All lights on fuse 2 not working
jasoncvw
jasoncvw is offline
PostPosted: Tue Jul 29, 2025 5:06 pm    Post subject: All lights on fuse 2 not working Reply with quote
Hi group!
We recently brought this 1976 bus home. None of the lights on fuse two are working, but the lights on fuse one work fine. I tried swapping fuse one and two and it made no difference. Looking for advice on what to check next.
busdaddy
busdaddy is offline
PostPosted: Tue Jul 29, 2025 6:02 pm    Post subject: Re: All lights on fuse 2 not working Reply with quote
Welcome!
After you clean up the tabs in the fuse box the fuses clip in to (especially the inner edges of the olse in them) report back, it should make a difference. But I also see what might be some funny business with the wire connections that are visible through the gap in the fuse box plastic, let's see the back of it please.
Слава Україні!
jasoncvw
jasoncvw is offline
PostPosted: Tue Jul 29, 2025 6:48 pm    Post subject: Re: All lights on fuse 2 not working Reply with quote
Thanks, I’ll clean the tabs and take a photo as soon as I can get out to the garage again.
SGKent Premium Member
SGKent is offline
PostPosted: Tue Jul 29, 2025 7:10 pm    Post subject: Re: All lights on fuse 2 not working Reply with quote
also buy a vom if you haven't gotten one. That way you can measure voltages. Or make a 12V light tester so you can chase voltage.
Wildthings
Wildthings is offline
PostPosted: Tue Jul 29, 2025 8:17 pm    Post subject: Re: All lights on fuse 2 not working Reply with quote
I recommend junking the fuses that look like they have zinc strips and buying ones that have brass strips. Use a tiny amount of dielectric grease on the ends where the fuses contact the fuse holder. Spinning the fuses several revolutions once every year or so can cut down on problems as well.
The wiring from the #2 fuse to the marker lights runs near the starting battery and is thus subject to corrosion. You need to make sure the grounds for the lights are functioning well.
jasoncvw
jasoncvw is offline
PostPosted: Mon Aug 04, 2025 6:35 pm    Post subject: Re: All lights on fuse 2 not working Reply with quote
busdaddy wrote:
Welcome!
We got them working. I thought it was due to cleaning, but I wonder if it’s because there was a wire loose to the positive terminal on the battery. I was hoping to link the photos you requested of the fusebox, but I’m having trouble with the upload on samba.
jasoncvw
jasoncvw is offline
PostPosted: Tue Aug 05, 2025 5:12 pm    Post subject: Re: All lights on fuse 2 not working Reply with quote
There was a loose cable to the positive terminal of the battery. I believe that’s what sorted the parking lights. They are working again. Thank you.
SGKent is offline
PostPosted: Tue Aug 05, 2025 5:51 pm    Post subject: Re: All lights on fuse 2 not working Reply with quote
glad you found it. Perseverance paid off. Smile
