Brucie_Lee Samba Member
Posted: Sun Aug 10, 2025 8:37 am Post subject: Rear wheel remains stiff after handbrake adjustment |
Hi,
I’m in the process of making some adjustments to my handbrake on my 71 Bay as it doesn’t fully engage until about 10 clicks. I’ve had new brake shoes and pads fitted in the past year and the handbrake cables were replaced at the same time as well. I also don’t leave it in the garage with the handbrake on so it shouldn’t be that it’s seized in place anywhere. The van hasn’t driven much in that time as it was winter and I had other house commitments to prioritize over getting it roadworthy.
I thought that since the garage said they did the brake adjustment at the rear I’d be OK to just make adjustments to the handbrake cables in the cab. I got it so that it starts to engage and be difficult to turn the wheels at 6 clicks and it fully engaged and not moveable (without a lot of pushing!) at 8 clicks which seemed like the goal but I’m now finding that after making the adjustment one of the rear wheels remains very stiff and hard to turn once I’ve let off the handbrake.
This doesn’t feel right at all so I loosened off the cable some more until the wheel turned same as the other side but then of course when I pull on the handbrake again the problematic wheel doesn’t lock like the other side does.
I then tried loosening both cables to once again check the wheel resistance and I can turn them both but they’re not spinning freely and will stop almost immediately once I stop trying to spin them. I can’t tell if the brake pads are maybe a tad close to the shoes when no brakes are applied and so I’m just overdoing it when making handbrake adjustments.
Finally, when I do let off some of the tension on the problematic side there is a light “clunk” in what feels like the cable itself, almost as though it’s catching somewhere. After the “clunk” I’ve noticed that the wheel turns easier again but it’s still kind of tight in my opinion.
I’m at a bit of a loss on what to do now. I could remove the wheels and make adjustments to the star adjuster(s) but this was supposed to have been done at the garage I took the van to already so I’d not planned on doing this. Although I do understand that you are supposed to make adjustments to the brakes at this point before doing anything with the handbrake cables. I just don’t want anything to be too tight and burn away the brake pads but I also can’t seem to adjust the cables so they lock on equally!
So I guess my question(s) are:
Is there anything that could be causing the brake pad to not disengage from the shoe on one side straight away?
Is there something that could be causing the handbrake cable to “catch” inside the channel/pipe that it’s threaded through, stopping it from disengaging properly?
Do I need to look for anything else to adjust besides the star adjusters and the nuts at the handbrake in the cab?
These are the main videos I’ve been using for reference in addition to my Bentley and Haynes manuals:
https://m.youtube.com/watch?v=LSbsPrGS0Os
https://m.youtube.com/watch?v=xUOMc2gD2qk
Cheers.
PS - I’m not the most mechanically minded person but I’m trying! _________________ [url=https://www.vw-mplate.com/mplate-57745.png]Click to view image[/URL] |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42787 Location: at the beach
Posted: Sun Aug 10, 2025 9:05 am Post subject: Re: Rear wheel remains stiff after handbrake adjustment |
a handbrake job starts with rear brake adjustment first because that affects the number of clicks. _________________ George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 24071 Location: NYC/Upstate/ROW
Posted: Sun Aug 10, 2025 9:19 am Post subject: Re: Rear wheel remains stiff after handbrake adjustment |
Back wheels up, drums off , confirm workmanship of brakes.
Don’t forget to undo all the park8ng brake adjustment first. _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1653 Location: New Brunswick,Canada
Posted: Sun Aug 10, 2025 9:51 am Post subject: Re: Rear wheel remains stiff after handbrake adjustment |
the book says to pull the brake lever out 6 clicks ,then adjust the cables until the wheels start to drag and can still be turned by hand,
the shoes could be starting to rust in position from lack of use ,after adjustment you may have to drive the bus and do a few brake applications to get them to fully release. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy sold dec 2024
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
Posted: Sun Aug 10, 2025 10:03 am Post subject: Re: Rear wheel remains stiff after handbrake adjustment |
lil-jinx wrote: |
the book says to pull the brake lever out 6 clicks ,then adjust the cables until the wheels start to drag and can still be turned by hand, |
That was the opposite of what I was doing. I thought I had to have the handbrake off/all the way in and then adjust the handbrake cables and then pull it out to 6 clicks to test for resistance in the wheels. Then release the handbrake and making some more adjustments to the cables and trying again til it locked hard on 8 clicks.
