sgellis Samba Member
Joined: July 06, 2016 Posts: 2222 Location: SW Nova Scotia, Canada
Huetti_1989 Samba Member
Joined: February 13, 2011 Posts: 1368 Location: Austria
LAGrunthaner  Samba Member
Joined: March 18, 2007 Posts: 5647 Location: 1st Coast
Posted: Mon Oct 27, 2025 3:11 am Post subject: Re: Nova Scotian 54 standard restoration |
sgellis, that is stunning! You are a master.
| sgellis wrote: |
Ruff pressing done. Lots of tidying to do but will wait until it is almost finished too fix a lot of the details.
The ribs positions came out matching the original. I am getting better at estimating the shrinkage.
Next I will form in the hump. Hopefully it will take up most of the extra metal but may need to heat shrink.
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
| Lind wrote: |
| Have you considered simply starting with a nicer bus? I don't know what your skills are, but the race is easier if you can see the finish line. If you are not a runner, don't start off doing a marathon. |
Posted: Thu Nov 06, 2025 7:55 pm Post subject: Re: Nova Scotian 54 standard restoration |
Getting bits fitted. I will need to do some repairs to the original parts before welding them together.
Always super satiating to lay an old rusty part on the new piece and having the ribs lay together perfectly.
I have to do a repair to the vin. A few of the stamping were very deep and the rust from the rear made a few pin hols in the bottom of the digits. Plan is to spread a thin layer of JB weld on the back and sand smooth. I will spay a few layers of zinc on the front to prevent the JB weld from coming through. The zinc is easy to remove after.
_________________ My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings) |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1403 Location: So. Cal
Posted: Fri Nov 07, 2025 8:29 am Post subject: Re: Nova Scotian 54 standard restoration |
| sgellis wrote: |
I have to do a repair to the vin. A few of the stamping were very deep and the rust from the rear made a few pin hols in the bottom of the digits. Plan is to spread a thin layer of JB weld on the back and sand smooth. I will spay a few layers of zinc on the front to prevent the JB weld from coming through. The zinc is easy to remove after. |
Can you please expand on this and show us when you do it? _________________ 1964 Original Owner build Thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=702135&highlight=
Ambulance Fan's. https://www.thesamba.com/vw/forum/viewtopic.php?t=627707&highlight=
Parts i am looking for:
64 bug nice used front/rear Black LHD floor mat. |
D-train Samba Member
Posted: Fri Nov 07, 2025 3:34 pm Post subject: Re: Nova Scotian 54 standard restoration |
Bloody amazing!! _________________ shiny paint doesnt make it worth any more |
Posted: Sun Nov 16, 2025 1:34 pm Post subject: Re: Nova Scotian 54 standard restoration |
Looks like a bought one! That’s impressive! _________________ shiny paint doesnt make it worth any more |
myklsmyth Samba Member
Posted: Mon Nov 17, 2025 10:31 am Post subject: Re: Nova Scotian 54 standard restoration |
| Well done sir |
Two Glove Boxes Samba Member
ryans65 Samba Member
Joined: February 16, 2016 Posts: 1371 Location: Yulee FL
Posted: Tue Dec 02, 2025 2:15 pm Post subject: Re: Nova Scotian 54 standard restoration |
| you're a madman, I expect no less from the barndoor forum though!! |
Posted: Fri Dec 12, 2025 10:22 am Post subject: Re: Nova Scotian 54 standard restoration |
Decided to finish up the front structure. Last bit is the dash pod. The pod bracket is in good condition but the cross braces are rusted along the bottom and beyond repair.
I knew the braces were going to be a pain to bend as my brake can only do 1/2" offset bends. I was able to do a short section by bending the first to 45° followed buy second bend and then finishing the first bend. On full length sections i could not get a good bend as it would slip in the brake.
Ended up using my largest step die in the bead roller with a guide. I offset the dies to give the correct distance between bends. After a few passes it gave me all the bends at around 45°. Then just finished them off in the brake. Work better than i expected.
Now i need to add the bends to the top brace. Haven't decided if I will print some dies or work it by hand.
