Whirlpool direct drive washers
Onceler
Onceler is offline
PostPosted: Mon Dec 15, 2025 12:00 pm    Post subject: Whirlpool direct drive washers Reply with quote
Any of you still running one of these and are familiar with fixing them?
My tub wonโ€™t spin sometimes during the spin cycle. I replaced the clutch a month ago and it seemed ok but now itโ€™s doing it again. Any thoughts?
1972 Karmann Ghia
Cusser
Cusser is offline
PostPosted: Mon Dec 15, 2025 1:04 pm    Post subject: Re: Whirlpool direct drive washers Reply with quote
On some washers, won't go into spin dry if the water pump has removed most/all of the water.
janerick3
janerick3 is offline
PostPosted: Mon Dec 15, 2025 6:33 pm    Post subject: Re: Whirlpool direct drive washers Reply with quote
On the 1st generation front-loaders (before ~2007), I became intimately familiar with the F5 fault.
The plastic shocks (4) that support the bottom of the outer tub have a tendency to break with heavy, unbalanced loads. When this happens, the inner tub rarely becomes balanced enough to start the high-speed spin. When both front shocks break, the outer tub will move around enough to break the wires leading to the fill sensor, located at the bottom front of the outer tub.
Replacement shocks are not that expensive and the front shocks are not hard to replace. Be sure to wear gloves, as the steel frame the shocks lock into is not deburred.
Thanks,
Jan K.
zerotofifty
zerotofifty is offline
PostPosted: Mon Dec 15, 2025 6:48 pm    Post subject: Re: Whirlpool direct drive washers Reply with quote
Buy an old top load machine fix any defects and you will be good for the next 30 years. New appliances are junk. If it has a chip or board in it, run away. Mine is near 40 years old, runs fine, did replace the old water valve in it, it was like about 20 bucks. and the timer wore out, NOS part was like 30 bucks. she just runs and runs, cleans well, cleans fast. no locking door either, so I can add clothes during the cycle without having to restart.
Old machines can be had for little money, they are built to last, like the old VW Bug, ease of service, reliable.
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
OldSchoolVW's Premium Member
OldSchoolVW's is offline
PostPosted: Mon Dec 15, 2025 8:57 pm    Post subject: Re: Whirlpool direct drive washers Reply with quote
Onceler wrote:
Any thoughts?
Buy a basic Speed Queen and end your misery.
Whirlpools aren't what they used to be 30 or 40 years ago. It seems they and most other brands have decided to put their manufacturing $$ into ridiculous bells and whistles instead of durable components and simple, reliable designs.
Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
Abscate
Abscate is offline
PostPosted: Tue Dec 16, 2025 2:22 am    Post subject: Re: Whirlpool direct drive washers Reply with quote
You have to stay commercial to go the low obsolescence route. My Amana turned into a toaster after I couldnโ€™t buy the gasket between tub and motor after 20 years. I had replaced motor about 3 years before
You also have to sign up to do all the work yourself or have a contract. Pay as you go will break the bank.
mrinnovation1
mrinnovation1 is offline
PostPosted: Tue Dec 16, 2025 5:14 am    Post subject: Re: Whirlpool direct drive washers Reply with quote
[quote="OldSchoolVW's"]
Onceler wrote:
Any thoughts?
Ditto!
iowegian Premium Member
Samba Curmudgeon
iowegian is offline
PostPosted: Tue Dec 16, 2025 7:16 pm    Post subject: Re: Whirlpool direct drive washers Reply with quote
True.
Our "new" Maytag washer is 41 years old and has needed ZERO repairs.
Our dryer is older-------it was built in 1961 and we bought it used in 1965.
(30 years ago I had to replace the timer--I was disappointed that it failed so early in its life))
Both of these machines are genuine Maytags made in Newton, Iowa by stubborn Dutchmen.
Xevin
Xevin is offline
PostPosted: Tue Dec 16, 2025 7:55 pm    Post subject: Re: Whirlpool direct drive washers Reply with quote
I had a chance to grab one of those for free sitting on the curb in West Hollywood back in the 80s. Looked to good to be true so I kept on driving Wink Shocked
We have a high-end Electrolux set front loader for the last 15 years. Itโ€™s so meh. Iโ€™m surprised itโ€™s still working. The old top loader early 90s Kenmore (whom ever made it) in our other home was fantastic. Everything just seemed cleaner and dried faster. I think a lot of the eco friendly โ€œthings or incentives โ€ made the modern washer and dryerโ€™s not great or long lasting.
