craigolio1 Samba Member
Posted: Fri Nov 21, 2025 1:13 pm Post subject: Longer studs for 10mm carb spacer? |
Hey all.
I’m hoarding the parts need to do an upgrade to an alternator in my 1971 Ghia.
From reading and videos I see people needing to add a 10mm spacer to the carb. I can’t seem to find longer studs or extensions.
I’d really like it to be a Canadian source if possible. Can anyone advise?
Thanks.
Craig. _________________ Located in the Toronto area.
1971 Ghia Convertible
Join me on my Karmann Ghia journey.
https://www.thesamba.com/vw/forum/viewtopic.php?p=10441921#10441921 |
vwmerckx  Samba Member
Joined: August 12, 2012 Posts: 256 Location: Phoenix, AZ
Posted: Fri Nov 21, 2025 2:44 pm Post subject: Re: Longer studs for 10mm carb spacer? |
I have a 10mm spacer on my carburetor and installed these longer studs - purchased from the local VW machine shop.
Sorry - cannot help you with a Canadian source, other than Scott at German Supply (https://germansupply.com) located in Toronto. I am sure he could help !!
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80644 Location: Sneaking up behind you
Posted: Fri Nov 21, 2025 3:02 pm Post subject: Re: Longer studs for 10mm carb spacer? |
Any good hardware store should have M8x1.25 studs. They don't have to be made by VW... they're just hardware. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Fri Nov 21, 2025 4:34 pm Post subject: Re: Longer studs for 10mm carb spacer? |
| vwmerckx wrote: |
Thank you’ knowing the length is very helpful. _________________ Located in the Toronto area.
| Glenn wrote: |
| Any good hardware store should have M8x1.25 studs. They don't have to be made by VW... they're just hardware. |
This was a big help.
Thank you. _________________ Located in the Toronto area.
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6474 Location: 37.5N 77.1W
Posted: Fri Nov 21, 2025 6:13 pm Post subject: Re: Longer studs for 10mm carb spacer? |
can be made by cutting the 'head' off of a metric bolt 1 3/8" (35mm) long. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
Posted: Fri Nov 21, 2025 6:30 pm Post subject: Re: Longer studs for 10mm carb spacer? |
| runamoc wrote: |
can be made by cutting the 'head' off of a metric bolt 1 3/8" (35mm) long. |
I was wondering about that. The studs have the unthreaded part in the middle which I didn’t think was critical, but also I’m not well versed enough in this stuff to know for sure that they aren’t important in some way. _________________ Located in the Toronto area.
Glenn  Mr. 010
Posted: Fri Nov 21, 2025 6:39 pm Post subject: Re: Longer studs for 10mm carb spacer? |
The unthreaded section is the set the depth that it's screwed into the carb flange. It's not needed.
Honestly if you can leave the head on and just screw it into the carb base. _________________ Glenn
Member #1009
#BlueSquare
Posted: Fri Nov 21, 2025 7:25 pm Post subject: Re: Longer studs for 10mm carb spacer? |
| Glenn wrote: |
Honestly if you can leave the head on and just screw it into the carb base. |
That just makes too much sense. Hahaha. _________________ Located in the Toronto area.
Posted: Sat Nov 22, 2025 8:16 am Post subject: Re: Longer studs for 10mm carb spacer? |
| Quote: |
| just screw it into the carb base |
in a way, length is more critical, especially on the rear mounting bolt..using bolts instead of studs for the fuel pump allows you to use a 'generator' style fuel pump with an alternator. It allows changing a 'generator' style fuel pump without having to lift up the alternator. BUT for some reason...'soft' metal 'things' use studs instead of bolts for mounting. I'm guessing pulling torque and twisting on the threads at the same time instead of just a pulling torque of a stud. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Posted: Sat Nov 22, 2025 11:22 am Post subject: Re: Longer studs for 10mm carb spacer? |
| runamoc wrote: |
| Quote: |
in a way, length is more critical, especially on the rear mounting bolt..using bolts instead of studs for the fuel pump allows you to use a 'generator' style fuel pump with an alternator. It allows changing a 'generator' style fuel pump without having to lift up the alternator. BUT for some reason...'soft' metal 'things' use studs instead of bolts for mounting. I'm guessing pulling torque and twisting on the threads at the same time instead of just a pulling torque of a stud. |
Interesting. I never thought of the pulling vs twisting AND pulling. I read 14ftlb of torque which I feel would be little stress on the threads.
My car already has an alternator style fuel pump so that one less thing to worry about.
On the subject of carbs. Are people using just paper gaskets? Just liquid gasket? Paper and liquid gasket? I’ve read all of these things.
Posted: Sat Nov 22, 2025 11:45 am Post subject: Re: Longer studs for 10mm carb spacer? |
| Quote: |
| just paper gaskets? |
I use just the cardboard ones that come in the kit. Back in the day, would trace and cut out cardboard gaskets from the phonebook cover, backs of note pads, and cereal boxes. I can buy that stuff now.  _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Posted: Sat Nov 22, 2025 1:18 pm Post subject: Re: Longer studs for 10mm carb spacer? |
| runamoc wrote: |
| Quote: |
I use just the cardboard ones that come in the kit. Back in the day, would trace and cut out cardboard gaskets from the phonebook cover, backs of note pads, and cereal boxes. I can buy that stuff now.  |
Hahahha. Amazing. So the paper ones are fine then. Noted. _________________ Located in the Toronto area.
