MrTL72 Samba Member
Joined: December 16, 2025 Posts: 2 Location: Lakewood, CA
Posted: Tue Dec 16, 2025 6:04 am Post subject: 1970 Bus Wiring Problems |
I’ve got my hazards turn signals working when the ignition is off. When I turn on the ignition, the hazard light stays on solid and the flasher relay stops working.
I’ve got the wiring diagram here, and things look good. I feel like I’m sending a 2nd power source to the hazard switch or flasher relay and screwing it up.
The headlight switch, hazard switch, and flasher relay are new.
Any ideas ? |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1811 Location: New Brunswick,Canada
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53265 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Dec 16, 2025 8:43 am Post subject: Re: 1970 Bus Wiring Problems |
Oh no..., new switch, most likely the issue.
New switches lack the 54 terminals, thier claims it fits 68-73 models is a fib, it only works with European models.
It must have required some creative wiring to find places for the extra wires. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4157 Location: Seattle, WA
Posted: Tue Dec 16, 2025 9:02 am Post subject: Re: 1970 Bus Wiring Problems |
Do you have stock (incandescent) bulbs at the instrument indicators?
With stock wiring, there is no turn signal functionality when the ignition is off. _________________ '67 bug: seized by the authorities
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4761 Location: Pasadena CA/DTLA soon China
Posted: Tue Dec 16, 2025 9:11 am Post subject: Re: 1970 Bus Wiring Problems |
| busdaddy wrote: |
It must have required some creative wiring to find places for the extra wires. |
Mr Busdaddy, what switches might these be? Mine is an European model. I may be interested in buying a spare.
Martin
Allwagons _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
Everything sounds good on paper! |
Posted: Tue Dec 16, 2025 11:20 am Post subject: Re: 1970 Bus Wiring Problems |
| ALLWAGONS wrote: |
| busdaddy wrote: |
Martin
Allwagons |
The one CIP says fits everything for example: https://www.cip1.ca/vwc-111-953-235-f/?_gl=1*1ojyw...MyOTM5MjQ. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
70bus  Samba Member
Posted: Tue Dec 16, 2025 2:02 pm Post subject: Re: 1970 Bus Wiring Problems |
Also what t/s relay are you using? Wrong one can cause issues like that. 70 needs 4-pin box or equivalent with 31, 49, 49a and KBL. Speedo indicator light goes to KBL not 49a. _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Raoul the 65 singlecab
Karl the 70 nine-seater |
