summerof78 Samba Member
Joined: March 31, 2023 Posts: 184 Location: Wichita, Kansas
Posted: Fri Aug 15, 2025 9:33 am Post subject: Consequences of a reversed fuel filter? |
I'm looking at a 1970 T1 and the guy admits it won't start/run.
He sends me a pic of the engine and the first thing I notice is the filter is on backwards!
Can permanent damage result from this on an ACVW engine, or is it just a silly, reversible mistake, so to speak? _________________ Lookin' for a wheel stamped 5/66 |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35999 Location: Conejo Valley, CA
Posted: Fri Aug 15, 2025 10:04 am Post subject: Re: Consequences of a reversed fuel filter? |
No damage, unless it was clogged with crap and THEN put on backwards, which would send the gunk into the carb.
Filter shouldn't be in the engine bay anyway, unless its metal and clamped to something so it doesn't shake. Put a metal one (and write the date on it) and mount it next to the tranny. _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Posted: Fri Aug 15, 2025 10:49 am Post subject: Re: Consequences of a reversed fuel filter? |
Thank you. From what I could make out from a web search is that performance would certainly suffer and it could screw up the fuel pump from continued backwards pressure. _________________ Lookin' for a wheel stamped 5/66 |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52901 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Aug 15, 2025 11:00 am Post subject: Re: Consequences of a reversed fuel filter? |
It depends on how clean the tank and system is, if it's making lots of crap a rreversed filter will clog up quickly (less surface area), if it's fairly clean then you may never notice an issue.
But look at it as an indicator of the skill level of the person maintaining the car, count on many other surprises. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Aug 15, 2025 11:12 am Post subject: Re: Consequences of a reversed fuel filter? |
busdaddy wrote: |
But look at it as an indicator of the skill level of the person maintaining the car, count on many other surprises. |
Certainly crossed my mind!  _________________ Lookin' for a wheel stamped 5/66 |
KTPhil  Samba Member
Posted: Fri Aug 15, 2025 12:01 pm Post subject: Re: Consequences of a reversed fuel filter? |
busdaddy wrote: |
Yes, this is a warning!
Like when I found a PO had "bridged" the front clutch cable eye and the pedal arm with a big PAPER CLIP, being too lazy to unhook the back and do it again. I thought back to the sale discussion where he proudly said he had rebuilt the engine recently... surprisingly, the engine lasted a couple more years! _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2919 Location: Thornton, CO
Posted: Fri Aug 15, 2025 2:04 pm Post subject: Re: Consequences of a reversed fuel filter? |
If that's all that's causing it to run poorly, and he's selling it in not running condition, you could be sitting on gold. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
Posted: Fri Aug 15, 2025 2:26 pm Post subject: Re: Consequences of a reversed fuel filter? |
scottyrocks wrote: |
If that's all that's causing it to run poorly, and he's selling it in not running condition, you could be sitting on gold. |
That thought also crossed my mind, but not sure how realistic that is. Probably more wishful thinking on my part...  _________________ Lookin' for a wheel stamped 5/66 |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 531 Location: Eastern north carolina
Posted: Sat Aug 16, 2025 5:13 am Post subject: Re: Consequences of a reversed fuel filter? |
If you can post the picture that was sent to you, more "faux pas " may be revealed. |
Posted: Sat Aug 16, 2025 9:09 am Post subject: Re: Consequences of a reversed fuel filter? |
Bobs67vwagen wrote: |
Not a very good pic, but have at it!
Posted: Sat Aug 16, 2025 10:43 am Post subject: Re: Consequences of a reversed fuel filter? |
Hard to see any detail on that photo. I can see the left side fan housing tube to the muffler is either missing or not connected which if run like that for a while is not a good sign. Kind of surprising to see the one year only reflectors on brackets from the bumper still there. Alot of those are long gone. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71619 Location: Phoenix 602
Posted: Sat Aug 16, 2025 5:59 pm Post subject: Re: Consequences of a reversed fuel filter? |
That vacuum line has definitely seen better days. _________________ Lookin' for a wheel stamped 5/66 |
zerotofifty Samba Member
Posted: Sun Aug 17, 2025 7:13 am Post subject: Re: Consequences of a reversed fuel filter? |
Likely none _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
KTPhil  Samba Member
Posted: Sun Aug 17, 2025 1:49 pm Post subject: Re: Consequences of a reversed fuel filter? |
Maybe this helps:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
