jpeters Samba Member
Joined: May 06, 2005 Posts: 1063 Location: Woodsfield, Ohio
Posted: Mon Jul 07, 2025 5:36 am Post subject: Re: Official SO42 Details and Changes |
[quote="the bus driver"]Thanks very much, I didn't come across his add..
I've now managed to upload pictures in the gallery.
Those look really nice. Worth much more than $100 in my opinion, even though I hate saying that. I think I paid about $100 just for the covers recently. _________________ '73 Westy
'68 Westy http://www.thesamba.com/vw/forum/viewtopic.php?t=484180
'65 Westy SO-42 http://www.thesamba.com/vw/forum/viewtopic.php?t=435614
'66 Bug
'63 Bug (Big Bore 40hp)
@neverdnf on Instagram |
von_hansel  Samba Member
Joined: June 12, 2006 Posts: 815 Location: Inland Empire
Posted: Thu Jul 17, 2025 1:51 pm Post subject: Re: Official SO42 Details and Changes |
von_hansel wrote: |
I can't remember where I saw a pic of the '66 after the pictures you posted of it at Woodburn, but it was in Gene Langan's collection in CT. Not sure if he still owns it. I spent an hour trying to find the picture but I couldn't.
I found the picture I was looking for. For Reference:
I'm not sure where this bus is today. _________________
Mugatu wrote: |
von_hansel is still so hot right now |
Posted: Mon Jul 21, 2025 2:23 pm Post subject: Re: Official SO42 Details and Changes |
This bus recently popped up in the gallery.
Before this bus popped up, all of the two-tone Tin-Top SO42s that I knew of were no port code with no kit code versions on the mcode plate, had solid windows, and had Euro wall Lamps. This bus was originally painted Sealingwax Red & Beige Grey, it has TE as the export code, has a D42 kit version, and is mcoded for louvered windows.
Can anyone make out what is in front of the "1" on the mcode plate for the build date? Looks like a "W". _________________
Mugatu wrote: |
velvetgreen Samba Member
Posted: Tue Jul 22, 2025 6:48 am Post subject: Re: Official SO42 Details and Changes |
^^ Looks like a "W" to me as well- very odd!?!?! |
Kommercial Samba Moderator
Joined: December 28, 2000 Posts: 1191 Location: San Tan Valley, Arizona
Posted: Sat Aug 02, 2025 8:31 am Post subject: Re: Official SO42 Details and Changes |
Recently picked up a 67 so42 fabrik 11707, UL delivery. The odd part is that it has a stationary sekurit closet window. The rest are Hehr as expected. It also has Mcode 342 which isnt on any lists. It does have the popout fixings for both rear windows though but no popout mounts on any of the others. Was wondering if anyone had heard of mcode342 or a stationary closet window coming from Westy?
On a related note, my so44 was mcoded for 6 popout windows and even has all the mounts on every spot, even though it has the same standard 5 Hehr westy setup. It has the rear passenger popout though (no rear closet on that one which makes the window actually useable). Maybe that was to force a front drivers popout without it being a flipseat? I guess maybe there is no standalone code for that.
srfndoc Samba Member
Posted: Sat Aug 02, 2025 8:42 am Post subject: Re: Official SO42 Details and Changes |
Kommercial wrote: |
On a related note, my so44 was mcoded for 6 popout windows and even has all the mounts on every spot, even though it has the same standard 5 Hehr westy setup. It has the rear passenger popout though (no rear closet on that one which makes the window actually useable). |
Looks like that is actually B42. Look at the 3 below it for comparison. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Posted: Sat Aug 02, 2025 9:27 am Post subject: Re: Official SO42 Details and Changes |
Good eye, you are correct. B42 upon closer inspection.
Ever seen a rear stationary on a so42? |
Posted: Sat Aug 02, 2025 9:34 am Post subject: Re: Official SO42 Details and Changes |
Kommercial wrote: |
Stationary closet glass is standard on an SO42. Most also have the rear two windows with popout mounts but no popouts as part of a normal Kombi build. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Posted: Sat Aug 02, 2025 10:54 am Post subject: Re: Official SO42 Details and Changes |
Kommercial wrote: |
Good eye, you are correct. B42 upon closer inspection |
I spent a while trying to find m-code 342 on other SO42s that we know of, and none of them had it. A lot of 425 and 430. The closest I could find to 342 was 363, 370, and 374. The SO42s with the 3XX m-codes are all Tourist Delivery/ US Service Members stationed Overseas. It now makes sense why I couldn't find a bus with 342 on the m-code plate .