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
PostPosted: Tue Dec 16, 2025 10:18 pm    Post subject: Re: Whirlpool direct drive washers Reply with quote
I had a chance to grab one of those for free sitting on the curb in West Hollywood back in the 80s. Looked too good to be true so I kept on driving Wink Shocked
Shocked
Ah, the foolish things we did in our youth. Wink
As well built as they are today, they were built like a tank back then. If you'd have fixed up that beast you'd still be doing laundry with it.
Yes, those old Kenmore washers and dryers were great. Simple, well built and reliable.
Honestly, do we really need anything more than:
Water temp - cold, warm, hot
Load size - small, medium, large
Agitation - gentle, normal
Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
Abscate
Abscate is offline
PostPosted: Wed Dec 17, 2025 2:44 am    Post subject: Re: Whirlpool direct drive washers Reply with quote
With seven ladies in the house and 6 animals our machines got heavy use. Women are demanding and wonโ€™t leave the house with crap all over them like me. Add in two sports a season and you really pound the machine more then the bachelor two pairs of underwear a week.
How did Wall Street genius Eddie Lempert destroy the Kenmore brand with 50% retail share and raid the pension fund in a few short years? Bad story
Cusser
Cusser is offline
PostPosted: Wed Dec 17, 2025 6:53 am    Post subject: Re: Whirlpool direct drive washers Reply with quote
I bought my 1981-made Maytag dryer in 1988. I've replaced the heating element, glides, belt and belt idler, and last week replaced a 5" wire with crimped ring on one end and a crimped 14" female connector on the other going to the heat coil assembly.
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Dec 17, 2025 9:03 am    Post subject: Re: Whirlpool direct drive washers Reply with quote
I miss my old top loading Maytag in the 1980s. Two failures, both repairable. A rust pinhole in the tub, patched. And a belt idler pully whose squeak drove me nuts until I replaced it. Moved and no longer have it. I expect its still washing clothes for somebody else.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
Abscate
Abscate is offline
PostPosted: Fri Dec 19, 2025 4:34 am    Post subject: Re: Whirlpool direct drive washers Reply with quote
[quote="mrinnovation1"]
Onceler wrote:
Any thoughts?
Ditto!
The relief she provided was only temporary, and it was more a rental situation
Onceler
Onceler is offline
PostPosted: Fri Dec 26, 2025 8:02 pm    Post subject: Re: Whirlpool direct drive washers Reply with quote
Finally fixed the issue. Seems the transmission had an issue going from neutral to drive. They say you can fix the gear in the transmission, but I just went ahead and installed a new one. Now she washes like stink
1972 Karmann Ghia
zerotofifty
PostPosted: Fri Dec 26, 2025 8:28 pm    Post subject: Re: Whirlpool direct drive washers Reply with quote
the timer mechanism may be the issue, the timer has a bunch of cams and contacts, over time some contacts can get burnt and no longer trimmer the solenoids or relays anymore.
Many of these washers have a circuit diagram on the inside of the rear cover panel. If not consult on line for repair manual or diagrams for your specific model on the interweb.
You can then see which solenoid and its wires need to be switched to make the spin go. Then check the timer for correct contact closure.
I replaced my timer not too long ago, one of the cycle contacts was burnt out.
Good luck, keep us posted on progress.
Words to live by.
nsracing
nsracing is offline
PostPosted: Mon Dec 29, 2025 7:58 am    Post subject: Re: Whirlpool direct drive washers Reply with quote
Make sure your problem are not the rollers. Just isolate the problem and see where it is broken.
Is it the motor or just tub/roller issue? Unhook the belt and check the motor. While the belt is off check the rollers-make sure they are not frozen w/ lint or just needing lubes.
Amazon sells all the repair kits to any washer. I just rebuilt my Whirlpool.
While you are at it, replace the water solenoids if they have miles to them.
Enjoy -
sloans265
sloans265 is offline
PostPosted: Wed Dec 31, 2025 10:26 pm    Post subject: Re: Whirlpool direct drive washers Reply with quote
Sorry to come in late Laughing Iโ€™ve been in the appliance business since โ€˜09. I love/have a direct drive Whirlpool washer. Had I seen the post I would have mentioned the transmission issue. You canโ€™t buy a modern washer that works as well as a that old machine
Also notice how everyone was referencing the newer machines. Apples and Oranges these days. Even Speed Queens have issues these days. Iโ€™m pushing more into install work to get away from dealing with crap quality/design
1970 Lotus White Panel
In search of any Pensacola Fla dealership items
