending unit. These manual gearboxes do NOT have a gear oil pressure sender.
leohtbaere
PostPosted: Mon Aug 04, 2025 1:56 pm    Post subject: Re: Oil Pressure Switch Reply with quote
The wiring diagram idea was helpful. That switch is part of wiring track 32 component F15. It is a "Transmission switch for safety belt warning system (man. transmission)" so, yeah, it's part of the seat belt warning mechanism. I can't seem to find a replacement. I'm guessing they're sort of rare. In the meantime I'll have to find a way to plug it. Anyone happen to know the thread type?
baldessariclan
PostPosted: Tue Aug 05, 2025 4:14 am    Post subject: Re: Oil Pressure Switch Reply with quote
If you’re wanting that seat belt warning switch, Bug City has used original ones for sale (albeit fairly pricey): https://www.bugcity.com/shop/shop.lasso?pquery=Seat+belt+interlock+switch
Otherwise, you could use a short bolt plus gasket to plug the hole. Not sure of the threading size, but my initial guess would be that it’s probably the same or similar to the threads used for the backup light switch — maybe try swapping it over to check?
bugger-off
bugger-off is offline
PostPosted: Tue Aug 05, 2025 4:49 am    Post subject: Re: Oil Pressure Switch Reply with quote
I don't know why someone would spend that kind of money on a USED part that was an annoying "feature" back then and even more so now! We had a '73 super when I was a kid and I can still hear that godawful noise!
Bruce
Bruce is offline
PostPosted: Wed Aug 06, 2025 3:49 am    Post subject: Re: Oil Pressure Switch Reply with quote
It is a great anti-theft feature. A crook isn't going to put the seatbelt on before trying to hotwire your car.
bugger-off
PostPosted: Wed Aug 06, 2025 6:26 am    Post subject: Re: Oil Pressure Switch Reply with quote
If they're gonna steal it, they're gonna steal it! I don't see this as any kind of deterrent at all.
2381Buggy
2381Buggy is offline
PostPosted: Wed Aug 06, 2025 10:01 am    Post subject: Re: Oil Pressure Switch Reply with quote
Going to hijack this thread for some info. I remember the seat belt interlock system on my mother's 74 Plymouth. The idea was to interrupt current to the starter motor if the front belt(s) were not fastened.
I am confused as to why VW would have had a switch in the transmission for the seat belt system.
Can anyone shed some light on how this worked? Seems like on other makes-an electrical interuption would have stopped flow to the starter motor circuit.
redhot
redhot is offline
PostPosted: Wed Aug 06, 2025 11:55 am    Post subject: Re: Oil Pressure Switch Reply with quote
The '73 user manual states "...as soon as a gear is engaged".
Wiring diagram for '73 shows this as F15, path #32.
For '74 it seems to have changed and no gear lever is mentioned.
Although wiring diagram is 74, it shows the "contact strip" in seat, "safety belt lock, left/righ contact", control relay and what I interpret (maybe not correctly) an interconnect to the driver side door switch. But not the gearbox sender...
2381Buggy
PostPosted: Thu Aug 07, 2025 7:44 am    Post subject: Re: Oil Pressure Switch Reply with quote
Thanks Redhot.
That makes sense. Now I remember that on an auto transmission like my mom's car had-the buzzer and light would come in in gear via the neutral safety switch.
Boy that Plymouth had a loud buzzer. I found the wire connector unhooked under the dash one day and connected it. The next time my mom went to start the car-the light came on and no starter.
It had been unhooked since the day it was purchased new in January 75. The federal mandate had been deleted by that time. The requirement only lasted one year in 74.
leohtbaere
PostPosted: Sun Aug 17, 2025 8:22 am    Post subject: Re: Oil Pressure Switch Reply with quote
As a followup, the threads for that hole are M14x1.5. I bought these:
https://www.amazon.com/dp/B0982RT2C2
and they worked great
