driver’s side sliding window
mojav
mojav is offline
PostPosted: Mon Aug 11, 2025 11:24 am    Post subject: driver’s side sliding window Reply with quote
I was sitting in the van when this happened. I guess the sun hit my window in just the right way and *smack* the whole thing cracked. I think my makeshift bug screen is somehow responsible. Where can I find a replacement sliding middle window? Thanks
mojavmusic.com
View user's profile Send private message Twitter Instagram YouTube Gallery Classifieds Feedback
syncrodoka
syncrodoka is offline
PostPosted: Mon Aug 11, 2025 11:27 am    Post subject: Re: driver’s side sliding window Reply with quote
Where on the planet are you?
Windows are often listed in the classifieds.
mojav
mojav is offline
PostPosted: Mon Aug 11, 2025 11:54 am    Post subject: Re: driver’s side sliding window Reply with quote
Belle Fourche, SD. Cleaned out the broken bits. Got a beautiful opening now. Luckily no rain in the forecast for now…
mojavmusic.com
vanis13
vanis13 is offline
PostPosted: Mon Aug 11, 2025 12:07 pm    Post subject: Re: driver’s side sliding window Reply with quote
mojav wrote:
I was sitting in the van when this happened. ....
I had something similar happen sitting in a parking lot. in my case it was a BB it turned out (could have come from adjoining apartment complex) ....interesting yours looks like if starts from the center of the left edge
mojav
mojav is offline
PostPosted: Mon Aug 11, 2025 12:11 pm    Post subject: Re: driver’s side sliding window Reply with quote
seems like the outer sliding window is really only held on there by the latch. do you think a custom glass company could make a panel that would fit around the latch? people on ebay want $3500 for a whole replacement window which isn’t too much less than I paid for the whole van originally
mojavmusic.com
syncrodoka
PostPosted: Mon Aug 11, 2025 12:25 pm    Post subject: Re: driver’s side sliding window Reply with quote
There are much more affordable options listed in the classifieds here
mojav
mojav is offline
PostPosted: Mon Aug 11, 2025 12:38 pm    Post subject: Re: driver’s side sliding window Reply with quote
https://www.thesamba.com/vw/classifieds/detail.php?id=2699331
does this fit on an 89 Vanagon? I called the other option in Classifieds with the black trim…
mojavmusic.com
67rustavenger
67rustavenger is offline
PostPosted: Mon Aug 11, 2025 12:42 pm    Post subject: Re: driver’s side sliding window Reply with quote
Aren't those side glass panels slightly curved outward?
If so, I don't think a custom glass shop can match the curvature.
My EV has slightly curved slider glass.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
16CVs
16CVs is offline
PostPosted: Mon Aug 11, 2025 1:02 pm    Post subject: Re: driver’s side sliding window Reply with quote
That will work, you can swap the glass out from your frame and swap t into your frame. you need to pull the handle off. I've put them in with the window in the van by pulling the run channel out and using a thin putty knife.
The slider window and 1/4 glasses are all flat.
Stacy
Samba member # 14980
