Nova Scotian 54 standard restoration
Page: Previous  1, 2, 3 ... 28, 29, 30
sgellis
sgellis is offline
PostPosted: Sat Oct 25, 2025 6:01 am    Post subject: Re: Nova Scotian 54 standard restoration Reply with quote
Think I have the transmission hump panel figured out.
I will press in the ribs and use a 3 D printed die to help with the bend.
Now to start pressing.
My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings)
Huetti_1989
Huetti_1989 is offline
PostPosted: Sat Oct 25, 2025 2:46 pm    Post subject: Re: Nova Scotian 54 standard restoration Reply with quote
I love that pressing tools!
They are a game changer Smile
-Christian
My 1957 SC
http://www.thesamba.com/vw/forum/viewtopic.php?t=605363&postdays=0&postorder=asc&start=0
MY 1967 Sparsamba:
https://www.thesamba.com/vw/forum/viewtopic.php?t=757182
My 1952 Panel:
https://www.thesamba.com/vw/forum/viewtopic.php?t=797388
My 1954 Deutsche Bundespost:
http://www.thesamba.com/vw/forum/viewtopic.php?t=621802
My 1961 SO34:
https://www.thesamba.com/vw/forum/viewtopic.php?t=716285
My 1991 Westfalia California:
http://www.thesamba.com/vw/forum/viewtopic.php?t=650751
sgellis
sgellis is offline
PostPosted: Sun Oct 26, 2025 12:22 pm    Post subject: Re: Nova Scotian 54 standard restoration Reply with quote
Ruff pressing done. Lots of tidying to do but will wait until it is almost finished too fix a lot of the details.
The ribs positions came out matching the original. I am getting better at estimating the shrinkage.
Next I will form in the hump. Hopefully it will take up most of the extra metal but may need to heat shrink.
LAGrunthaner Premium Member
LAGrunthaner is offline
PostPosted: Mon Oct 27, 2025 3:11 am    Post subject: Re: Nova Scotian 54 standard restoration Reply with quote
sgellis, that is stunning! You are a master.
Applause Applause Applause
Maui Roadsters VW Logo
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote:
sgellis
sgellis is offline
PostPosted: Wed Oct 29, 2025 5:10 pm    Post subject: Re: Nova Scotian 54 standard restoration Reply with quote
Bit more done. Not an easy part to get flat. I may need to put in a couple relief cuts.
It is good enough to put in the long bends so will see how the back reacts to the bend. Maybe I can get away with some more shrinking.
sgellis
sgellis is offline
PostPosted: Sat Nov 01, 2025 2:52 pm    Post subject: Re: Nova Scotian 54 standard restoration Reply with quote
Bends in. The 3D printed die worked great at getting the ribs around the 50 mm radius.
The bulge over the transmission is not working out so will cut it out and create that part separate. Too much extra steel there to take up.
sgellis
sgellis is offline
PostPosted: Thu Nov 06, 2025 7:55 pm    Post subject: Re: Nova Scotian 54 standard restoration Reply with quote
Getting bits fitted. I will need to do some repairs to the original parts before welding them together.
Always super satiating to lay an old rusty part on the new piece and having the ribs lay together perfectly. Smile
I have to do a repair to the vin. A few of the stamping were very deep and the rust from the rear made a few pin hols in the bottom of the digits. Plan is to spread a thin layer of JB weld on the back and sand smooth. I will spay a few layers of zinc on the front to prevent the JB weld from coming through. The zinc is easy to remove after.
matthew henricks
matthew henricks is offline
PostPosted: Fri Nov 07, 2025 8:29 am    Post subject: Re: Nova Scotian 54 standard restoration Reply with quote
Can you please expand on this and show us when you do it?
1964 Original Owner build Thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=702135&highlight=
Ambulance Fan's. https://www.thesamba.com/vw/forum/viewtopic.php?t=627707&highlight=
Parts i am looking for:
64 bug nice used front/rear Black LHD floor mat.
D-train
D-train is offline
PostPosted: Fri Nov 07, 2025 3:34 pm    Post subject: Re: Nova Scotian 54 standard restoration Reply with quote
Bloody amazing!!
shiny paint doesnt make it worth any more
sgellis
sgellis is offline
PostPosted: Sat Nov 15, 2025 3:34 pm    Post subject: Re: Nova Scotian 54 standard restoration Reply with quote
Finally done... Mostly. Still a few details to add.
If doing it again I would make two parts and seam along where the fire wall panel meets.
D-train
D-train is offline
PostPosted: Sun Nov 16, 2025 1:34 pm    Post subject: Re: Nova Scotian 54 standard restoration Reply with quote
Looks like a bought one! That’s impressive!
myklsmyth
myklsmyth is offline
PostPosted: Mon Nov 17, 2025 10:31 am    Post subject: Re: Nova Scotian 54 standard restoration Reply with quote
Well done sir
sgellis
sgellis is offline
PostPosted: Thu Nov 20, 2025 7:27 pm    Post subject: Re: Nova Scotian 54 standard restoration Reply with quote
On to the rear wheel wells.
Inner panels needed to be removed as they are very rusty along the seams. One seat bolt cover was rusted and needed removing. It had an excessive amount of spot welds. Decided I should remove the other one also.
Started patching the left side. Would be much faster to just make new ones.
sgellis
sgellis is offline
PostPosted: Sat Nov 29, 2025 4:03 pm    Post subject: Re: Nova Scotian 54 standard restoration Reply with quote
Left wheel well finished, mostly
I need to trim 10mm off the lower front of the inner panel. I wasn't 100% sure of the size until everything was fitted. Always easier to trim than to add some on.
Two Glove Boxes
Two Glove Boxes is offline
PostPosted: Sun Nov 30, 2025 8:59 pm    Post subject: Re: Nova Scotian 54 standard restoration Reply with quote
Looks great!!
1950 Deluxe Sedan Build
Two Glove Boxes IG
ryans65
ryans65 is offline
PostPosted: Tue Dec 02, 2025 2:15 pm    Post subject: Re: Nova Scotian 54 standard restoration Reply with quote
you're a madman, I expect no less from the barndoor forum though!!
sgellis
sgellis is offline
PostPosted: Sat Dec 06, 2025 1:19 pm    Post subject: Re: Nova Scotian 54 standard restoration Reply with quote
I needed a quick part to build so finished off the front valance.
I clamped the panel in place to insure the bumper bracket holes were lined up.
The angle is 18g. Curved it with the stretcher. I clamped the panel on high and spot welded the angle on to ensure it had the correct curve.
Huetti_1989
PostPosted: Mon Dec 08, 2025 2:02 pm    Post subject: Re: Nova Scotian 54 standard restoration Reply with quote
Ready for the bumper now! Very Happy
-Christian
My 1957 SC
MY 1967 Sparsamba:
My 1952 Panel:
My 1961 SO34:
Page 30 of 30