I’m guessing that was wrong then?  _________________ [url=https://www.vw-mplate.com/mplate-57745.png]Click to view image[/URL] |
Posted: Sun Aug 10, 2025 10:12 am Post subject: Re: Rear wheel remains stiff after handbrake adjustment |
You dont touch the parking brake cables or lever adjustment until you know the service brake shoes are:
Good lining
Radiussed to the drum
Adjusted to within 3 clicks of drum not turning by hand
Taking on faith that your garage did the above correctly is about a 9% odds. _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4107 Location: Seattle, WA
Posted: Sun Aug 10, 2025 11:18 am Post subject: Re: Rear wheel remains stiff after handbrake adjustment |
Whatever the reason for the wheel hangup, it will be necessary to open up wheel/brake assembly for investigation, unless you can spot something obvious by eyeballing the cable conduit under the bus. Which entails de-adjusting brake shoes and then putting them right again afterward. Since you have so much trust in the work of your "garage", I suggest you leave it all to them. _________________ '67 bug: seized by the authorities
Posted: Sun Aug 10, 2025 2:00 pm Post subject: Re: Rear wheel remains stiff after handbrake adjustment |
kreemoweet wrote: |
Whatever the reason for the wheel hangup, it will be necessary to open up wheel/brake assembly for investigation, unless you can spot something obvious by eyeballing the cable conduit under the bus. Which entails de-adjusting brake shoes and then putting them right again afterward. Since you have so much trust in the work of your "garage", I suggest you leave it all to them. |
Oh believe me, I don’t have much trust in this garage at all! I had to take my bus in to get a bunch of stuff done underneath concerning the suspension and steering etc., that I just couldn’t do myself and some of the work include brake related bits so I just left it in their hands to fix it. But to be honest it’s not a dedicated VW garage but one that’s got an “old timer” who knows them marginally better than the young uns.
I’m trying to get better at taking responsibility for doing my own maintenance where possible though, especially since I live in Norway now where the hourly rate is extortionate for any sort of labor.
I appreciate all the advice I’m getting here though so thank you all.  _________________ [url=https://www.vw-mplate.com/mplate-57745.png]Click to view image[/URL] |
Posted: Sun Aug 10, 2025 2:04 pm Post subject: Re: Rear wheel remains stiff after handbrake adjustment |
lil-jinx wrote: |
i suppose you could do a cable adjustment with the lever in ,and test it at 6 clicks,then readjust as required to get the 6 click resistance. |
This was what I was doing already and it seemed to work for the left hand side but not for the right so I think it’s better to just take a proper look at the rear brakes and make any adjustments there first as I’m not entirely convinced the garage I took it to did the work correctly as they did something wrong when adjusting the steering box also. _________________ [url=https://www.vw-mplate.com/mplate-57745.png]Click to view image[/URL] |
SGKent  Samba Member
Posted: Sun Aug 10, 2025 3:06 pm Post subject: Re: Rear wheel remains stiff after handbrake adjustment |
these are FIFTY year old cars. Someone who worked on them as daily drivers when they were a young person at age 25 - 30 is now 75 - 80 years old. You better learn how to care for your car or have a lot of money to pay a restoration specialist, if they can find one. Rear brakes either went disc or self-adjusting drum some 40 years ago so it is hard to find people who have ever serviced manually adjusted brakes. _________________ George Carlin:
Posted: Mon Aug 11, 2025 5:09 am Post subject: Re: Rear wheel remains stiff after handbrake adjustment |
OK so a quick update on the progress.
I removed the back wheels and drum cover plate and checked the brake pads and everything looked good there and when I had my wife test the brakes up front I could see the shoes moving and making contact the backing off when she took her foot off the pedal. I checked the star adjusters but they were set fine as far as I was concerned.
So then I went to the handbrake cables which I’d fully slackened off and proceeded to pull the level out to 6 clicks and then adjusted each cable until the drums started to be hard to move without a lot of effort on 6 clicks and then fully locked on 8 clicks. I could have it wrong but I’m pretty sure that’s what I read.
When I let off the handbrake the drivers side drum returns to normal and I can spin it without much effort. The passenger side is different though and it stays pretty stiff to turn although it will turn. This is not the same feeling as it was before any adjustment of the handbrake cables to tighten them.
If I lie down under the van I can see the shiny new handbrake cables and if I gently tug or wiggle on the passenger side one I can go back to the drum and it rotates normally with minimal resistance.
So I’m suspecting that perhaps the cable is getting caught or finding some resistance somewhere which is why it’s not fully disengaging the brake shoe. I can see that the cable is greased inside the channel but of course there could be a minor blockage or something that’s just preventing it from fully returning to the disengaged position.
