Oh! Oh! Towed!
Page: Previous  1, 2
sanchius Premium Member
sanchius is offline
PostPosted: Sun Aug 03, 2025 12:09 pm    Post subject: Re: Oh! Oh! Towed! Reply with quote
Xevin wrote:
^^^ Flame Roasted Green Chilies
Winner winner!
Apologies for the hijack, Dave, let us know what you find.
The Syncro years (2005-16) - The 2WD years (2017-23) - In Hoosierland (2023-now)
Westy & WBX rebuild spreadsheet - Sanchius & Tuna: The Video
Your gold star membership keeps this awesome list going!
djkeev
djkeev is offline
PostPosted: Sat Aug 09, 2025 8:33 am    Post subject: Re: Oh! Oh! Towed! Reply with quote
Well, the Van sat for a few days after arriving home.
No joy on start attempts…….
I decided to go with my gut feeling of wet ignition.
I replaced the coil wire and the Van sputtered to life….. kind of.
No power, backfire, rough running, stalling…..
but it ran well enough to move it to a better spot than where the tow driver dropped it.
It sat there for a day or two or three……
Tried to start it again but no joy.
If it fired, it barely ran.
Water, has to be water in the gas!
Those stupid vapor tanks with the prone to failure rubber seal!!!
I set about pulling hoses and collecting fuel to examine for water mixed with gas.
I replaced the fuel filter and I drained every bit of the fuel system that I could.
Did I have water?
You betcha!!!
But not a lot……
The Van started, it ran and I drove it for the next two days locally.
While it was running, it lacked the low end power off of idle.
I was thinking dirty injectors or needs new spark plugs.
Speaking of spark plugs, I discovered that I drove 10,192 miles with spare spark plugs…… but no wrench !!
I decided to make a run to Reading, about 2 1/2 hours south of me, and set off mid afternoon.
The road is almost entirely hugging the Delaware River.
I did great until about 2 hours in.
It started running horribly!!!
No power, trying to stall, missing, etc.
I pulled over into the Limeport Baseball Stadium, found a shady spot and turned off the Van.
That’s it, no more starting!!!
On a lark, I grabbed my last spare ignition coil and slipped in into place.
It instantly kicked off and idled, purring like a kitchen.
High end power and low end power.
I drove the rest of the way to Reading without any problem.
Now, why does this engine eat ignition coils?
This is the 4th in just three months……….
Ghia
Vanagon
Beetle
DanHoug
DanHoug is offline
PostPosted: Sat Aug 09, 2025 9:52 am    Post subject: Re: Oh! Oh! Towed! Reply with quote
if you have time, post pictures of the coils and brand + part number. VW is very specific as to the coil to be used with their electronic ignitions.
coils die from:
- heat. either internally generated from long dwell times (extensive idling) or external.
- high secondary resistance. this raises the voltage before firing and can deteriorate winding insulation. check your wires and rotor. i assume you are using the NGK BP6ET plugs but make sure they aren't the resistor BPR6ET plugs. i really like the Monel coiled wire spark plug wires.
- supply voltage. can be too high (not likely) but it could also be too LOW where it is running on the ragged edge and any deterioration in coil performance shows up as misfire.
- poor manufacturing, vibration, wrong application
be sure you have removed the black RF shield on both the distributor cap and coil. these conductive shields can cause arcing resulting in misfires. not needed unless you listen to AM radio while driving, and even then, you may or may not notice the absence of the shield. Monel wires go a lot further to suppress RF than those shields.
-dan
www.thefixitworkshop.com
kamzcab86
kamzcab86 is offline
PostPosted: Sat Aug 09, 2025 10:58 am    Post subject: Re: Oh! Oh! Towed! Reply with quote
Import Direct #23-0268. I just installed this into my '90. Before doing so, I tested it and the old (new 10 years ago, not factory-original) green label Bosch coil: both produced the same resistance readings.
It cross-references to VW's part #211-905-115D specified for the 2.1L MV. This same coil is used in multiple VW models, including the K-Jetronic cars from 1985 onward.
Why is that?
The VW parts catalog specifies #101-000-009AA, which is a Bosch WR7CC+, or an NGK BR6ES, both being resistor plugs.
~Kamz Anxious
2016 Golf GTI S
DanHoug
DanHoug is offline
PostPosted: Sat Aug 09, 2025 11:40 am    Post subject: Re: Oh! Oh! Towed! Reply with quote
there's much more to coils than simple primary and secondary resistances... turns ratio, core material, etc. these design parameters affect the impedance the ECU 'sees' as well as the electrical kickback the ECU deals with when the coil ground is switched off. in practice, this can result in the ECU going into oscillation and causing misfires if not actual ECU damage. yes, that coil is working for you. mebbe it's an exact match, but mebbe not. we don't know.
kamzcab86 wrote:
Why is that?
look in the original owners manuals for both Digijet and Digifant vans... they specify NON resistor plugs. with lower power ignition system such as ours, you generally want either resistor wires OR resistor plugs. there just isn't sufficient energy to reliably fire thru a resistor rotor, resistor wires, and resistor plugs.
the VW parts catalog is trying to optimize inventory by reducing the number of stocked items. it isn't the best choice to use a resistor plug in the Vanagon platform. you'll get a higher energy spark with a non-resistor plug, spark that has a better chance to fire thru wear, poor mixtures, deteriorating components.
-dan
kamzcab86
PostPosted: Sat Aug 09, 2025 1:49 pm    Post subject: Re: Oh! Oh! Towed! Reply with quote
Oh, I know. Just offering up some data.
I also know that coils may pass a resistance test, but still don't operate correctly. One reason I swapped out my old Bosch.
D'oh! You're right... Bosch W7CC0.
I know the parts catalog isn't 100% accurate, but I'd have thought spark plugs would be something they got right. Mad
~Kamz Anxious
2016 Golf GTI S
Page: Previous  1, 2
Page 2 of 2
