Separating body and chassis
Page: 1, 2, 3  Next
MTT3107
MTT3107 is offline
PostPosted: Sat Dec 06, 2025 3:44 pm    Post subject: Separating body and chassis Reply with quote
So, I am getting ready to pull the body from the chassis, started removing all the bolts today.
Caster wheels for the dolly are coming in tomorrow, and then I'll build the dolly.
But ran into an issue with the bolts connecting the body to the chassis.
Got everything out, the 17mm bolts in the back, at the front of the body, and at the front beam.
But 2 of the 13mm bolts under the chassis are just spinning, I suppose the captive nut there broke loose.
What do you do there ? Just cut off the bolt head ?
And what to do with those locations, once the body goes back on ?
Teeroy Premium Member
Teeroy is offline
PostPosted: Sat Dec 06, 2025 11:12 pm    Post subject: Re: Separating body and chassis Reply with quote
Cut the head off of them. Once body is off the pan, open them up from the bottom and fix or replace with solid metal and captive nut
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
Rome
Rome is offline
PostPosted: Sun Dec 07, 2025 10:16 pm    Post subject: Re: Separating body and chassis Reply with quote
If you remove the front seats, the shifter, and the engine first, you won't need to raise the body as high to clear the chassis.
MTT3107
MTT3107 is offline
PostPosted: Mon Dec 08, 2025 5:21 am    Post subject: Re: Separating body and chassis Reply with quote
Got it…
Seats are already out, since they need to be re-upholstered.
Shifter is out because I am replacing the shift rod bushing, the original was completely gone.
Engine :
I won’t pull the engine yet…
But yesterday I removed the trunk and deck lids to lighten the body as much as possible, and noticed that with the decklid removed, you can pull the fan shroud easily, as opposed to the beetle.
So I did that, and will also remove the oil cooler and carb & intake manifold.
MTT3107
MTT3107 is offline
PostPosted: Mon Dec 08, 2025 1:30 pm    Post subject: Re: Separating body and chassis Reply with quote
So, I went back to the 2 bolts which were giving me trouble.
Was ready to attack them with the angle grinder, but decided to try again first.
But this time only with the ratchet and socket instead of the impact driver.
Turns out, the impact socket is thicker, and it just wasn't getting properly seated because of the shape of the washers.
With the ratchet and socket, once I had cleared off dirt and underbody gunk, I was able to get the socket on properly, and got them to turn. One of them needed a lot of back and forth, but came out in the end.
So tomorrow it's off to the big orange store to buy materials for the dolly, and build it.
jeffrey8164
jeffrey8164 is offline
PostPosted: Mon Dec 08, 2025 6:14 pm    Post subject: Re: Separating body and chassis Reply with quote
Good news.
I still haven’t figured out if it’s just the energy of the universe or just me, but it seems that even if I know what needs to be done exactly, there will always be a fastener that makes it take twice as long.
Volkswagen!
(Compression 8.7:1)
MTT3107
MTT3107 is offline
PostPosted: Tue Dec 09, 2025 5:02 am    Post subject: Re: Separating body and chassis Reply with quote
I think it’s the law of the universe….
Or maybe just an extension of Murphy’s law.
Very Happy Very Happy
MTT3107
MTT3107 is offline
PostPosted: Tue Dec 09, 2025 6:21 am    Post subject: Re: Separating body and chassis Reply with quote
Another question about the body/chassis gasket.
One of the tasks I have once the body is off the chassis, is to replace the gasket.
I have been all over the web and youtube to see how it's done, and what techniques are being used.
Most folks will apply some kind of sealant/glue, to hold the gasket in place.
But then I saw this video, from Airkewld : https://www.youtube.com/watch?v=_FYJELtOsBM
They use self tapping screws to hold it in place, no sealant/glue.
Pros/Cons ?
jeffrey8164
PostPosted: Tue Dec 09, 2025 12:41 pm    Post subject: Re: Separating body and chassis Reply with quote
I just used 3M weatherstrip adhesive when I did mine.
I wouldn’t feel comfortable punching a bunch of holes in the pan.
Volkswagen!
(Compression 8.7:1)
MTT3107
MTT3107 is offline
PostPosted: Tue Dec 09, 2025 4:42 pm    Post subject: Re: Separating body and chassis Reply with quote
I wouldn’t worry about the holes, they are tiny.
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Thu Dec 11, 2025 3:00 pm    Post subject: Re: Separating body and chassis Reply with quote
I think they said in the video that they used the holes that the factory had made when they used nails.