Did you buy your bus from redstock? Let's see some more pics of your bus!
Kommercial wrote: |
a related note, my so44 was mcoded for 6 popout windows and even has all the mounts on every spot, even though it has the same standard 5 Hehr westy setup. It has the rear passenger popout though (no rear closet on that one which makes the window actually useable). Maybe that was to force a front drivers popout without it being a flipseat? I guess maybe there is no standalone code for that. |
Of the roughly 30 SO44's I know of, yours is the only one with jalousie/ Hehr windows. My guess is the previous owner added them. However, anything is possible especially if the original owners were planning on going somewhere with a ton of mosquitos like Central or South America; the jalousies would be more enjoyable than popouts. _________________
Mugatu wrote: |
Clara  Samba Member
Posted: Sun Aug 03, 2025 7:43 am Post subject: Re: Official SO42 Details and Changes |
srfndoc wrote: |
Kommercial wrote: |
Stationary closet glass is standard on an SO42. Most also have the rear two windows with popout mounts but no popouts as part of a normal Kombi build. |
M108 is "without five side windows", which means they only had the one solid in the closet. This in prep for the five jalousies. Almost all SO-42s have this. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Sun Aug 10, 2025 7:15 am Post subject: Re: Official SO42 Details and Changes |
volksbus wrote: |
There's a company in Ohio that is willing to reproduce this variant, which was in my 1967 SO-42. I will post more details here once we have ordering available. |
Wade posted his wedge blocks in the gallery. Is the pattern on the left the same as volksbus flooring in his bus? If so, I have crow on my face
The two buses are a little over 300 Fabrik Nr apart.
I would love to hear your thoughts on the two patterns above.[/b] _________________
Mugatu wrote: |
Posted: Sun Aug 10, 2025 8:29 am Post subject: Re: Official SO42 Details and Changes |
von_hansel wrote: |
I would love to hear your thoughts on the two patterns above.[/b] |
Westfalia would use scraps of random fabric for the stake/poll bags that never showed up in the main tent patterns. I think that is what you're seeing here but we would need to see at least one bus with this pattern intact on the main floor to say it was another known pattern. Its possible it was a pattern used late in production in 67 but so far there is no direct evidence of that, just a couple blocks. Happy to be wrong, just need the proof. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
volksbus Samba Member
Joined: November 02, 2005 Posts: 219 Location: Chicago, Illinois U.S.A.
Posted: Sun Aug 10, 2025 8:32 am Post subject: Re: Official SO42 Details and Changes |
Responding to...
"The two buses are a little over 300 Fabrik Nr apart.
I would love to hear your thoughts on the two patterns above."
We're getting close on having a reproduction lookalike on vinyl, no fiber backing, ready for production. I went over the sample this weekend and were tweaking the colors.
I toad you! It's an OG variant. I'm not in the habit of making up stuff and posting it on The Samba! _________________ "Get in the bus!"
1967 SO-42 Campmobile "Klaus"
1963 DC Truck
1967 Dodge A-108 CampWagon |
mr matt Samba Member
Joined: May 26, 2005 Posts: 982 Location: southeast Pa
Posted: Wed Aug 13, 2025 4:44 pm Post subject: Re: Official SO42 Details and Changes |
Are the glass coverings for the lights available for purchase ?
I understand there are 2 types..
Thanks! _________________ 1955 3-fold semaphore Oval beetle
1971 Convertible beetle
1977 Westfalia, FI, Berlin interior |
Posted: Thu Aug 14, 2025 4:46 am Post subject: Re: Official SO42 Details and Changes |
mr matt wrote: |
Thanks! |
I believe that you'll simply have to look for used ones in the classifieds. When I was searching for mine I was told that there used to be someone who was reproducing them, but I wasn't able to find them. _________________ '73 Westy
'66 Bug
Posted: Sat Aug 16, 2025 7:54 pm Post subject: Re: Official SO42 Details and Changes |
So far, no luck _________________ 1955 3-fold semaphore Oval beetle
Posted: Sun Aug 17, 2025 4:31 am Post subject: Re: Official SO42 Details and Changes |
Thanks!
I must have been searching with the wrong key- word; - light _________________ 1955 3-fold semaphore Oval beetle
Clara  Samba Member
Posted: Mon Aug 18, 2025 10:51 am Post subject: Re: Official SO42 Details and Changes |
They are plastic covers, not glass.
I had made some repros, years ago. If there is interest I can make more. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