I’m not sure what more I can do now other than fully disconnect the passenger side handbrake cable, somehow cleaning out the guide tube and then re-running it as everything seemed to be fitted right at the drum. Could it be possible to fit the handbrake cable the wrong way round at the drum end?
Since the cables are brand new is this something that can happen and they’ll settle in with repeated use? I haven’t driven it yet since doing the adjustments so I don’t know if that’s also something that will correct itself once I apply the brakes a few times and actually use it rather than checking it while on the jacks.
My other option is to just slacken off the cable so that it doesn’t cause the brake to bind when the handbrake is pulled for that side but then I’ll have uneven grip which isn’t ideal.
I’m just worried about driving around with the back wheel really sticking and wearing out the brake shoes unevenly. I have the equivalent of an MOT on Wednesday though so don’t really want to take everything apart in case I have problems getting it back together again in time.
Apologies for all the questions but any advice is greatly appreciated.
Thanks. _________________ [url=https://www.vw-mplate.com/mplate-57745.png]Click to view image[/URL] |
Posted: Mon Aug 11, 2025 7:40 am Post subject: Re: Rear wheel remains stiff after handbrake adjustment |
you could back off the passenger side cable a little and see if that works,or back off the brake at the star adjusters a little,,if you back off at the wheel ,do a road test and looks for pulling to one side,if it's just a notch or two different from the other side you probably won,t notice any pulling, _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1974 parts bus
SGKent  Samba Member
Posted: Mon Aug 11, 2025 11:33 am Post subject: Re: Rear wheel remains stiff after handbrake adjustment |
is your cable system the two cable system that goes to a spreader and then a single cable up to the e-brake mechanism, or the two cable system all the way to the e-brake system? I forget what year it changed.
If it is the two into one system, I would look at the spreader bar when the brake is pulled to see if it is pulling equally on both sides. If not, you may think you are evenly applying equal force but something else may be going on. _________________ George Carlin:
Posted: Mon Aug 11, 2025 11:38 am Post subject: Re: Rear wheel remains stiff after handbrake adjustment |
Seems like the old cable has worn a groove somewhere along its path, and the new one is getting wedged into the groove when tightened. I'd be looking for any damage or bends in the cable conduit, especially where the cable enters or leaves the conduit. If the groove is in the flexible bowden tube, maybe just giving it a half-turn will keep the cable from running in the groove. _________________ '67 bug: seized by the authorities
Posted: Mon Aug 11, 2025 11:39 pm Post subject: Re: Rear wheel remains stiff after handbrake adjustment |
SGKent wrote: |
is your cable system the two cable system that goes to a spreader and then a single cable up to the e-brake mechanism, or the two cable system all the way to the e-brake system? |
It's the two cable system. I took it out for a drive last night and initially there was a lot of the rubbing sound on the brakes from lack of use but after a few minutes and some firm braking that went away. I haven't tried the handbrake again yet but will jack up the back again tonight and see if it's any better as it could be that the lack of use maybe caused some buildup on the pads and made them a bit "sticky."
Although I feel like if that were the case then they wouldn't have been OK when operating the brakes with the pedal... _________________ [url=https://www.vw-mplate.com/mplate-57745.png]Click to view image[/URL] |
Posted: Mon Aug 11, 2025 11:42 pm Post subject: Re: Rear wheel remains stiff after handbrake adjustment |
kreemoweet wrote: |
Seems like the old cable has worn a groove somewhere along its path, and the new one is getting wedged into the groove when tightened. I'd be looking for any damage or bends in the cable conduit, especially where the cable enters or leaves the conduit. If the groove is in the flexible bowden tube, maybe just giving it a half-turn will keep the cable from running in the groove. |
Yes this is certainly possible. I couldn't see any signs of obvious damage or bends like you suggest but I'll have another look. I haven't had much luck finding what part I might need to order for replacing the conduits so if you have a link or know what they're called that would be great. _________________ [url=https://www.vw-mplate.com/mplate-57745.png]Click to view image[/URL] |
SGKent  Samba Member
Posted: Tue Aug 12, 2025 12:38 am Post subject: Re: Rear wheel remains stiff after handbrake adjustment |
I think the most exposed spot is the welded steel tubes they go into that go under the rear torsion tube. Sometimes someone will put a jack under one and crush it. I don't know how someone would expand that. Maybe large channel locks on the sides to open it a little if that has happened. Follow the cables under the front floor pan and be sure they aren't rubbing on something. _________________ George Carlin:
Posted: Tue Aug 12, 2025 3:38 am Post subject: Re: Rear wheel remains stiff after handbrake adjustment |
You can’t check the star wheels with the drum off. Usually, if you can pull the drum without backing off the stars, they aren’t right _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