MTT3107
MTT3107 is offline
PostPosted: Fri Dec 12, 2025 6:08 pm    Post subject: Re: Separating body and chassis Reply with quote
So, today I finally got to separate the body from the chassis.
But before I completely pull it, I will have to modify my dolly, since it is not high enough.
No big deal, just lift one end at at time with the hoist, and replace the uprights on the dolly with taller ones.
That said, it took me a while to get it free.
Looks to me like this Ghia isn't as undisturbed as I thought..
It looks like the body was off the pan before..
Because there is no gasket between body and pan, just some weird brownish goop..I will clean it all up and install the proper gasket.
And, have a question about the steering column :
I wanted to remove it, but found that the wires for turn signal and ignition are connected directly, no connector in the column like on my '73 beetle.
Is this normal ?
To remove the column do I have to cut the wires, and splice them back together when reinstalling it ?
Rome
Rome is offline
PostPosted: Fri Dec 12, 2025 8:50 pm    Post subject: Re: Separating body and chassis Reply with quote
About 35 years ago I had a very rusty '72 Ghia Coupe "parts car" on which I also separated the body from the chassis. It had the exact same brownish foam strip remnant with very sticky glue that was all along the perimeter of the chassis. My car was certainly never separated before, so I'd confidently say that your chassis seal seems factory original.
My steering column wiring harness definitely had a large connector high up on the column, but it contained the extra wires compared to yours for the wiper motor switch. I doubt that VW would design a harness like you found on yours on which the wiring could not be quickly connected separately, due to the assembly line process of mating the body to chassis and getting all the mechanical and wiring connections completed quickly.
The harness on your Ghia would be largely the same as on a Beetle of the exact same year, so if there's a reader who also has, or recently worked on an original unmolested Beetle of your era could comment about this detail. Or check the Ghia factory wiring diagram in the "Technical" tab to see if the wiring portion at the column had an obvious break due to a multi-chamber connector.
MTT3107
MTT3107 is offline
PostPosted: Sat Dec 13, 2025 6:56 am    Post subject: Re: Separating body and chassis Reply with quote
Just checked the wiring diagram here on the samba technical section. There are several diagrams for the '71 Ghia, they all show direct connection between turn signal, dimmer switch, ignition switch and the rest of the wiring.
Redlabel6
Redlabel6 is offline
PostPosted: Sat Dec 13, 2025 7:31 am    Post subject: Re: Separating body and chassis Reply with quote
My '73 had the same waxy goop between the pan and body, no gasket.
I used a butyl rubber rope when I put it back together, no gasket.
d
1957 Oval Window Beetle
1973 Karmann Ghia Coupe
https://www.thesamba.com/vw/forum/viewtopic.php?t=666792&highlight=73+coupe
Teeroy is offline
PostPosted: Sat Dec 13, 2025 9:19 am    Post subject: Re: Separating body and chassis Reply with quote
Just finished a 71 restoration this Spring. 70-1 Ghia ignition switch and turnsignal definitely do not disconnect at steering wheel end. They get loomed together at the switch housing and then run along the steering tube to a grommet by the fuse block. The only connectors are at the fuse block or related switches and relays.
ARR #3
MTT3107
MTT3107 is offline
PostPosted: Sat Dec 13, 2025 4:15 pm    Post subject: Re: Separating body and chassis Reply with quote
OK, thanks for the answers !
I will clear off that goop, and install a regular gasket, already have it here.
And will cut the wires to remove the steering column, and splice them back together when I reinstall it.
Teeroy is offline
PostPosted: Sat Dec 13, 2025 10:02 pm    Post subject: Re: Separating body and chassis Reply with quote
Dont cut and splice, just unhook them. If you need them out of the housing, just cut the outer sleeve so the harnesses will seperate (only about 10 wires)
ARR #3
Bobs67vwagen
PostPosted: Sun Dec 14, 2025 3:17 pm    Post subject: Re: Separating body and chassis Reply with quote
Sometime in the early 70s VW stopped using the rubber gasket between the body and pan and substituted that sticky brown mung. I took the body off a 74 bug pan earlier this year and it had the brown stuff, no gasket. My 67 bug which is off the pan for the 1st time now has the rubber gasket.
MTT3107
MTT3107 is offline
PostPosted: Sun Dec 14, 2025 3:52 pm    Post subject: Re: Separating body and chassis Reply with quote
So will my Ghia.... Very Happy
Page: 1, 2, 3  Next
