Vintage Battery box with 6V optima battery inside
Page: Previous  1, 2, 3, 4, 5, 6
kingkarmann
kingkarmann is offline
PostPosted: Fri Apr 15, 2022 4:32 pm    Post subject: Re: Vintage Battery box with 6V optima battery inside Reply with quote
I would be very interested in a vintage 12v that would work with the 67 hold down set up.
A Varta decal on a modern battery is the best illusion I can create.
udo dreisoerner
udo dreisoerner is offline
PostPosted: Mon Apr 18, 2022 5:31 am    Post subject: Re: Vintage Battery box with 6V optima battery inside Reply with quote
Sebastian Gaeta wrote:
Since villemi has not posted about this for over a year and the project appears to be dead, I'd like to show you guys what i did. Charles Rollins at Woody's Custom Shop has been making Optima Cloaking devices for many, many years and I was a bit surprised they were never mentioned here.
I have used them in my 356's for a long time and this winter got some inspiration for my Ghia when I saw this image of an original VOA 6v battery.
I bought on of the devices from Woody's with the intention to mimic this battery as much as I could. I recreated the graphics in Photo Shop and had a friend with a vinyl cutter make them. Rather than making and laying out each individual piece in the aqua color, he did a negative cut on black vinyl overlaid on the aqua so that the little parts would not be so delicate. For the front graphic it worked fine but for the graphics on the top cover it looks like a peel off sticker so we will redo that in the individual characters in aqua.
Here is what the device looks like from Woody's.
Here is what I came up with using that device
And here it is in the car.
It's close enough for now and looks much better than the bare optima as far as originality goes, if that's anything you care about.
Hi from Germany. Where can i buy a Box Like this?
Searching for a 1956 lowlight karmann ghia with a VIN number between1273054 and 1273440, and the matching engine with an Engine Number between
1525510 and 1525519 PLEASE OFFER ME ONLY THE CARS THAT I'M LOOKING FOR, THANKS!!
JeffL
JeffL is offline
PostPosted: Sun Apr 24, 2022 3:46 pm    Post subject: Re: Vintage Battery box with 6V optima battery inside Reply with quote
I just bought this battery at Napa and the fit is great for the standard 6V metal top. I was thinking of a print as you suggest. However to get the ground and positive in the correct positions the smooth area for the decal is on the back. I think I will run without a decal for my 56 Ghia.
http://karmannghias.org/
https://karmannghias.org/GAlken/index.html
boinkffd
boinkffd is offline
PostPosted: Mon Apr 25, 2022 4:30 am    Post subject: Re: Vintage Battery box with 6V optima battery inside Reply with quote
Thank you Everett for sending me the diagram. I was hopeful the the 6 Volt Optima footprint would fit in the standard VW Ghia 6volt. The optima is a bit large. I can look into printing the cases but it seems there is already a cover on the market from the previous post.
I will still look into options as well as Resin Printing the different battery badge logos.
Geoff
Sebastian Gaeta
Sebastian Gaeta is offline
PostPosted: Mon Apr 25, 2022 7:38 am    Post subject: Re: Vintage Battery box with 6V optima battery inside Reply with quote
Hi Udo,
Here is one on eBay. They are sold by Charles Rollins at Woody's Custom Shop:
https://www.ebay.com/itm/363792122625?hash=item54b3b34301:g:mOwAAOSw2s1UzxjF
Sebastian Gaeta
'57 Swiss Delivery Oval Agave Green, OKRASA Powered
'63 Beetle Turkis
‘64 Karmann Ghia Coupe Manila Yellow/Black Roof, OKRASA Powered
'64 356C Cabriolet Signalrot
'65 356C Coupe Rubinrot
'66 Single Cab Velvet Green
'67 Ghia convertible Lotus White
Saul82Primo
Saul82Primo is offline
PostPosted: Tue Apr 29, 2025 12:12 am    Post subject: Re: Vintage Battery box with 6V optima battery inside Reply with quote
Do you sell these custom 3D 6 Volk battery cases? I'm very interested in buying one.
GELS
GELS is offline
PostPosted: Thu May 15, 2025 9:34 pm    Post subject: Re: Vintage Battery box with 6V optima battery inside Reply with quote
Saul82 - I would love to find one too.
Aircraft800
Aircraft800 is offline
PostPosted: Tue Nov 25, 2025 2:10 pm    Post subject: Re: Vintage Battery box with 6V optima battery inside Reply with quote
Are the files available so I can have one printed locally?
Woody's no longer makes them.
JeffL
JeffL is offline
PostPosted: Tue Nov 25, 2025 2:45 pm    Post subject: Re: Vintage Battery box with 6V optima battery inside Reply with quote
You could put the 12v optima under the rear seat and leave the 6v there as a dummy. I used a Miata 12v under the back seat is the Alken which is as low as a Ghia. Just other ideas.
I would like a VWoA decal to put on my tractor supply battery after I pulled theirs off. Any out there?
Aircraft800
PostPosted: Tue Nov 25, 2025 4:04 pm    Post subject: Re: Vintage Battery box with 6V optima battery inside Reply with quote
It's not for my VW, it's for my 1950 John Deere MT tractor, you guys just came up with the correct way to hide the Optima 6V Group 1 battery.
Page 6 of 6
